Date: 07/08/2017 08:53 pm
Date: 03/21/2017 07:47 pm
Date: 07/13/2018 02:21 pm
Radiator
Date: 05/27/2018 06:07 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 08/13/2017 02:01 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
  • Online today: 394
  • Guests: 349
  • Total: 349
ground effects
Started by streethorse, December 16, 2003, 12:49:53 AM
streethorse
Pretty trick looking wagon. I'll definitely look into the Aerostar dam, I'm almost ready to spray the paint but I really want to get this dam installed before I do that
86 5.0L conv. Stang
85 4x4 F-150
78 Pinto Runabout
98 Ranger
Custom Chopper
pintoperformance
Streethorse,
I am building a 2.3 and right now I have a Wolfverine bracket cam--running a 388cfm Ford 2bbl carb, with a Racer Walsh 2" intake spacer on my intake manifold.  Had to make my own throttle mounts.  ALso using a Hedman header.  The engine has been balanced and blueprinted..
engine has really good throttle response..
Have installed a 8.7 rear end out of a Ford Granada (1977).
New Cragar Wheesl 14" front and 15" rear..
Will be installing a C4 transmission soon..
Mike aka Pintoperformance
pintoperformance
try front air dam from Ford Aerostar van--also try side ground effects from dodge Daytona--I have installed on my 78 Pinto Panel.
Had to do a little trim here and there and had to make mounting tabs  but came out real good. Painted the side ground effects a satin black--the body of the Panel Wagon is Viper Red.. Will post pics as soon as I finish up rest of car.
streethorse
Killer concept, we're thinking on the same lines. I think ground FX on my lil 78 would be wicked trick
86 5.0L conv. Stang
85 4x4 F-150
78 Pinto Runabout
98 Ranger
Custom Chopper
The CobraII airdam should be pretty close. It may require a little trimming, or possibly narrowing(though i doubt it would need that) On a 79-80 i'd look into airdams from the mustang-capri from those years. they're about 6 inches too deep but they have that much you can trim off. i doubt you could use the 'glass extensions for the fenders though that'd put the dam in front of the bumper. Here's my plan for using King Cobra GFX http://www.fordpinto.com/yabbse/attachments/final_concept.jpg
I did what Crazyhorse said. I compared different cars about the same size as the Pinto. I came up with the front air dam from a Honda  :o Civic. It was actually the bumper cover. I cut it almost in half. I was going to use a rear bumper cover from a Dodge Daytona as a roll pan. Unfortunately I rolled my wagon.  ::)
Anyway heres a thread that shows the dam pretty good.
http://www.fordpinto.com/yabbse/index.php?board=6;action=display;threadid=81
streethorse
I was thinking maybe Mustang II but I don't know if it would bolt up to the Pinto's front fenders. I'm just trying to find any piece that will go under the bumper and cover the lower core support, I really wanted an air dam but it's not like these lil horses get much attention from aftermarket parts builders
86 5.0L conv. Stang
85 4x4 F-150
78 Pinto Runabout
98 Ranger
Custom Chopper
I've seen late 80's Mustang GT GFX cut down for a Pinto, you could check out other cars in the Pinto's class, check the distance from wheel opening to opening. if it's longer you can always cut it down. Personally I'd avoid using anything that's shorter, as adding length is tricky AND expensive
streethorse
I have been considering the turbo. I also want to keep my A/C. I live in the South we don't have winter here, not sure how that will work. also not that familiar with doing the turbo mod. I know you have to drop comp. ratio, new cam, all that
86 5.0L conv. Stang
85 4x4 F-150
78 Pinto Runabout
98 Ranger
Custom Chopper
If you have the motor apart you might want to think about  a turbo.............. ;D
streethorse
old horse, new rules. I am currently in search of ground effects to fit my 78 Pinto Run About. It's a great lil car A/C, full rear glass, 4spd ( prob go to 5spd when engine gets built). staying w/ 2.3 want to show these kids how to build an old school tuner. Any help or suggestions on this problem would be greatly appreciated. I took the car down a year ago now I am dying to get it together again
86 5.0L conv. Stang
85 4x4 F-150
78 Pinto Runabout
98 Ranger
Custom Chopper
