Date: 06/07/2021 08:14 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Date: 02/28/2018 09:33 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
1971 Pinto
Date: 03/04/2017 11:28 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 02/26/2017 03:22 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
  • Online today: 531
  • Guests: 349
  • Total: 349
my bobcat won't start!
Started by krazi, November 03, 2005, 11:04:08 PM
krazi
I know it isn't the cam gear, it isn't water in the tank, and it shouldn't be a locked distributor. I talked to my auto instructor from high school, and he said it might possibly be a broken rotor. the cam gear is aluminum or some metal, I made sure of that when I changed the cam when I put the engine in the car. I hope it's the rotor. thanks for the input.
krazi
yeah, I'm Krazi!
dirt track demon
take the distributor cap off and jump the solenoid with a screw driver and see if your rotor spins.  if it dont then you are in for a long day or 2 or 3. lots of swearing. maybe some tool throwing.   but on the bright side, racer walsh has a cool aluminum gear for the 2.8's.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
AHHHH!!!!!
The Old Stripped Fiber timming gear!!!!!
OUCH! You will have to take most of the fron of your V6 engine apart to replace the timing gears.
krazi
I was on my way back to work this evening, tooling down the hi-way at about 45 or 50 when it happened. the engine hiccupped, and stuttered, and died completely died when I shifted to neutral. I tried to start it, and it didn't want to fire. I checked the #1 plug wire, and it had spark. ok. I pulled off the air cleaner and looked and listened when I pumped the carburetor. I had fuel. I tried everything to get it to start. I called my auto instructor from high school, and he said to check the fuel for water. I'll do that tomorrow. he also said to squirt some carb spray down the airhorn, and if it starts, then I have water in the fuel. tried it, nothing happened. here's the specifications: '77 mercury bobcat wagon, 2.8 v6, motorcraft carb, c-4 trans, 8 inch rear. any help would be greatly appreciated.
krazi
yeah, I'm Krazi!
