Date: 07/30/2020 11:45 am
postal pinto
Date: 06/03/2020 09:31 am
77 pinto
Date: 08/22/2017 06:31 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 11/11/2019 04:49 pm
Date: 05/19/2018 04:56 pm
Date: 02/18/2017 04:44 pm
Date: 04/15/2017 05:14 pm
Date: 01/10/2022 03:41 pm
  • Online today: 344
tools for the job youve made
Started by Tude, February 24, 2006, 12:38:43 AM
Tude
this is the stand i made im sure one can be made for the 8 inch also
custom fit hammered and bent
Tude
just the other day i needed to put a set of 9inch gears together and was tired of it sitting funny so what i did was cut an old rearends axles off, cut the back cover off , then i made a pair of legs with a pipe that slid into the axle tubes(what remained) then cut 2 holes,welded 2 washers with nuts over the holes and treaded bolts to lock them in place to keep it from spinning
i think it weighs about 20lbs all together and works awsome just wish the legs were taller
dirt track demon
Quote from: hvyeqop69 on February 24, 2006, 06:11:41 PM
Im glad you brought up this subject, I need to come up with a tool if possible that can break loose those old rusty brakes from the drum without taking off the tire and wheel and sledge hammering the drum in 100 degree heat in 6 foot of weeds.
Something that all I have to do is jack up the car to get the wheel off the ground and then attach it or whatever to the wheel, studs,or rim or tire?
Got any ideas?
1/4 stick of dynamite. Go ahead and laugh but it worked.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
johnsonracing
;D    Secret,and old log roller works great for bending fenders and sheetmetal.Just hook it under the fender with the pivot on top of the fender.Lift and walla!-you just staightened your fender or what ever you're trying to staighten.
            Try it, you might like it.
bear1838
best one i have made is from old tortion bar from a old big block chrysler car just get it out and grind down one end they work great for pry bars and don't have to worry about them breaking eather
hvyeqop69
Got any ideas?
Drive the good ones. Derby the rest!
I buy Pinto Spindles.
demoiowa89r
I made a 5 foot long prybar from a axle. I'm not sure what it was out of but i flattened the end and cut a v slit it works really good. i also made a hammer/axe. On 1 side is a sledge hammer head and the other an axe blade. It helps when your beating out the sheet metal and need the kinda cut it loose. Matt   89r    :accident:
Proud owner of a 74 pinto sedan. NON-DERBY
a 78 hatch. derby car.
a 73 wagon. derby car.
Gaslight
Metal stands at different hieghts for the car to sit on with the tires on.  Stands that bolt to the lugstuds and hold the car up in the air.  Wrenches with so odd angles.
There is more thats just off the top off my head.
Jake
Tude
what all tools have you made that help you out at the track or in the shop when your working on the cars
ive made several sledges with metal handles i broke about 4 in one summer so then i welded a solid pipe on on and its still working great
for my 302s i put a small socket on a old extention and taped it up good so that if i had to pull the dist i can turn the oil pump but i cant rember what size it is off the top of my head(thats the only thing i use it for )
