Date: 09/02/2021 08:21 am
Date: 07/08/2022 11:51 pm
Date: 07/17/2019 05:23 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Date: 12/20/2016 10:47 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
V8 rear end
Date: 04/12/2018 10:57 am
71-73 Hood
Date: 12/07/2018 06:22 pm
  • Online today: 1,090
  • Guests: 136
  • Total: 136
Questiond regarding 2.3 motor mounts
Started by osiyo59, March 04, 2006, 10:59:32 PM
osiyo59
As always, Bill and Tony come through once again! Thanks Guys...Rob
Rick posted this link to his Pinto 2.3 conversion.
http://www.angelfire.com/nv2/rickscarstuff/Pinto.html
Shows a good shot of the 2.3 motor mount welded into the early frame.
I have heard that cutting the stock ones off the car and installing ones from a 2.3 pinto, and using the stock 2.3 pinto engine mount brackets and mounts is the best way to go. Knowing what is involved, I too would go that route if I were to do that swap.
Make sure that you mark the location of the tranny so you can use it to line up the engine, as well as set the pinon angle correctly with the 2.3. From what I understand the bolt holes for the frame mounts are not in your car, so you will have to either drill them or weld in the brackets. If the "sub-frames" are the same, some good measurements should let you place the holes correctly.
Don't forget to use the pinto oil pan and pick up tube.
osiyo59
So when it comes to putting the 2.3 into a 72, how should I tackle the motor mounts? Cut the old ons and move them or just fabricate new ones? The motor, as I stated in an earlier post, is out of a 94 Ranger. Maybe I should cut the mounts out of the Ranger and use those. Suggestiions?...Rob
