Squire trim
Date: 03/28/2018 10:11 am
Date: 02/28/2024 02:07 pm
Date: 03/18/2020 01:30 am
Bell housing
Date: 08/23/2017 05:41 am
V8 rear end
Date: 04/12/2018 10:57 am
Date: 02/18/2017 04:47 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 02/21/2017 06:29 am
  • Online today: 350
  • Guests: 353
  • Total: 353
Pinto missfiring on the highway.
Started by pintoguy76, December 19, 2005, 10:25:37 PM
Did you get all those pumps at the same place? I have never had any problems like that. You might have a problem with the fuel strainer in the tank, rust in the tank, or a bad fuel hose.
How do the plugs look?
That valve might not be helping either.
I put an electric pump on it because mechanical pumps would work for about a thousand miles and then quit. I went thru 5 or 6 brand new mechanical pumps and finally the last one would not work at all. Thats when i got fed up with it, and put in the mechanical pump. I too wonder if im getting too much fuel. It's a possibility, but i think it is burning everything it gets, theres no black smoke. There is blue smoke when i rev it up, due to valve guides and a burnt valve, but i have never seen any black. I might try the regulator thing, i dont know. Going to clean that one spark plug too for sure.
I would think about running a stock pump and lines, and replace the bad section of return line. It is all low pressure stuff, easy. The pump is a pain with that sheild, but with all the stock stuff it should run right. If you don't want to go thru that, you might want to get a reg. with a bypass (return). This might sound funny, but maybe you are getting too much gas. I doubt it, but maybe.
My vent line has a fuel filter on it and I have not had any problems (EFI).
I bet thats the problem right there. I plugged the return line. Ive used this electric pump now for about 2 years....had the car a lil over 2.5 years. The problem with that is it hasnt done it every time im on the highway, after i gave it a fresh tune up i went to kansas city the very next day and it ran fine. Thats about 200 miles each way. It made 27.2 mpg and had more power than its ever had before. Now the gas milage has dropped some and it doesnt have near the power. It was amazing what the tuneup did for it, but its a shame that power didnt last long. The reason i plugged the return line is because it was leaking gas out of it. is there another way to vent the tank? I havent checked to see if it still misfires if i leave it in a lower gear...dont see why it wouldnt tho. There are no charcoal canisters or anything on this car...no vents into the intake either except for the PCV system.
If the belt was out of time you would have less power overall, depending on the setting. If it runs fine then has issues, chances are it is not the belt. In the mid 70's car makers were forced to use a "self contained" venting systems. What this did was basicly vent into the intake or charcoal canister. When they did that, they stopped venting the gas caps. If your venting system has been messed with and you use a non-vented cap, there is potential for a problem. Check to see if the vent hose is not plugged or kinked.
You stated that you have an electric pump. Is a return line installed? Are you using the return as a vent?  I know on my pintos the mech. pump has two fittings, one is a return to the tank.
Will the car have its problem if you stay in a lower gear and keep the rpms up?
This cap was bought at the parts store for a 76 pinto sedan. The coil is about 2.5 yrs old, but it was a cheapie. Vac advance worked last i checked, i'll check it again. If the timing belt was off could that do it? I think my belt is old...
STpinto
The gas cap is something you should check, correct it by buying a cap made for your car.  Another thing to check is if the distributer is advancing. Sometimes when you start the car, it is fine, because you aren't really putting any real demand on the engine. But then you get it out on the highway, and the distributer needs to advance, and it is stuck in it's original postion, and can't utilize the fuel now being introduced. Many times the vacuum advance is not working any more. Check it with a vacuum gauge, or take it off the distributer and zoop through it- if it doesn't move, it is inop. Also, check your coil, they can make a car behave badly-good luck
Keep on Keepin on
No surging, it does pop real loud under the breather when i put my foot to the floor. It just starts misfiring real bad and bogging down and losing speed pretty bad, even with my foor to the floor. Im not sure that my putting the pedal to the metal doesnt actually make it lose speed faster....because it might, i didnt pay much attention to that. How do i make the gas cap vent if it is unventented? I can remove the cap and try running it that way, but if thats the problem how do i solve it? Drill a hole in the *top* of the  cap?
73pintogeek
Hi...
I agree with the gas cap theory...try that first ...if the cap is not vented it can create a vacuum of sort`s after high fuel consumption and as a result ...fuel starving...as you slow down the tank has time to vent as consumption decrease`s...also you say it mis-fire`s...doe`s it pop back or start to surge or bog down? Just some thought`s...Hope they help! ;D
73pintogeek
A bad day workin` on my Pinto is better than a good day at work!
No i lost the original cap and replaced it with a brand new locking gas cap. I think I still had the stock cap on it when it did it before tho. I dont think the new one is vented, not even sure the original one was either, but i dont know.
My 79 race car did something like that, but it was the pump. It checked fine for pressure, but did not do the CFM. Changed it, and it was fine. Was the stock mech. pump.
Do you have a vented gas cap?
My 76 pinto has recently developed a problem that ive had in the past and cured once before. It'll do just fine in town, but get out on the highway about 50 or faster...and it will run fine for a mile or two, but then all of a sudden it starts misfiring real bad and losing speed, even with the pedal to the floor, and after downshifting...get down to a certain speed and it will be fine again....until you reach the normal highway speeds again.  Ive replaced both fuel filters (the one behind the electric fuel pump i had to install, and the one up by the carb. Like i said its done this be before and i cured it with a fresh tune up. New plugs, wires, cap, rotor and filters. But, that has only been 6 months and maybe 5,000 miles ago. Theres no reason i should need to replace that stuff again already. Theoretically it shouldnt be fuel related, because you use more fuel in town than on the highway. The plus wires havnt layed on the hot exhaust manifolds and burned the insulation or anything like that. The only thing i can think of is, there is a burnt valve in cylinder number three. Maybe it has fouled. I dont know why the plug would make it do this, but its the only thing i can think of that could be solved by giving it a tuneup, and the burnt valve is the only thing i can think of that would have already fouled up something that is new. Whats odd is it never did this before the last time it happened and its been 2.5 years now and i know its had the burnt valve this whole time and its been on the highway alot. I just cant figure it out. The *only* way i can see it being fuel related is if the pump is weak to keep up with the CONSTANT demand of fuel on the highway, instead of the the inconsistant use of fuel intown...everytime the clutch is pushed in it would give the fuel pump a chance to refill the float bowl in the carb. Just a thought. Anyone have any ideas? Ive got a new head for my car just havnt got the time to put it on yet.
