Date: 09/01/2017 11:58 am
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 12/26/2016 04:29 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 11/05/2016 09:03 pm
Date: 04/14/2023 06:15 am
  • Online today: 266
  • Guests: 282
  • Total: 282
12v while cranking
Started by hoots, March 13, 2006, 09:33:34 PM
dirt track demon
So does the factory ford duraspark module, and it uses the wire that triggers the starter solenoid. If this is what you are worried about, quit worrying, all that wire does is tell the box to change the timing a little to make it easier to start. It doesn't matter if this voltage drops a little, I dont care where you pull your juice from, when you crank that starter the whole system is going to drop.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
hoots
The MSD 6a requires 12v ignition source, other than Battery, that is also on during the start cycle. MSD tech says not to hook to alternator. I'm thinking a relay that is triggered by the 1 wire alt.
CHEAPRACER
Quote from: fast34 on March 13, 2006, 09:53:50 PM
What are you trying to power with this source??  The wire that activates the solenoid should have this power as well as the positive side of the coil, assuming your battery will supply it, while under cranking load.
Some ignitions use 6 volts to the coil with a resister built in somewhere in the wiring, it won't hit 12 until you crank the engine, the wire I found was before the resister.
CHEAPRACER
Man I should have taken notes,  There is 1 wire coming off my steering column switch or the back of the fuse block on my 74 that I used but it took awhile to find it. (I just looked and I can't even figure out what I did) I used a test light and disconnected the starter solenoid to keep the engine from turning over, probe each wire until you find the one that stays on, I also used a relay switch to take the load instead of directly connecting my ECU to the 12v source not knowing how much amps it would take.
dirt track demon
Couldn't you use a 2nd solenoid, use the feed that drops power to activate the 2nd solenoid that is a direct feed from your battery to what you are trying to power.
The PINTO!!
fast34
hoots
Any ideas on how to get a 12v source while cranking (starting) the engine? All my switched 12v sources drop power when I am starting the engine. ???
