Interior Parts
Date: 08/07/2017 03:59 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 02/08/2018 02:26 pm
Date: 05/24/2020 08:19 am
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 04/21/2017 02:03 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
1980 hood needed
Date: 04/23/2020 10:41 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
  • Online today: 529
  • Guests: 372
  • Total: 372
Granada rear end...
Started by junkyard dog, May 22, 2006, 09:44:55 PM
Check out the FAQ section about 8" rears too.
BTW: TT, sorry you can't make it to PA this year.
turbo toy
The Granada rear end is 1/2 inch wider between the spring perch centers and as Bill said,they must be modified and you will need to use the Pinto shock plates on them.You can push the springs over 1/4 inch on each side and make them go,but I highly advise against it.
I have heard the Granada rears are a direct bolt in, but I was told the 67/68 Stang and the Maverick ones were too, and they WERN'T. If it does not have the same style rubber block assy., or the perches are not the same spacing, you will need to do 'something' to bolt it in. The Mav. and the Stang rears were easy to work with.
As far as the driveshaft, you will need to make sure it is the correct length, but there are different length ones out there that are cheaper than having one modified. If you made changes to the drivetrain you need to make sure the driveshaft is the correct length.
http://www.turboford.net/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=040352
junkyard dog
Is this an easy bolt in swap??
Will my driveshaft need to be shortened?
and will the parking brake cables hook up?
I have a C4 and mustang ii driveshaft in the car now.
