V8 rear end
Date: 04/12/2018 10:57 am
Date: 08/13/2018 02:46 pm
Date: 03/13/2021 12:57 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 03/23/2018 09:23 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 07/04/2022 07:55 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
  • Online today: 645
  • Guests: 656
  • Total: 656
Project Warhead
warhead2
Did a little more work today was able to Barrow a cherry picker and pull the engine had everything disconnected a while back was just sitting on the motor mounts. Bought a engine stand today also. Will get the engine on the stand this weekend once I buy some bolts to mount it to. Decided to remove the clutch and flywheel.  The clutch was supposedly the reason the car was parked. Will post this weekend with an update. If anyone has any questions feel free to ask.
warhead2
Another update. Still working on the underside. Using sanding sponges to sand the dirt type grit and lite surface rust. I finally finished removing the driveline attached to the axle, wasn't worried about it till now. Its in my way for sanding. Just removed the 2 u brackets.
Also removed the last exhaust hanger. Sanded,cleaned then primed the area between the spare tire and rear axle.
Also was pulling out old mouse nest debris thats inside the frame. Had to be careful lol was pulling stuff out and stabbed my finger on a 30yr old sticker. Found several more after that.
warhead2
Here is the after picture that i forgot on the post above. Also 2 pics of what i got done so far on the rear spare tire area.
warhead2
Did some cancer(rust)  removal to see how far some of it has spread. Have only the before picture of the rear passenger fender area. Will post later and after picture.
I know my cuts aren't perfect but more of exploring. Will make cuts better when i get my welder up and running. Fun part will be the wheel well area since there are 2 sheets of metal 1 inside and 1 outside
warhead2
Did some more light sanding, primed n undercoating on the rear spare tire area, also removed the muffler still along ways to go cleaning and undercoating
warhead2
Dropped the fuel tank tonight still had around
8 or 9 gallons left inside for 32yrs. Smells amazing lol. Cleaned the rust off one of the tank straps then primed all of it except where the bolt was just need to remove it just got tired and will do it later. Just need to clean up the underside now for undercoating
warhead2
Worked on scraping some seam sealer inside the floor area no picture. Then decide on cleaning the underside on drivers rear passenger floor. I used a sanding sponge to clean up then mineral spirits to clean. I put down primer in preparation for undercoating with truck bed liner. Forgot a pic of the primer. Only worked this small area for now.
warhead2
Lol on the flex seal Pinto. I have some fiberglass drywall tape maybe that will work place on the inside then coat it.
It will be interesting to see how the Flex Seal hold up. why do I see an image of Phil Swift spraying a Pinto with Flex Seal and driving it across a lake. LOL You might consider model aircraft fiberglass with Flex Seal applied as a possibility for the holes in the boots. Maybe it is something that can also be 3D printed? There are a number of "rubbery" plastics available.
warhead2
Ok an update have only done some small stuff. I got the driver's spring readjusted was not in the bottom grove properly and got the upper n lower ball joint connected to the spindle. Then just clean n primed and undercoated the lower radiator support. Also sprayed flex seal on my hood hinge boots. Drivers boot was in good shape no rips. passengers boot is alot worse them a big split. I got both cleaned n coated l got 2 coats on both but will have to work with the passenger one to get the crack sealed. But this is my update incase anyone was wondering.
Quote from: Wittsend on April 25, 2021, 02:28:21 PM
That's interesting. Does the Cruise Wagon have the slots cut for the window pivot point with a rubber or plastic plug? Or is there no holes in the area?  My wheel well looks fine, no rust through. Thus the only logical place for water to get in was the window pivots. I wonder if the cars with non-movable rear windows get rust there too???
Now that I think about it..., I have the aluminum trim that sits rather horizontal and can very well become a channel for the water that drips off the windows. There has to be holes to mount that and maybe that is the source of the water??? Ford wanted you to buy a Pinto..., and three years later buy a Mustang. Like they should have cared.
When you take the side panels off it basically looks like a window wagon minus windows with a few additional holes for the hardware to secure the side panels onto the car.  You could theoretically take the side panels off and put glass back in if you wanted.  Everything is there.
Lower control arm should move enough to line the holes up....
warhead2
Did a little bit of work last night. Was going to install my new from speedway strut arm but the one of the holes on the lower control arm was off by a little bit. I tried with everything loose but didn't work. Looks like i may have to bend it some how to match the original.
Then I cleaned up some more of the passenger fender area also removed the brake cooler box then primed and sprayed undercoating. Didn't spray the bumper bracket yet going to remove it and clean it up.
