Date: 09/22/2020 11:33 pm
Date: 05/19/2018 04:56 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Date: 04/07/2021 06:12 pm
door sills
Date: 03/14/2020 03:20 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
  • Online today: 148
  • Guests: 134
  • Total: 134
engine swap
Started by haj81, February 22, 2006, 07:10:33 AM
haj81
pintony;
any luck finding that cam and followers?
jay
So what you need is a cam and rockers.
I wil take a look and see what I have about...
haj81
the reason i'm looking for a head is because i fried the cam, and took out the followers with it.  a new cam and followers cost more than a used motor cost.  the reason i'm looking for the head is so i can get the followers together with their matching cam lobe respectively.
jay
haj81@aol.com
Quote from: haj81 on February 22, 2006, 07:10:33 AM
tough time finding 3 tower head, so i'm considering replacing 2.0 with a 2.3. Will the 2.3 bolt up to a 2.0 bell, and are the front mounts the same?  What other problems can I expect?
jay
Hello Haj81,
The 2.3 is longer 3-4" so you may want to re-consider????
I have many 2.0 cylinder heads.
What is wrong with the one you have?
Are you looking for a re-built head or just a core for rebuild?
Gaslight
YUMA!  Bummer I was just at PIR for a race.  I am only in Ventura County California.  Its only about a 6 hour drive from Yuma.
250.00 with all the accesories.  Shipping or pickup would be up to you.  I have no way to crate it.
Jake
haj81
i live in yuma az.  would consider paying x amount of freight
Gaslight
Jay,
  Where you located.  I am getting ready to pull out a perfectly good running 2.3 and auto trans from my 74.
Jake
Yes, with adapting the dowel pins it will bolt up to your tranny. No, you will need to cut off the welded on frame side engine mount brakets and install ones from a 2.3 along with the mounts themselves. The only "problem" will be locating the frame brakets correctly to keep the correct pinion angle, as the tranny will help locate the engine fron to back. Take good and detailed measurments.
haj81
jay
