Date: 10/11/2019 11:13 am
Date: 10/24/2019 01:43 pm
Date: 02/05/2017 09:45 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
77 pinto
Date: 08/22/2017 06:31 pm
Date: 01/24/2017 12:36 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
  • Online today: 587
  • Guests: 565
  • Total: 565
73 Pangra Project
Started by turbopinto72, May 05, 2003, 06:42:14 PM
Quote from: turbopinto72 on May 01, 2005, 04:44:46 PM
And yet another view of the "shiney" garage. ( Im sure Scotts garage will be even more shiney).
Brad, the car looks real good with the Torque Thrusts on there.  Nice choice!
wagonmaster
Hey Brad, have you had a chance to drive it at all yet? Are the brakes working properly now? Starting to look SHINEY!!!  ;)
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
Hey brad, haven't you heard?... A clean garage is a sign of a sick mind!?! LOL
Peronally I think both are lookin GREAT! Knowing all the work that went INSIDE the Pangra & what went on it that garage for the last month or so, I know MY stuff wouldn't look that good!
Hey Brad,
Those wheels look familiar. ;D
Loose the blacked out taillight frames. TOO much Black.
Nothing looks better than Black and Chrome!!!!!
So the clear coat did not go well but at least I have a clean garage. Here are a few pic's of the ( not yet done car" but a clean garage. 8)
Its never too late to start clear coating your car ( even when its 2 days before a show.......... :o :o )
Quote from: Sir Hugh on April 11, 2005, 11:46:35 PM
Hey, is this the car you are trying to finish for the Knott's Ford show? If it is, oh man will it be a sight to see. You have done some fantastic work from what I can seen. Can't wait to see it in person. Good Luck! :D
Yes, this is the one and its giving me fits BUT I think I'm wining............. :P
Brian, the oil galley plug was only 1/2 of the equation. after I fired it up I STILL did not have oil pressure. So, I once again removed the aux cover plate but noticed that my fix was working. I could spin the dist shaft and see no oil leaking out the plug. The oil pressure would go up to 25 lbs then drop down to 12. SO..............off goes the pan.................again......... however I did find the culprit. It seams that the oil pick up tube had loosened from the pump causing a mass leak inside the block. Its fixed now............... >:( >:( >:( :o.........Any way Now I'm working on fitting the Hood ( which needs some massaging). Nothing like taking it down to the wire. OH BTW, I fixed the throttle cable bracket so it does not move. I added another bracket to it. More news to come tomorrow....
Sir Hugh
Loving my plum 1978 Pinto Hatchback.  He has a rebuilt engine and is running like new. Beautiful. He still needs a new paint job though.
wagonmaster
Hey Brad, did you have much trouble getting the oil galley plug taken care of?
Brien - wagonmaster
'85 LTD LX
good job, get the test run on video, i'd love to see it!
Quote from: 79panel on April 10, 2005, 12:37:08 PM
On Friday, April 8th, I went down and helped Brad with his Pangra. We got the brakes working, the doors and decklid aligned and working well, and determined why the oil pressure went away when running the engine to test changes Brad had done. All-in-all, a fairly productive day, plus, for lunch, Brad fed me one of the best pita sandwiches I've ever had!! :) I'll let Brad fill in all the details later!
Yes, many many Thanks to Brian for all the help with the car. I have yet to try out the brakes........ :o.......... But I'm sure they will work well..... ;D........ This weekend I got the door handles back from the powdercoater and installed them as well as the inside panels etc.Got the front fenders on ( finally, after dropping one of them while the paint was wet and spending about 5 extra hours doing scratch repair and fixing a piece of gel coat that fell off........ >:( ). Any way, a little more paint and some clear coat and a test run.........everybody cross their fingers... ;)
wagonmaster
Brien - wagonmaster
'85 LTD LX
CHEAPRACER
I installed a high volume pump on a previous 2.3 project and while bump starting the engine to check valve lash, it  shot the oil across my ceiling and down my brother before figured we should throw the cover on.
Well, hear is a good one for ya all. after firing the car up and running it  I noticed that the oil pressure guage was pegged at 100+ lbs oil pressure. I figured it was broken or something so I installed a mechanical guage at the oil feed to the turbo. It to showed 100+ lbs oil pressure. After a few days of thinking and calls to both Dan and Dwayne Esslinger it was concluded that my Hi volume/Hi pressure Melling oil pump was defective. Dwayne said he thinks I could have hada up to 200 lbs oil pressure ( this would be the bad part). SO, I called Summit, they called Melling and the next day at 9:00 am I had a new ( stock) oil pump. I pulled the rack, dropped the sway bar, pulled the pan, installed the new pump etc......... Fired it up and now have 70 lbs oil pressure at 1300 rpm cold and about 60 lbs warm ( from a STOCK pump). Who needs anything more????? as a matter of fact its probbably to much ( I will be changing oil from 20/50 to a streight wt oil.   :o >:( :P ;D
Thanks. I got the interior done and doors painted now. The Powder coater jacked up my door handles, front window trim and rear bumper....... >:( >:(, needless to say im not happy................ >:( >:(
bricker4864
 :o Looking great as usual, Brad.  The bench looks like the back of my wagon when I was working on it.
Wheres that sound clip?  And I dont mean cow....rooster....bark :P
So, what does a work bench look like when Painting............ :-\
You guys know how I like shiney...... ;D This is four coats of base, each coat wet sanded between with 1500 over four coats of primer and the first clear coat.
A few up date pictures on the paint. The door is 3 coated with base and a small repair going on. The body has the first clear coat.
OWWWWWWW!!!!! Been there, done that I had a radiator cap blow off (of course I was being stupid & opening it while it was hot) I was standing directly in front of it & got the most of it on my chest. It didn't feel right for a week or two. Now I know what a lobster feels like!!!
Thanks, I appreciate the comment. My SHINEY was almost tarnished yesterday when I was running it for the first time. About 10 min into the break-in cycle the upper radiator came off and blew hot antifreeze/water all over the place. The other bad thing was I was standing right in front of it when it happened and got doused with 180 deg water. Cant tell you how that su@ks, I got burned on both legs and one arm. Still does not fell great today ( the good news is I got all of it off my SHINEY parts............ :o :o ::) :'(
Brad, the Pangra is lookin BEAU_TI_FUL!!! It's so nice that you may not get points in a show cuz the judges were blinded by the SHINEY!!  :P Thanks to guys like you the Pinto is WELL represented!
Quote from: Pintony on March 05, 2005, 11:12:52 PM
Hey Brad,
I like your credo "Your Never Too Old To Go Fast"
Do you ever go REALLY fast and think??? "Did I Double Check the torq on those lug nuts?" ;D
hehehe, well, the other credo is " the older I get the more I need to doubble check things". I cant tell you how many nuts and bolts I find loose............. :o
Hey Brad,
Allmost ready for some paint.
And it all went down to the metal ( and fiberglass ).........just about ready to paint.
