1978 fuel sendng unit
Date: 05/27/2020 09:54 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 11/12/2020 08:28 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
Date: 12/20/2016 10:47 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 10/28/2018 08:45 am
Date: 10/25/2019 03:30 pm
door sills
Date: 03/14/2020 03:20 pm
  • Online today: 1,137
  • Guests: 593
  • Total: 593
Best Carb. for 2.0
Started by snakeriver_man, June 17, 2006, 12:02:40 PM
fast34
I would also go with the 500 cfm Holley.
snakeriver_man
Thanks for your input! Wish me luck! We have $3k invested in the motor and I don't want to trash it but I'm committed at this point. I will be talking to you guys when I am at the point of firing it up, which will be awhile.
Thanks again,
snakeriver_man
Karl Schmidt
Hey snakeriver_man,
I just do not like where the oil ring in in the wrist pin hole using the 5.7 rod.
+ the piston is only about 1.75 inches tall
I have used the 5.2 Crower rod with good results.
snakeriver_man
Thanks all for your info. I will let you know what I end up with.
Pintony, you commented on the 5.7" rods as being to much for the 2.0? this was one of the suggested upgrades when working with Esslinger on building this motor. What would be your concerns? The pistons wrist pins are  deeper in the piston allowing the use of the longer rods. We used a bore scope after assembly and put the piston at TDC and then looked in the combustion chamber to verify we had clearance. I am appreciative of your opinions.
Thanks,
Karl
snakeriver_man@hotmail.com
Karl Schmidt
I use a 500 cfm holly 2300 with a 50cc accelerator pump.
Quote from: snakeriver_man on June 17, 2006, 12:02:40 PM
I have a 2.0 engine that has been enhanced with Esslinger Ported\Polished head and a mild turbo cam set up. We believe to have 10:1 compression rario. I have Wiseco Pistons and 5.7" rods with floating wrist pins. I am looking for the correct CFM carb for street driving. I appreciate any opinions and information. I had talked with Demon about obtaining one of their 2-barrel carbs used on the six-shooter set up they offer but could not purchase an individual carb from them. I'd prefer a new product but I am also asking about what has worked for others.
I appreciate your advice, thanks.
Karl
The 5.7 rod is a bit much for the 2.0????
goodolboydws
You piqued my curiosity, Karl.
I put in 7500 PRM for the 122 cu. in/2000cc engine and even bumping the volumetric efficiency up to 150% of the stock figure, the carb. spec still comes in at slightly under 400cfm.
At a more realistic 6,500rpm and 115% VE figures, it would be 264cfm., which is probably still within the theoretical maximum of what the stock carb. will provide, unless I'm terribly mistaken.
I used to have the formula for determining the maximum cfm of a given carb, based on the throttle plate diameters, but I lost it in a computer crash and haven't found it again yet.
goodolboydws
Check out this site.
It lets you plug in your own numbers to determine the carb CFM required for your engine, based on engine displacement, maximum RPM anticipated and volumetric efficiency.
http://www.csgnetwork.com/cfmcalc.html
snakeriver_man
Karl
Karl Schmidt
