1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 08/13/2018 02:46 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 07/08/2017 08:53 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
NOS Sedan decklid
Date: 10/23/2019 11:51 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
  • Online today: 515
  • Guests: 404
  • Total: 404
Similar problem returns: slight bog down & backfiring when revving
Started by r4pinto, March 05, 2006, 09:26:09 PM
fast34
You have not stated whether or not it has any spark at the plugs?
It is pointed toards the number one terminal. Even traced the wires just to make sure. I aprreciate the tips, but the problem is lying elsewhere as the belt is on properly, the marks line up perfectly & the rotor is pointing towards the number one terminal. Next tip please. I want this thing running soon as my dad is tired of looking at it in his driveway. :(
fast34
I would check to be sure that your AUX shaft is still in time.  Pull dist. cap and set at top dead center and see if rotor is pointing at #1 terminal.
I did twice & they line up perfectly, & after I couldnt get it started I rechecked it & the marks are still right on the money.
Gaslight
Did you spin the motor one full revolution after you installed the timing belt?  Just to make sure the timing marks still line up after the belt was installed?
Jake
Pulled of the timing cover & checked the cam timing & found out it was off by about a tooth. Went ahead & replaced the timing belt since it was all cracked. but now the car won't start at all.  I sprayed some starter fluid in the carb to get it started & it would attempt to start but would not stay running. I then pulled the plugs & they were wet with gas, as well as the electrodes being a little darker than I would like. Does this sound like the enrichment screw being out?
SOMEBODY HELP ME OUT HERE!!! I"M GETTING TIRED OF NO REPLIES!
77turbopinto: The old egr valve was junk the rubber was all cracked up & the velve itself was all plugged up. The timing belt was rather loose all over no matter where I went to check it. I know some belt deflection is normal, but it seemed quite excessive. Before when I was having a similar problem I changed the spark plugs & rebuilt the carb. The choke & the rest of the carb is set according to specs, but I'm not too sure about the enrichment screw position. The plugs were fouling out a bit so I thought it's dunping too much fuel. Just not too sure what way to turn the screw & how much.
Gaslight
Put a timing gun on the engine and with it running rev the motor and keep the gun on the crankshaft marks.  See if the timing is advancing when you rev the engine.  Also is your car an auto or a manual?
Jake
What side of the belt was it loose on. It depends on where the pulleys stop as to which way the tension is on the belt, that's why it needs to be set to the right spot before you set the tension. When the car is running it will keep tension and correct alignment (to a point) even if a little loose.
It was running fine before you replaced the egr? Do you still have the old egr? If so, I would put it back on and see what it does, but they tend to effect the tune only if they leak vac, or exhaust. I know you can just block off the holes on the intake (adapter) and vac and the car normally runs fine.
What did you do to fix it before?
Well, as you all know I have been trying to figure out why my car would bog down & backfire when revving & accelerating. I fixed the problem under accelerating & to a point while revving, but the problem has returned somewhat.
It ran good for a little bit, but after I replaced a bad egr valve that whas shot beyond belief with a NOS unit off ebay the problem has seemed to return.  I thought I might need to adjust the enrivhment screw, but I am not sure how much & what way to turn it to adjust it. I do have the 2.3 with the 5200 carb on it.
I was doing some maintenence on it today so I pulled the timing cover off & the belt did seem quite a bit loose so I'm assuming that might have been some of the problem.
What else do i need to check? Vac lines all good, good compression across the engine, so I'm a bit confused. It runs good for a bit but would act up after a while.
