72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 03/06/2017 01:24 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
nos core support
Date: 01/03/2020 09:39 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 04/30/2023 04:31 pm
1979 pinto
Date: 04/19/2018 02:02 am
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
  • Total Topics: 16,268
  • Online today: 330
  • Guests: 148
  • Total: 148
Project Warhead
Started by warhead2, November 01, 2005, 10:57:13 PM
warhead2
Rob for most part the front floorpans were only part that was really rusty the underside of the car is good along with frame. But rust in normal spots like lower panels in different spots and bottomms of doors. This has always been an Oklahoma car so no big problem with salts on the road.
Sent from my SM-G965U using Tapatalk
rob289c
Reeves1: Not sure what you mean by lower (cable) steering shaft.  I attached pics of my steering shaft but I don't knw what you mean by the cable.  Wiring harness?
rob289c
Quote from: rob289c on January 16, 2023, 07:44:13 PM
Mine was (I guess still is) a 1980.  I held on to parts I have used, will use, and might use on my current project.  I gave a lot away, and then gave what was left of the body to a local guy that had a Pinto.  What parts do you need?
Lower (cable) steering shaft
rob289c
The frame rail looks pretty solid.  Good thing.  I'm looking forward to Spring so I can get back on my project...
rob289c
warhead2
Did some work to passenger floor. Cut out some rust. Only worked on it for a little bit tonight. No grinder injuries lol but wore thicker gloves just incase.
Cardboard under car just for spark defelting
rob289c
rob289c
Quote from: rob289c on January 07, 2023, 05:52:45 PM
Rusty floor work...nasty job!  I had to do the passenger side front floor pan in my Mustang.  Pinto was too far gone to salvage.  Using what I could for my Mustang/Pinto Roadster Project.  Lots of fab and welding ahead for you...
What year Pinto ? I need some parts... 71-72
rob289c
Ouch!  I know what you mean about the physical pain not what one would think.  Several years ago I detached my right distal bicep tendon.  It felt like a rubberband snapped on my arm...not much pain but freaked me out when my bicep was up near my shoulder!  Got it fixed and is as good as new.
rob289c
No one gets out without paying "Skin Dues." I was building a Tiny House with my daughter . I was using a push stick on the tablesaw, but I had my index finger extended too far. I was also holding the push stick too high. When it caught the blade the stick slammed my finger down into it. Honestly the physical pain was 5 on a scale of 10. The financial pain was an 11 on a scale of 10. 45 minutes in the ER for 4 stiches and the bill was $5,600! We went back and fourth with the hospital but it still cost $2,200. The young Dr. suggested I could return to the hospital to get the stiches removed. Not after that bill. I took them out myself.
warhead2
I did a little cutting of the rust, then cut down the new floorpan. I need to trim it a little more but so far so good. Also nicked my thumb with the grinder when I turned it off.
My passenger side was bad too. Likely because water leaks in the car and puddles there due to road camber. I took a sheet of steel and fashioned it to fit in the area cut out. I put a few dimples in it using a larger/smaller socket on each side, guestimating they were centered and hitting the upper socket with a 5 pound hammer. Worked Ok, but not the best. Stopped when I missed the hit and tweaked my index finger. Overall the repair works and has held for years. I just hate (MIG) welding thin metal to somewhat suspect old metal. There is a fine line between cold welds and holes blown in the metal. 20 years of doing it and I still dread the process.
warhead2
The passenger is worse. I have bought floorpans from Joe Bayura. They are not to bad of a reproduction. I still have a long way to go but trying to stay motivated. But as long as I keep doing something to the car its one less thing
firepinto
My floors are about as bad.  I have some ebay reproduction floor pans still in the box that I have to get to soon.
'79 Pinto auto hatch back with an '80 2.3L and 4 speed transplant.  A 2.3 Turbo and T5 are waiting for the next transplant.
Plans changed, going V8 with TKX!
rob289c
rob289c
warhead2
Looks good on the strut arm.
Small update did so rust removal on drivers side floor pan. Did have a whole lot of time so will finish it another day. One picture is the the frame rail and all the stuff field mice/ rats stuffed in there over the yrs. Thats all for now Happy new year everyone.
Quote from: rob289c on December 11, 2022, 06:37:06 AM
That will be done in the Spring.  I am just test fitting and finger-tightening parts at this point.
Experimentation still counts as progress in my book!
Dwayne :)
rob289c
Yesterday I bolted my OEM and Speedway strut rods together, put them in the vice, heated, then bent to the proper angle.  I test fit the Speedway rods to see how they line up with the lower control arms, frame, and sway bar links and everything appears to be fine.  Just letting you know in case you want to try it on yours.  I don't think you will be able to bend the Speedway rod without applying heat first. Until I get my coil springs to the right height and get weight on them, I'm not going to final assemble and torque anything. That will be done in the Spring.  I am just test fitting and finger-tightening parts at this point.
rob289c
rob289c
Reeves1: I have decided there is too much corrosion in the bushing area of my OEM strut rods so I am going to use the Speedway rods after bending to the correct angle and transferring the sway bar end like mounts to the Speedway rods.
