Date: 07/20/2018 03:00 pm
Date: 04/21/2017 02:03 pm
Date: 10/26/2020 03:24 pm
Date: 02/18/2017 05:55 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 01/19/2021 03:56 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 10/01/2020 02:00 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 584
  • Guests: 521
  • Total: 521
Transmission question
Started by BBfox, April 05, 2006, 10:43:37 AM
BBfox
sounds like what i have laying arroud wont work, thanks for the input though, i believe my motors compression is shot anyway and i think i rather find somehting else than put any money in the 2.8, im thinkin 2.3 or maby a v8 swap, i have a complete HO EFI 5.0 setup, how cool would that be? id probably have to fabricate a shorter upper intake though
wagonmaster
The standard trans for the 4-cyl bolts on going through from the inside of the bellhousing into the transmiaaion. Some Capri 2.6L/2.8L V6 bellhousings may accomodate this configuration. You might try going this route. The V6 in the Mstg II bolted from the outside into the bellhousing, as most other Ford products do, and the bolt pattern is significantly different. A C-4 auto will bolt easily to the 2.8 using the Pinto/Mstg II 2.8 C-4 bellhousing. As far as any AODs go, you may want to check if any of the Ranger/Bronco II transmissions would work for you.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
krazi
If I remember correctly, the bellhousings are different. the top two holes on the bellhousing are closer on the 2300 and farther apart on the 2800.
krazi
yeah, I'm Krazi!
BBfox
will a tranny off a 2.3 bolt up to a 2.8?
I have 2 good trannys for a 2.3, a 4 speed manual and an overdrive auto i wana do something with. maby i should just switch to a 2.3
