1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 08/27/2018 11:11 am
Looking for front seats
Date: 08/10/2021 09:54 pm
postal pinto
Date: 06/03/2020 09:31 am
Date: 09/01/2017 07:52 am
Date: 02/18/2017 05:52 pm
door sills
Date: 03/14/2020 03:20 pm
  • Online today: 489
  • Guests: 130
  • Total: 130
high friends
Started by wang, August 04, 2006, 01:21:52 PM
eatmydust
     I like plaidpaint, !!!!!! or my favorite is mope the "walk in" cooler.
     ice is fun.
            eatmydust
The ribbing I take for owning a Pinto!  Jeez!!
earthquake
A Ferbulator???Whats next johnson shafts,ca-nibally pins,fuel injected bumper bolts.If you melted a piston you'll know. Cly will be dead at any engine speed below 4 grand Maybe not even then, and it will pump oil out of the breather.Makes a hell of a mess.More than likely it's the cat.
dirt track demon
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
DragonWagon
Do a compression test on the cylinders, pull the catalytic converter, take a good look at the spark plugs and distributor cap/rotor. I suppose the converter could be clogged with who knows what, overheating and causing the sparks and metal bits. A compression test will show you if a piston/rings are toast. If one cylinder (or more) is way lower than the other ones, it's rebuild time. Does it smoke?
I have no idea what a ferbulator is. Distributor? Carborator? Blinker fluid regulator?
Start with the simple stuff and work your way up. Good luck.
1976 mpg Wagon. The start of it all.
1977 Cruising Wagon, to be turboed.
1979 glass hatchback. No motor atm.
1980 wagon parts car.
CHEAPRACER
wang
cat melted piston ferbulater muffler bearigns where to start help
dirt track demon
Muffler bearings are go bad.
The PINTO!!
wang
for thanks.  mabe not good for fix.  cat maybe lots, but guy at parts store said to change the ferbulator and i dont know what this is refering to
71hotrodpinto
Welcome :welcome:
I'm sorry but it sounds like you have melted a piston. Its time for a rebuild on the engine. OR  MAYBE it might be the Catalytic Converter falling apart ????
Id at least tear the cat off and see if it might be the culprit . The top end is the next area to tear down to inspect the engine before you go too far. But Sparks coming out the tail pipe can be expensive bad news.  :sorry:
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
wang
new here, but always loved pintos since when i can remember from.  so just got my first mpg wagon woodgrain green, sweet i'll say.  1977, got it at used lot cheap.  i get home and run bad then started shooting small bits of metal out of tailpipe i don't know what may be.   some of bits were sparks when i saw wife drive awaqy and when back smelled funny.  how to find problem?