Warhead2: I attached a pic of my rods OEM vs Speedway that shows the different angle between the two.
rob289c
Heat them like that will weaken the metal.
I'll buy them if you'll ship to Alberta ! I was going to buy some anyway....PM me if you want ?
rob289c
I have an oxy-acetylene torch that would heat them cherry-red in seconds and they would easily bend.  By this time tomorrow I should have my old strut rods back.  I contacted the guy I gave the remnants of my Pinto to and he said I can have them back.  I will be stopping by his brothers farm where my old Pinto is and grab the parts I need.  The lower control arms, including the strut rods are in the hatch area so I will throw them in the back of the pickup and disassemble when I get them home.  Hopefully they are where I left them.  I will see if Speedway will take back the ones I bought.  Store credit will be fine as I will be buying more parts as I continue on my project.
rob289c
Take the new ones to a machine shop & have them bent to the right angle ?
warhead2
Rob i still have my factory one. Everything is the same except the angle. The bushing end was why I was changing mine out. Its still solid but do you think it had rusted to much to be usable?
rob289c
I have some comments on the strut rod issue.  It looks like you have one factory rod and one that you bought at Speedway.  I didn't think I needed my old strut rods and gave them away but unfortunately I found that the kit I bought from Speedway that didn't require strut rods, when I attempted to install I found out that the Speedway kit doesn't work with a stock Pinto Crossmember.  I had to go another route with different lower control arms.  I am finding that other parts that Speedway lists for Pinto and Mustang II only work with the Speedway or Heidt's crossmembers, not the factory stock crossmember.  That is true for the strut rods that you and I purchased.  The speedway arm isn't designed to work with the factory frame.  The Speedway frame has a different mounting bracket and doesn't go through the frame like the factory configuration.  I think if I put mine in the vice and heat to cherry red, I will be able to bend it slightly to make it line up with the factory frame mount.  The good news is that the mounting holes in the strut rod line up with the holes in the Speedway lower control arm...you just cant bolt it on because the angle is wrong to get it to line up with the frame mount.  Other than the angle being different, do you see any other differences from the factory rod?  Is the overall length the same?  Are the Speedway bushings the same as the factory bushings?  Mine old ones are long gone.
I looked back and saw that I had offered my old strut rods to you in an earlier post before I gave them away to someone else.  I wish I had kept them!  I also wish I had researched and asked more questions about the Speedway parts.  I assumed that they could be used with a factory crossmember but they don't.  I asked the sales rep if the kit would...he assured me it would and even passed me to a tech support specialist and I told him what I had and he too assured me it would all work together just fine.  I know better now.  I thought if anything on my project would be a no-brain, bolt-together endeavor, it would be bolting the front suspension together.   It isn't...
rob289c
warhead2
Rob thanks. I plan on doing a few mods to the car more electronic side. The strut rod on the passenger side I still haven't messed with it yet. I plan to tweak it with a long cheater bar in very near future. I still don't have a tank for my welder, but I'm working on that next wk.
Like I said I welcome any questions it keeps me motivated.
rob289c
This quite a project you have going and I don't know how I have missed your posts.  Had I noticed it sooner I would have compared notes with you with the project I have going on.  Yours looks to be a straight resto, while mine is re-using as much as I could from my rotted out Pinto to make an oddball car.  I will follow this as you progress.
One question:  what did you have to do to get your strut rod and lower control arm holes to line up?  I also bought the Speedway arms and they too seem to be off by a little bit.  I think I can tweak them but wondering what you ended up doing.  Mine came with the press in studs too but I am going to use Grade 8 bolts instead as I am going to be bolting the sway bar mount on top of the strut rods and the studs won't be long enough to accommodate bot the rod and mount.
rob289c
warhead2
Small update working some more on underside cleaning, priming, n undercoating around the transmission tunnel. Also the product im using. It works fairly well but make sure that you wear gloves and keep a rag or paper towel close to wipe of the nozzle,  tend to build up by it. If you have any questions feel free to ask.
warhead2
Worked on striping down the engine. Took the valve cover off and it looks good for sitting for 30 plus yrs.
warhead2
Got the engine stand put together and got the engine on it finally. Was a little weird because holes are not exactly even on the back of the motor. I just took the adapter plate off the stand and was able to find the right position. Ran out of time to do anything else. But will go back to it in the next day or two.
warhead2
Quote from: Dtmix on July 05, 2022, 07:15:22 PM
Slowly but surely! You are making progress! I cannot wait to see the final product!
Keep up the great work! Keep up with your ongoing commentary!
Happy Motoring!
Dan
Thanks will do. Yes it is a slow process 6yrs so far since I moved the car and started working on it.
Dtmix
Slowly but surely! You are making progress! I cannot wait to see the final product!😀
Happy Motoring!
Dan
Happy Motoring!
Dan
