Bumpers
Date: 07/06/2018 04:47 pm
Date: 04/07/2021 06:12 pm
Date: 02/08/2018 02:26 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
  • Online today: 1,106
  • Guests: 197
  • Total: 197
Crossover help!
Started by Gaslight, February 15, 2006, 07:45:36 AM
You should not need an assy., just the pedals and the mount for the clutch arm.
The mannual brake, and power brake have different pedals, but they will interchange, they just have different pivot points. Might take a different frame.
The clutch pedal pivot bolts to the stock frame with three nuts and a bolt-plate on the left side. Un-bolt the brake arm and install the 4spd one, easy.
I don't know if the pedals are the same, but you can have your local ford dealer see if they have the same part #'s.
Gaslight
  I am looking for a 4 speed pedal assembly for my 74 Pinto.  I have run into a guy with an assembly from a 74 Mustang.  What are the chances that the assembly is a crossover and are the same items?
Jake
