Built 2.0
Date: 10/07/2018 05:27 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 06/19/2018 03:58 pm
Date: 10/24/2019 01:45 pm
Date: 03/17/2019 10:15 pm
Date: 08/13/2017 02:01 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
  • Online today: 269
  • Guests: 183
  • Total: 183
Does anyone with a electric fuel pump...
Started by Glassman, December 28, 2003, 04:53:38 PM
Yeah, common sense was telling me to. I was thinking of installing one like Underdogs dad has on his car. Im still leaning toward the stock T-Bird switch. Thanks for the replies, keep 'em coming.
When I installed the 5.0 in my StangII I didn't use the "crash switch" at first. I had a power steering line spring a leak, dumping fluid on the manifold. it's a scary thought to see the rubber isolator on a 45psi 80liter/hr fuel pump burning! After that I installed the crash switch, and moved my industrial relay to the console so i could pull it out in an emergency. I also bought a fire extinguisher that day. In short, ANY pecautions you can take to keep your ride from going "up in smoke" is worth the time.
Underdog76
On my dads 71 we have two on regular switch in the dash and one kill switch mounted on the rear under the trunk as per racing regulations.
Fast as lightning, strong as thunder
i put one in my car, if you get in a wreck (god forbid) it will cut power to the pump so your not feeding a fire or dumping out fuel on an allready bad situation!
have an inertia shut off switch? Since I have a stock one from the donor car, I was wondering, if I should install it?
