Date: 11/08/2019 10:01 am
SVO SWAP
Date: 03/15/2018 03:12 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 11/02/2019 10:25 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 02/28/2018 09:37 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
  • Online today: 506
  • Guests: 236
  • Total: 236
Fan's on motors.
Started by Nevada Pinto, March 02, 2006, 11:08:54 AM
johnsonracing
Plastic is the way to go.I drove about thirty demos with Pintos,with out fans, before starting to run a fan.If your radiator is getting that close,the pump is going to put a hole in your radiator anyway.When you run a fan,the motor is a least cool when you do loose your coolant.I always weld a 1/2" washer inside my thermostat housing to replace the thermostat.A 9/16" opening is perfect.(measure the opening on washer)
demoiowa89r
I either run no fan or an eletric fan.   Matt  89r
Proud owner of a 74 pinto sedan. NON-DERBY
a 78 hatch. derby car.
a 73 wagon. derby car.
CUTWHAT
WE RUN PLASTIC FANS SO IF THE DO HIT THE RAD THEY EAT THIER SELF UP AND NOT CAUSE YOU TOSE A BELT!!!! :surprised:
Tude
i always take my fans off everything i run becouse its just one more thing that the radiator and hit, and if one of the blades breaks it really throws the ballence of the car off it will feel about like haveing a bent rim running 30 mph sitting still -so to speak
custom fit hammered and bent
Nevada Pinto
Fan's....Do you run with them or with out them....I have in the past ran with out them...And I'm thinking this year to try to run one...A buddy of mine runs the original one but he cuts it down a little....