Sent from my SAMSUNG-SM-G930A using Tapatalk
warhead2
I forgot to take my endo scope camera with me but I checked slightly behind the carpet panel. didn't see any rust streaks on the panel or in the lower panel.  Another thought is maybe some water seeped into this seam in the corner of the door frame on the car.
warhead2
Im not sure I will check tomorrow. I will have to remove the carpet panel inside but ill see what I can see with my endo scope camera first and take some pictures. There was no trim on mine. Im sure someone else might chime in on Cruising Wagons with rust in the same place.
warhead2
Quote from: Wittsend on April 24, 2021, 07:18:54 PM
Just a guess but I'm think that 99% of the time rust rearward of the door/above the sill is from water getting in where the rear, side windows pivot. Maybe if you live were it snows it is different. But my car is Californian and I still have rust there. It looks like there is a box beam behind the rocker and that is why the rust is up high. Another member posted pictures and I'll put some up here.
My passenger side floor was shot and I made a replacement floor out of sheet. But other smaller areas that aren't too bad I used POR-15 and their mesh. Sounds like a cheap way out but frankly I have had cars 10+ years doing this and it looks like I did it yesterday. Getting too old to think it will matter going forward for me. The picture is dark but all I have. I make the dimples with two different sized sockets on either side of the metal and hit the smaller with a hammer. It worked but it is easy to get the sockets out of alignment (you are doing this blindly) and I permanently marked my index finger when the 5lb hammer slipped and hit my finger!  >:(
Mine is a cruisen wagon so no windows. Maybe the panels had a leak but also had field Rats and mice in the 30yrs it sat Maybe rat pee?? Also this is an Oklahoma car and still in Oklahoma so no heavy road salt. Also we do get some snow so maybe it froze on the outside in that area or worked its way in. I didn't remember seeing any rust streaks by looking from the inside that area but will double check this week with my Endo scope. Thanks for the suggestion.
warhead2
Here are most of the body rust spots that I will need to cut out and weld in new metal when I get a tank of Co2.
warhead2
Worked on rear floor pans some tonight. Cleand up some rust and then primed it. Then cut into some rust bubbles to see how far the rust spread. Will have to do some more cutting before I find someone good metal.
warhead2
Quote from: Reeves1 on April 06, 2021, 05:06:54 PM
OEM bolts do not need to be pressed in. Yours may be a bit too large.
If you press them in they may fail ? Depends on how much pressure is applied......?
(I would not do so)
This is a lug bolt the same as wheel lug bolt. It needs pressed in because of the knurl to keep it in place and not spin when taking on or off the nut. I think it is a little bit harder because it is a new strut arm that hasn't had a lug bolt in it. It has to cut the knurl as you press it.
(I would not do so)
Can't answer your questions but... .  Does it cause anyone else to ponder the fact that we are warned that a microscopic scratch can become a stress riser that can cause a part to fail. Yet lug bolts and a lot of ball joints are pressed in with a multitude of jagged edges?
warhead2
Small update. Called Speedway and talked to one of the experts and he advised me to use a 7/16 20 lug bolt. I tried pressing in with a ball joint press got it almost all the way in may need to use a hydraulic press. But it looks like this size bolt will work.
Does anyone know if the thickness of the head being a problem vs the original that is much flatter? Looking at pictures it doesn't look like it will interfere with anything.
I then cleaned up a little bit of rust  on the drivers frame head n running lights. Just primed it to cover the bear metal. Will clean the frame all the way when i get my bast cabinet set back up.
Quote from: warhead2 on August 27, 2020, 08:19:50 AM
Put on some truck bed liner on passenger side and some anti rust coating in the strut arm/ frame area. So i tried to install the old studs on the new strut arm and couldn't get it to go any further. Im going to measure the hole and the stud. I believe the holes need to be drilled out just a hair. Ill post my findings in the next few weeks. The strut arm is from Speedway.
Make darn sure before you drill !
Those bolts are not meant to turn. OEM was likely pounded / pressed in to cut the grooves like you see in your old ones.
rob289c
I have strut rods from an '80 that you are welcome to.  Let me know if you want them.
rob289c
From what I remember the struts are different between the Pinto and Mustang II.  I don't remember what it was off the top of my head as it has been almost 15 years.  I had both front ends at the time and I was parting them out at the same time and I noticed those parts were different.
warhead2
warhead2
Partially got the upper control arm in. And installed the upper ball joint on drivers side. Need to readjust my spring to sit in the groove in the lower arm. Need to spray on my truck bed liner on the passenger side before I install the rest on that side.
warhead2
Quote from: Wittsend on August 07, 2020, 01:49:21 PM
How did you deal with the different strut? I think the main thing it would change is the caster - if anything. But primarily I think it would either correct a design problem - if in fact one existed..., or not even install because things wouldn't line up.
The new strut is for the passenger side. I haven't  tried to install it yet. I think it will work  im hoping.
