Pinto drive train
Date: 06/29/2018 08:32 am
Date: 01/12/2019 10:19 am
Pinto Watch
Date: 06/22/2019 07:16 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
Date: 02/18/2017 05:55 pm
Date: 12/15/2018 02:21 am
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Date: 04/06/2017 12:13 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
  • Online today: 261
  • Guests: 227
  • Total: 227
2.5 liter engine swap
Started by Pangra74, May 31, 2006, 12:32:06 AM
Pangra74
Thanks for your input. I think will have to find the other wiring harness from the electrical system to the engine. I discovered that in order to use this engine I will HAVE TO configure the computer as it has no distributer hole in the block....can't run regular ignition. This engine is also a lot taller so a hood scoop will be necessary too.
1974 Orange Runabout
CHEAPRACER
The computer needs 12 volts, it's the sensors that are low voltage which is the reason you need multiple grounds to insure an accurate reading.
Quote from: Pangra74 on May 31, 2006, 11:08:24 PM
I know the car is a 12 volt system. My concern is that generally computers run on lower voltage than regular automotive electrical systems. I have the engine/computer harness only. I'll have to get the harness that plugs into the block and see what I can find out.
Joe
If you provide the computer with a good 12 volt plus ( read 13-14 volts) the computer will do all the reconfiguring it needs to lower the voltage to the injectors etc.
Pangra74
Joe
Check out the FAQ section about EFI swaps.
The 2.5 ranger is the same 12 volt system as any car, however, make sure you have "all" the sensors that went with the donor car and a good alternator and battery.
Pangra74
Any of you guys out there have any experience with the distributorless 2.5's? I picked up a 2.5, dual spark plug, distributerless engine from a 2000 Ranger pickup and would like to drop it in my 74 runabout. I have the computer and all sensors. Does the computer module take 12 volts or is there some sort of transformer to lower the voltage? I will have to swap out the oil pan as the Ranger motor has a rear sump. Any answers or ideas would be helpful.
Joe
