1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Built 2.0
Date: 10/07/2018 05:27 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 07/10/2016 10:17 am
Date: 07/30/2018 04:32 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 11/05/2016 09:03 pm
  • Online today: 1,106
  • Guests: 160
  • Total: 160
Build sheet
Started by Tercin, November 04, 2005, 01:35:43 PM
my bilud sheet was under the drivers seat tucked in the springs  a Ford friend told me to look there
Tercin
Most of it is what each code means. Since the car si mostly original or repaired to stock specs, I think it will be a matter of taking the time to sit down and really think about each part. Winter will be cold, that will be the time to sit down and look things over a bit.
Tercin
The only Pinto I have
73 Sports Accent
Rust free California Car
Bipper
Depending how wadded up it is what I have done is use steam form an iron to get the paper softened up as much as possible. But don't hold it close. It needs the moisture, not really the heat.The paper is so dried out there's not chance of getting it near flat without some humidity. Even with doing this you will have pieces break off, but if you can eventually get everything flat you can tape the pieces back on. And don't try to do it at one sitting. Do a little bit every day. Give it a little humidity every day as it unravels.
Tercin, what parts can't you figure out? Maybe I can help you.
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
skrach
i found mine under the passenger seat under the carpet and under the insulation lol  mine is wadded up in a ball, im trying to figure out how to un ravel it without breaking it lol.
I found mine under the carpet on the drivers side.
Quote from: Tercin on November 04, 2005, 01:35:43 PM
The other day I got a wild hair and decided to do a bit of poking around my 73 Sports accent. Low and behold there it was between the seat springs and the foam, under the passenger seat was the coveted build sheet. A bit tattered but complete. I know how to figure out some of it but not all of it, still after 32 years and 1 previous owner it was still there and readable.
Tercin
How COOL!!!! 8)
Tercin
Tercin
73 Sports Accent
