Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 06/30/2018 09:48 am
Date: 04/25/2017 12:17 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 01/28/2017 12:30 pm
Date: 07/17/2018 09:49 pm
  • Online today: 131
  • Guests: 101
  • Total: 101
Headgasket!!!!!
Started by 77turbopinto, April 15, 2006, 03:44:26 PM
I do all the light stuff myself, but Paul is very handy when the extra body is needed. I spend time at his place too working on his toys, works out very well.
Taking the pinto out today to go see some family.
I have heard so much from both sides of the re-torque issue. I think I need to re-do the valve cover gasket, so I might do it. What is the correct way to do it, I have heard many opinions on this, but what is yours?
turbo toy
Bill,If you're not using torque to yield head head bolts,be sure and retorque the head after several complete heat cycles.Put Paul back to work.
Took it out this evening. Seems to run much smoother than it did before the gasket went, I suspect the injector might be helping. I need to re-check the plugs and re-set the timing, but she seems ready to go (for now).
I will get a pic of the gasket.
On thursday the headgasket went on the turbo pinto. 48 hours later (not all spent on the car), a bunch of parts and a few band-aids it is back on the road.  Strange noise it made, sounded like a cam follower bouncing around in it, but it was only the gasket. The gasket now has a 1/2" notch cut between 1 and 2. While I was in there I noticed that the valves in #3 had some evidence of exrta heat, but not too bad, and it had good comp. in that one before the head was pulled, so I changed the injector for it and did all the o-rings on the rest of them.
