Date: 01/24/2021 07:54 pm
Date: 09/06/2020 01:57 am
Rare parts for sale
Date: 09/10/2018 08:38 am
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
v8 springs
Date: 05/07/2017 04:46 pm
Bumpers
Date: 07/06/2018 04:47 pm
Date: 08/03/2017 07:40 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
  • Online today: 1,293
  • Guests: 1050
  • Total: 1050
W
Started by whitepony, January 13, 2006, 12:56:52 PM
fast34
Yeah I forget that not all of us do the work on our own cars, and labor is CRAZY!!  I have a c-3 auto and just changed to an 8" with 3.00.  When the c-3 dies (I'm sure will be soon), I will put in the T-5  5 speed  :D
Hey Fast: Do you have a a/t or m/t? That is the difference between 80 and 90, depending on the gears. Could have the 2.73's too, maybe.
I don't know what he did, but $1000. is easy to drop on that if you have someone else pull it and re-install it, plus tax.
fast34
Gearing has alot to do withit too.  By looking at your photo by your name, it looks like a 77 or 78, and probably has 3.18 gears in a 6 3/4".  I agree with 79panel, what was the condition of the lower end,how many miles on it??  How did you spend $1000 on the head and still leave it stock????  Also, are you in this for power or fuel economy--- Usually you can't have both.  Carb upgrade, (holley 350), camshaft, hedder,and 2 inch exhaust with free flowing muffler, and then you are talking!!!  And if you other guys can't get more than 70 out of your stock Pinto, then it also has something seriously wrong with it too!!! My stock 2300 runs 80-90 if I want it, down I-5 all day long.  I can pull any hill from Southern OR over Siskiyou Summit at the posted speed and it at least a 5 degree climb for many miles.  Just for your info. Ha Ha Ha LOL. :laugh:
One tooth off is a lot. If your car has more power now than before, chances are it is ok, but worth a look.
I said before, when stock these cars are slow, the 2.3 has about 85 hp, and the cars is about 2400lbs. Keep in mind if yours has an a/t, there goes about 10%. My saturn is about the same weight, has 125hp, and stock is not a ball of fire even with the 5spd. My stock pinto will do about 80, if given the time and room on flat ground. A performance cam, bigger (cheap too) carb, and a bigger exhaust, and you can pep them up quite a bit. Keeping it stock will give people more time to envy you when you drive it.
whitepony
So you are saying that it could be the cam timing belt. I am open to any suggestions! My former youth pastor has decided to give me his nissan sentra......
I don't want to give up my beloved car!!!! :'(
glory hallelujah! What a sweet pinto!!
wagonmaster
Some thoughts on your situation. since the cylinder head was off, have you doublechecked the cam timing to assure that the cam is not a tooth off? Also, what kind of condition was your short block in before the head was done? If you had the head done and the short block was worn and weak, a bad situation could have been made worse by causing more blowby past worn piston rings and, hense, less power.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
Quote from: whitepony on January 17, 2006, 02:53:41 PM
Alright. But there is something wrong. When I go up a hill, or I'm just straight driving it is rediculously slow!!! I think my engine is holding out on me. I am missing one screw from my accelerator pump. I don't know; I've just been really discouraged lately.
                                                            -Branden
Hello Branden,
The Pinto with an automatic has a top speed of around 70mph
Up hill this will decrease steadly untill it levels out.
P.S.
My 72 pinto does 40mph on a steep hill.
In 2nd gear!!!
whitepony
                                                            -Branden
If you had the stock head re-done with all stock parts your car will still be slow. Sorry.
whitepony
Hey yall... I was wondering when you replace a camshaft, get a valve job done, oh heck if your head is basicly re-done.... is my car still supposed to seem pansi-ish? I mean I spent nearly a grand on my clylinder head and it seems to not have all that much power! Do I need to mess with the carb because I forced the choke plates down(to the front of the engine) and my car seemed to have much power... much like it should feel as I waited over a week to get the car out of the shop!
        -Branden
