Hatch needed
Date: 09/10/2017 09:16 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
Date: 08/03/2017 07:40 pm
Date: 05/19/2018 04:56 pm
Date: 05/28/2017 03:20 pm
  • Online today: 536
  • Guests: 281
  • Total: 281
Need advice on dealing with rear end howl..
Started by powderblue76, February 17, 2006, 06:16:48 PM
3.90 gears for a ford 8"?????
There is no such gear for a Ford 8" rear.
Quote from: ford guy on March 23, 2006, 12:06:04 PM
if you want stock width  you can try a 89 mustang lx [4 cylinder]
ok 2300 cc automatic car-------[why ]???????? limited slip
and 3:73 gear
if me i would make it a posi or a locker.
i just put 1 under my 84 t bird 302. bolt in
you say you can fab
then get a 8 inch  locker  3:90 gears
like you said  make your own  brackets-------by the way dont forget
3 degree neg on the  pinion yoke  as you re weld your new spring perches if you use springs. wayne
:what:.......   Its realy hard to understand just what the heck you are saying.
ford guy
and 3:73 gear
you say you can fab
fast34
86's will not bolt right in.....you need one from a 74 to a 78...
powderblue76
Great!
There is now a use for that '86 M2 I referred to a few days ago.
More later.
Thanks again guys.
powderblue76
Which year M2 would have a chance of bolting in?
fast34
Agree 77turbo, go with the 8 inch.  Try to find one out of a must. 2 and maybe you'll get one with the rear sway bar.. They handle so much better with that little baby. Yours is probably got worn out pinion bearings, a common problem with the 6.75.
Either turn up the stereo, or replace the rear. The tools and gears are way too pricey. If you need just a cheap and easy rear, and are planning to stay stock, the stock 6.75's are out there.
Quote from: Tude on February 18, 2006, 12:33:19 AM
Put a 9 inch in it. They are very commen to find parts for
I don't know about the 9 inch, but the 8"s are fairly easy to find (for now). Ford never put the 9" in a pinto or any other car that would make it an easy "bolt in" (any that fit would have been modified to fit). Don't plan on seeing a 9" cheap either.
The easy way to tell a 8" from a 9": put a 6" extension on a deep socket. If you can put it straight on all the meatball to housing nuts, it is an 8", if not, it's a 9". (or just by the price)
Tude
custom fit hammered and bent
73pintogeek
Hi...
I agree with Bill...find another good rear end and do the swap...
We used to pack `em with white lead when I was a kid and drive the crap out of `em `til they "crapped" out!
Ahhh...the good `ol daze! :amazed:
A bad day workin` on my Pinto is better than a good day at work!
billnall
Change the whole rear end, easier & faster & cheaper.
Do a search on this sight, there is a lot of different rear ends that will fit.
Ford Parts Man
powderblue76
Yeehaw!
The rear end in my "new" Pinto is howling   :(  when I am accelerating, so...
What do you all recommend, a different rear, or getting a gear job done?
I have wanted to do a gear job myself, mainly so I have to buy more tools.. ;D
If a different rear, what will fit?
Just Pintos, or will other cars work?
I can do fabrication, so making and installing mounts in no problem.
I think I have 2.79 gears.
Thanks,
