1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 07/11/2023 11:39 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
hood for a 79-80
Date: 11/30/2018 10:55 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 11/12/2020 08:28 pm
Date: 02/16/2019 10:46 am
KYB shocks
Date: 02/08/2017 07:09 pm
  • Online today: 107
  • Guests: 110
  • Total: 110
Help on engine that won't stay running
Started by Smalldisplacement, April 05, 2006, 09:32:33 PM
Smalldisplacement
Well I checked the Ballast resistor I'm getting 1 ohm resistance I tried to buy one and the replacement is no where near the same creature, we checked out a mustangs resistor and it's a little smaller and has 1 ohm resistance also. I pulled the fuel filter and it looks new (I've only had this car a year) I cranked it over with the filter out and it pumped out pretty good, the fuel looked clean also. I changed the fuel cap to a locking style cap, so it's new as well, but I ran the car without the cap to make sure the tank was venting. I let the car sit and idle for half an hour without any problems then I drove it down the street about half a mile and it died again. When it was dying I tried to give it fuel but it seems to be starving for it so I'm not sure if it's vaporizing or what. and why just start now after driving fine for a year. I checked the fuel lines and I did not see any leaks or feel any hot lines and I also put a can of sea foam in the tank. MAN I am baffled. I'm I missing something!! Thanks again for all your info. al
fast34
I would also check your fuel cap to be sure it's venting.  Since you still have spark that is.
goodolboydws
Alternately, for anyone with a simlar sounding problem,  if it IS a failing module or a problem with insufficient heat conducting compound between the base of the TFI ignition module and the metal body of the distributor, and is a heat related problem, (something that also happened to me on a Lynx of this vintage) you can easily diagnose it this way:
Run the engine IN YOUR DRIVEWAY, with the radiator blocked enouh so that the engine really gets warmed up quickly and completely and see if that causes the engine to die.
If it DOES, immediately pour some cold water over ONLY the module or use a garden hose to let a trickle of cold water run over it continuously, and see it the engine starts up after doing this.
When you're doing this, it's important to try to keep the water away from the rest of the engine as much as possible,  or the test will be less valid, and you'll also be likely to get a face full of steam.
goodolboydws
This really sounds as if it is a partially clogged fuel filter or a possibly a fuel sticking inlet valve (needle valve), where the needle sometimes sticks in the closed position.
I've had both of these problems with various carbureted cars, and when it's a fuel FILTER situation, the engine speed range at which there is NO problem can actually be the biggest clue, as the engine will frequently be able to run at idle or low speeds/low loads, but die when it's under a heavier load or in any situation that demands a greater fuel flow than can make it through the clog.
I'd check the larger fuel filter, not the carburetor inlet screen.  If I remember correctly, most of the later Pintos had a fairly substantial paper element one.
With the inlet needle situation, (blocking fuel flow) the problem tends to be less predictable and is not dependent on engine speeds.
Smalldisplacement
Copy, I connected an in-line spark indicator on a plug and I still have spark when the eng is warm and won't start. After work I'll try to check the fuel flow pressure from the pump. Still seems odd that the pump would stop working when the engine heats up. Another thing, I started the car up and let it sit and Idle for about 20 min and it never shut off. Seems the problem is when the car is driving and or applying more fuel to the warm engine while driving. Tranny fluids are good. Still Baffling. Thanks for all the input!! You guys are really helpful. al
fast34
When it does this, you need to immediately stop, open hood, pull coil wire, and check for spark.  This will tell you if it is ignition related or not.  That is where I would start.  Since you have replaced the most frequently problem causers, I would keep a test light on hand to check to be sure you have voltage at coil at this time also. Let us all know what you find.
bro
If vandal has put sugar or soap in your gas tank I have heard of this being the result.  If water has built up in tank and become an issue (especially with season warming up) try some methyl hydrate or such.
Otherwise, I have experienced something similar in the past and I'm not sure exactly what the answer was.  Similar experiences with different make and model cars have shown themselves to be faulty sticking starter solenoid/relay.  Fairly easy to test and cheap to replace.
When it happened with Pinto once I think it related more to coolant thermostat that stuck closed, allowed engine temp to rise enough to trip something that protects engine.  After attending to cooling system and installing always-open thermostat I suffered a blown head gasket.  Not cheap.
In all the above experiences the car would start when cold, drive without issues but after parking briefly I couldn't restart until after waiting 20-30 mins.  Jump start wouldn't help.
I don't profess to know the answer but I do know the question. :sorry:
Smalldisplacement
Yeah, it totally dies. when it does I can crank it over and i get all the dash lights but it won't fire up until it cools a bit. I drained the tank last year when I pulled the tank float and x-mitter. I'll change the fuel filter in the carb and see what that does. I just figured it might be electric because my civic was doing the same thing and it was the main relay that was bad. it would stay open when it was hot and close when it cooled a bit. Thanks again guys!! I'll write again with results.al
DragonWagon
Yeah, sounds fuel related, vapor lock or something, not electrical since you say it runs fine after sitting a bit. Wouldn't think there'd be an intermittent distributor problem that shows up every 10 miles. Usually when the electronic ignition goes, it's very intermittent or it totally goes out.
Need more info on exactly what it's doing/not doing...
1976 mpg Wagon. The start of it all.
1977 Cruising Wagon, to be turboed.
1979 glass hatchback. No motor atm.
1980 wagon parts car.
Things I would check:
Fuel filter and pump. Junk in the tank or carb.  Clogged vent to the tank.
73pintogeek
Hi Al,
Do you lose all power or just the ignition? Check to see if you have a ballast resistor mounted somewhere (usually beige ceramic long piece with a flat plug at each end) just a thought...if they get hot and the spring is bad it will seperate and cut power to the ignition...
73pintogeek
A bad day workin` on my Pinto is better than a good day at work!
Smalldisplacement
Smalldisplacement
This is on a 76 pinto wagon 2300. Starts up great and runs fine for at least 10 miles then loses power and shuts off, after letting it cool for about half an hour it starts right back up for another couple of miles then repeats the process. I have changed the electronic ignition module and the coil. The plug wires and plugs look good and the cap and rotor are new. Could it be the magnetic pickup in the distributer? Any info would help. Thanks agin, al. ???
