1971 2 lt Cam
Date: 10/10/2020 06:27 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 01/18/2017 05:35 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Windshield
Date: 01/15/2022 09:31 pm
Date: 03/16/2017 10:00 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
  • Online today: 1,972
  • Guests: 128
  • Total: 128
Manual Transmission Tag
Started by TPETTI1, August 08, 2006, 01:39:33 PM
78cruisingwagon
I have Ford shop manuals from 1970 to 1979. However, being a truck driver it'll be a couple of weeks before I get back home. Most Pinto four speeds were 3.65-1.97-1.37 and 1:1 and reverse was 3.65. Starting in 1978 most Pinto four speeds were 3.98-2.14-1.39- and 1:1. There were exceptions of course. The same Hummer Trans were used in four cylinder Fairmonts/Zephyrs and Mustang II fours. The Mustang II v6's were Borg Warner SR4 transmissions which are identifiable by the fact they look a lot like T5 five speeds. The regular Passenger car three speeds were mostly 2.99-1.79-1:1
and the four speeds were either 2.78-1.93-1.37-1:1 or 2.32-1.69-1.31 and 1;1. Once again depending on application they were exceptions to the above. When I get back home for the group I will exhume all Trans tag codes with gear Information and post it here for reference. I should have it entered by Decmber 1st. Hope this helps.
Gaslight
Well there is this website.
http://www.ddperformance.com/Trans%20ID%20chart.htm
But that will only handle the 5 speeds.
I have never seen anything for the 4 speeds but maybe this will help.
http://www.motivegear.com/tech_info/tranny_guide/tranny_guide.html
Jake
TPETTI1
All of them have a tag and most are 4 speed
Gaslight
Are they 4 or 5 speeds?  Do any of them have a little aluminum tag hanging off a bolt on the tailshaft?
Jake
TPETTI1
I've got 8 transmissions and need to know where or how I can get the gear ratio any ideal.
