79 pinto steering column
Date: 08/18/2018 02:00 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 11/29/2018 10:26 am
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
Date: 11/05/2016 09:03 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
  • Online today: 583
  • Guests: 247
  • Total: 247
Pinto/MII front spring part #'s: 4cyl / V6 / V8
Started by gearhead440, January 18, 2006, 11:19:19 AM
datazz
Hey,Gearhead 440.I really appreciate the info. You saved me some work.Thanks a lot.
gearhead440
Datazz,
According to the info that I have found, the SW with 2.3 engine uses the same springs w and w/o air so you should be ok using what you have.  The MII 302 springs w/o AC would also work but they will be a bit stiffer than what you have now.
datazz
Does anybody else know whether I need to change my front springs to the mustang II ones?Thanks.
datazz
Hey,Pintony.I have an 80 pinto wagon with a 2.3 ,4speed with no air.Do I need to change my front springs? I just bought a 78 mustang II off the ebay with a 302 4 speed.(DONOR).I'm planning on using the front and rear sway bars but I didn't know if I needed the front springs or not.Thanks.
gearhead440
gearhead440
I did some cross referencing between Napa and Advance Auto Parts websites and part numbers and came up the with following table that may be useful.  I wiil be using Advance Part Number 8542 for my V8 swap :).  There might be typos...
Application                             NAPA #           Advance Auto Parts # (TRW)
(80) Pinto 4cyl w/o A/C                2773041         8578
(80) Pinto 4cyl w/ A/C                     2773042         8576
(77) Pinto 6cyl  SW w/o A/C           2773042         8576
(80) Pinto 4cyl S/W w/ A/C           2773037         8542
(76) MII 4cyl w/o A/C                  2773036         8558
(78) MII V6 w/ A/C                     2773039         8582
(78) MII V8 w/o A/C                     2773039         8582
(78) MII V8 w/ A/C                      2773038         8556
Quote from: gearhead440 on January 18, 2006, 11:19:19 AM
I've been searching for the correct spring for a 302 swap.  Fat Rodder on Ebay sells 350lb and 425lb.  Racer Walsh also sells a variety of spring rates.  Advance Auto parts might be able to get MII springs but they said it could take a few weeks even if they are able to locate them.  Hoots has used 450lb springs for his wagon swap.  Any input is greatly appreciated!  Thanks.
Hello  gearhead440,
Springs from a Pinto W/2.3 & A/C should be just about right for a V8 swap.
gearhead440
I've been searching for the correct spring for a 302 swap.  Fat Rodder on Ebay sells 350lb and 425lb.  Racer Walsh also sells a variety of spring rates.  See below information for part numbers for sedans, station wagons, 4 cylinders, V6 and V8 applications.
