1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Date: 12/31/2017 11:14 pm
Date: 02/05/2020 11:06 am
Date: 09/17/2024 12:35 pm
Hatch needed
Date: 09/10/2017 09:16 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
parts needed
Date: 02/20/2017 07:58 am
  • Total Topics: 16,268
  • Online today: 204
  • Guests: 60
  • Total: 60
8" rearend out of a 64 Comet
Started by osiyo59, March 01, 2006, 06:36:57 PM
Hey, that's how I did mine!!!!! It works great.
osiyo59
I'll Just make it fit! Thanks Tony and others!
turbo toy
WELL SHUX,seems like I struck out altogether on this one.I was going from memory from years ago when I put a 65 Mustang 8 inch in my 71 Pinto.I am certain that I bolted it in without having to modify anything,but I don't remember which shock plates I used.Sorry for the wrong info.I promise to do better next time. :accident:
The early Pinto did have the rubber.
But the tit that sticks up into the pearch was round. the later Pinto had the oval tit. BUT both had the rubber mount between plates.
osiyo59
Well, First off, Sorry for call you Turbo "boy".  :sorry: No disrespect intended. Second; fortunately my wagon is a 72 so I'm assuming from what I have read here, the 64 8" will fit just fine. Thanks to both of you for the help....Rob 8)
turbo toy
I stand corrected.You are right Bill,It is a direct bolt in for the cars that don't have the rubber cushions.I don't know what year they started with the rubber,But the 71 through 73 didn't have it.Maybe someone can post the year they made the change. :sorry:
Well, not exactly, maybe.
I can't speak for the older pintos, but it will not fit in any of the pintos I have had (77 and newer). It might be ok in the older pintos, but the pintos that have the block and rubber inserts with the oval holes will not direct bolt into any of the older rear perches. At the very least you will need the shock plates from the donor car, or open the holes on the perches to use the blocks.
The 4 lug bolt pattern might be different too (4 on 4.5").
TT is correct, the 67+up stang is wider. I have a v8 68 rear and it took a little work, but not bad. I hope to find an older one someday.
turbo toy
osiyo59
Thanks Turbo boy! That is exactly what I wanted to hear!...Rob
turbo toy
Yes.The Comet,Falcon and Mustang 8 inch rears through 1966 are a direct bolt in with the possible exception of the rear U joint.In 1967 they went to a little wider rear.They will still fit,but the spring perches are wider center to center and require a little work.
osiyo59
Anyone know if an 8" out of a 64 Mercury Comet wil bolt right in to a 72 Wagon? Any thoughts?...Rob
