door sills
Date: 03/14/2020 03:20 pm
Date: 02/21/2017 06:29 am
Date: 09/05/2018 06:30 pm
Date: 08/01/2023 06:53 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 08/17/2022 06:27 pm
Date: 01/28/2021 03:49 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
  • Online today: 178
Wagon sway bar
Started by hoots, March 14, 2006, 07:10:00 PM
Those are vibration/torque dampers, kind of like the big thing hanging off the back of the tranny.
I have seen them only on the wagons.
Hello eatmydust,
Parts YES! But I have probally 200 NOS Pinto parts that I do not even know what they are for...
Mostly because I only mess with the 1971-73 Pinto.
Beyond that I'm not too interested.
I still think the 74-UP Pinto's are COOL 8) though....
My son loves the 79-80 Pinto???
Which works out great!
No competition over Parts. ;D
eatmydust
Not sure what they are for . . . they're factory OR put on before I got it.  Pintony, your'e a part guy, don't you know what they are???  LOL
eatmydust
The ribbing I take for owning a Pinto!  Jeez!!
 :what: The heck are those big blocks for?
in the top photo just behind the black arrow attached to the leaf spring???
eatmydust
Here is a pic of how my sway bar mounts to the axel.     The air shocks are what makes this system work best, in my opinion.
eatmydust :fastcar:
wagonmaster
The Mstg II shocks will not fit a wagon without modification. The Mstg II upper mount is a stud type like the Pinto sedan/h.b., but the wagon uses a cross pin with two bolts that go into the body and a stud at the bottom.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
hoots
hey 'eatmydust', how much for your setup? can you post a pic or two?
The easy way to install one with stock ford parts is to use the Mustang II rear bar. You will need the shock plates, end link brackets, and you will need the shocks for the MII as well.
I don't recamend installing a rear bar without a beefy front bar to help balance the car. If you only install the rear bar with no front one, it can cause the back of the car to fight the front for control (oversteer).
This MII donated lots of stuff to my turbo pinto.
eatmydust
No, technically they didn't come with rear sways.  I used the rear sway bar off of a Bronco II.  Then got air shocks, separated the lines, so they didn't feed off of each other, with some cutting, a little bit of bending, some heating (fabrication), it worked.  I know, now my pinto is more fun at turns.  Stiffening up the rear end really helped me take turns at speed.
p.s.  Do you want to buy my setup?  (Air shocks, tubes, sway bar & pictures on how to mount it).  I'm thinking about switching mine out with a 280Z independent rear end.
eatmydust
hoots
Did the wagons come with a rear swaybar, haven't been able to find one.  :look:
One a side note; no shortage of smileys to choose from. :showback:
