Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 09/21/2018 11:35 am
TWM Intake
Date: 08/15/2018 08:20 pm
72 Pinto
Date: 03/07/2019 12:07 pm
72 pinto
Date: 06/23/2016 12:40 pm
  • Total Topics: 16,268
  • Online today: 330
  • Guests: 150
  • Total: 150
Project Warhead
Started by warhead2, November 01, 2005, 10:57:13 PM
warhead2
Painted transmission mount
Took bell housing off the transmission to clean up
Got the lower control arm painted.
Also put some undercoating on the driver's fender
Thats it for now need to get on the ball and put the driver's side suspension back together. Then I can start on passenger side.
Sent from my SAMSUNG-SM-G930A using Tapatalk
warhead2
Thanks will do. I plan on redoing all the seams with sealer inside and out.
Looks like you are making some good progress.  Your car reminds me of my cruising wagon.  Floor pans and all...LOL.  Make sure you re-seam seal the cowl panel under the fender before you put it on.  The part where the cowl meets the kick panel side.  My car leaked down the kick panels on both side due to the seam sealer cracking / falling off.  Keep up the good work!
warhead2
Put some Dupli color truck bed liner on wheel well fire wall. Put on 3 coats on. Also tried putting in coil spring isolator to make sure it fits and it fits perfectly.
warhead2
The Easter bunny came early. With bushings and some suspension parts lol.
warhead2
Just got the outer sleeve out. Also ordered my energy suspension control arm bushings. Also paint this control arm also.
warhead2
Transmission cross member before cleaning. Will paint tomorrow. Will post pics soon
warhead2
Worked on lower control arm bushing got the inner sleeve and rubber out. Now to get the outer sleeve out.
warhead2
Im working on it slow but steady
The Whistler
I like It. Show us more progress please!
Turbo is a way of life
warhead2
Sandblasted and painted with chaise saver paint
warhead2
Ok thanks i had seen his post
warhead2
Some more clean up of parts
Removed York A/C compressor
And removed the hood
warhead2
Was checking out some rust on passenger side between door and rear wheel. Found bondo and who ever did the work sucks. They put 1/2 thick layer of bondo even a small part was still wet from 27 yrs ago lol.
Also removed the carburetor
warhead2
Cleand up and primed the bracket for the brake cooling box
Also took out the battery tray needs some work. I dont have a mig welder yet
I took out the radiator and the thermostat housing out was very rusted on in the tube but ok on the engine side. Was some sludge just inside the motor will get it dipped at a later date. Look at that 27 yr old radiator fluid still green lol.
warhead2
Some interior shots
warhead2
I got the front fender off and started on the driver's front end. came apart with hardly any problems for sitting for 27years until the lower control arm bolt after cut part bolt off still couldn't get it out. I finally able to split the inner bushing sleeve some and get vise grips on it it broke free
warhead2
Thought i would update this after above post from 13 yrs ago. I didn't really get going until April 2016 when i finally was able to load it up and move it to a garage in OKC. it had moved once from 2005 and sat another 12 yrs in a field. As i got it to my garage about to unload a passerby saw the car and asked if it was a Vega lol i was like no Pinto he said cool dont see them often and went on his way. after i got into the garage.
warhead2
ok this is 2 pics after i took the seats out just a reminder this car has been sitn for about 15 yrs so feild mice and rats got in there and made it there home lol
warhead2
ok here r some pics first pic is the pass seat,  2nd is driver, 3rd is back seat. at this time i have the bottem part of the back seat upholstered and workn on the top part pics soon to come
warhead2
its a 77 and for the drive train havent really thought about that yet.
Yesssssss!!!! WarHead....Go for it!!!!!!!! Pictures are very good. I will be starting on my interior after the first of the year as well. Is that a 78? what are your drive train plans?
gpinto2
Good luck keep us posted!!!!!
1972 Pinto 410,C-4
warhead2
ok guys well it is time for me to start on my project. So far I have tank the seats out and i plan and am working on re-uposter them starting with the back seat and in jan starting on the front seats.  and as of yesterday i removed the carpet and found that the front 2 floor pans rustd out with the pass being the wost.    I will post pics very soon. and here in a few wks i plan to take out the motor. ok thats it for now pics to fallow soon ;D
