79 pinto steering column
Date: 08/18/2018 02:00 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 11/02/2019 10:25 am
Date: 06/05/2018 09:13 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 07/11/2023 11:39 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 02/03/2018 11:28 am
  • Total Topics: 16,268
  • Online today: 222
  • Guests: 143
  • Total: 143
Project Warhead
Started by warhead2, November 01, 2005, 10:57:13 PM
How did you deal with the different strut? I think the main thing it would change is the caster - if anything. But primarily I think it would either correct a design problem - if in fact one existed..., or not even install because things wouldn't line up.
warhead2
Got the driver's shock, strut arm n bushing and steering knuckle installed.
Sent from my SAMSUNG-SM-G930A using Tapatalk
warhead2
Does anyone think that this strut i bought from Speedway will be a problem? The angle is off like a 1/2 inch but the rest of it matches up.
warhead2
Partly installed drivers strut on drivers side. Also put on some undercoating around strut area. Also so Eastwood frame rust protection before I installed the strut. That is aluminum foil wrapped around the brake lines to protect it from spray.
I used Joe's Hand Cleaner (no grit).
Pink stuff & like jelly.
Use gloves & slather on (with care due to sharp edges) and let sit over night (longer doesn't hurt).
Scrapes off easy with a putty knife.
Use a second time if required.
Easy & safe, no fumes etc.
See the top two containers on the left, the one I use is on the right, white with red letters...
https://joeshandcleaner.com/products/
warhead2
Got my Eastwood welder a few wks ago. Also got my floor pans when I get to that point to install them. Haven't done much work the last few wks. I started trying to remove the old undercoating on the passenger fender with a propane torch and paint scraper.
warhead2
I have welded with Mig yrs ago. Took an Auto body / refinishing Class. Not to hard going to practice some before I commit to welding on the car. I bought the Eastwood 135 should fit my need for now. Still have to get a helmet and gas and a few other things.
Not sure if you have ever welded..., or not, but here are a few things I learned with MIG. In addition to a helmet and some form of a jacket a Pro Welder friend told me to wear ear plugs. That keeps any sparks from striking your ear drum! Make sure the metal is CLEAN. Have a good solid ground. If it is a 120 volt welder avoid extension cords and if you need one make sure it is 12 gauge and only as long as needed.
Sheet metal is a pain because you are likely replacing rusted areas. Anywhere the metal has thinned it is suspect to blowing a hole rather than fusing the steel. For me that is (notice I didn't say 'was') the greatest difficulty. Putting a piece of copper tightly behind those areas (potential holes) helps as it continues the continuity of current and also helps to draw heat. If you feel the gun pushing away from you, you have too much wire feeding. Use recommendations BUT wire feed speed and current levels are something you perfect over time.
Be prepared to GRIND. MIG welding is a constant additive method. Other forms (gas, TIG) you add metal at your choosing. But MIG is like Arc welding, you aren't welding unless you are adding.
What Welder did you get? 20 years ago my wife was in Costco and they had a floor model $450+ Lincoln MIG PAK 10 on sale for $250. It has been a workhorse for me. Just try and stay within the duty rate cycle. Thankfully I have never tripped the internal core breaker. The other is if you are using shielding gas over flux core make sure you turn off the bottle. Nothing is more frustrating than days later finding you have leaked $35 of gas from a new bottle!
warhead2
Thanks for the compliment. Im trying to just stay focused in certain areas. I have all the front suspension cleaned and painted its basically ready for me to put it together. Im getting my mig welder today. So will have other stuff i can work on.
Your perseverance and methodical "one step at a time" process should be inspiration to those who struggle with their Pinto projects. It is easy to get caught up in "window shopping" website catalogs but that shiny new part that was purchased at the click of a mouse..., it might take 10 hours prep work to install with a lasting effect. Keep your hands on the plow!
25 years ago someone gave me a '61 Corvair Lakewood station wagon. I used it mostly for storage but the winter of 2019 I decide, 'I'm 62 and if not now..., then WHEN???' So, I opted to make it a winter only project with the anticipation that it might take a few winters. Covid-19 has spread it into the spring - and possibly the summer. But the thing is you have to start, and you have to persevere. I'm getting close to putting the engine back together but it started with this  :o
warhead2
Got the bolt hole little bit more straight hopefully  i fixed it enough. I installed the driver's control arm and ball joint. Also painted the outside of the sping cup. Im moving in the right direction.
warhead2
Did a few touch ups/ I installed rubber spring isolators and installed the passenger lower control arm with the balljoint. Had to work to get the control arm in with the new bushings. If you use a 6in 2x4 to put under side on the sleeve of the bushing and hit it with a hand sledgehammer it will help get it into position.
warhead2
I would love to weld but don't have a welder yet. My plan was to leave the fender off and was only painting the area that i have done so far. I plan to use welding blankets to cover the area and suspension to protect it.
guess before you put the supenson back on finish up the welding on the battery box area , I always burn fresh paint with the splater from welding , then have to repaint , hate doing things twice , great job your doing ,
warhead2
Did some more painting on the spring cups. Primed and painted the middle area where the lower control arm gos on the passenger side. Almost ready to start putting the passenger side suspension back together. Almost have all the new replacement parts.
warhead2
Got both spring cups painted and the top of the driver's primed.
warhead2
Yes that's the plan when I get my welder. Battery  tray and the battery fender area are my first 2 repairs with the welder.
looks like you have the dreaded rust out from the battery tray , very common , no one ever cleans this area when changing batterys , at least you can get at it with the fender off and weld in a new peice
warhead2
Did some more cleaning and then primed fender and coil spring cup area. Plan on just using black rustoleum paint for the cup area. And truck bed liner for the rest of the fender area.
OK cool thanks for the info! I'm keeping my windows for sure I'm just concerned about the rubber. I think they're going to have to come out at some point.
warhead2
Found the chrome trim.
warhead2
Quote from: 71pintoracer on April 25, 2020, 09:03:35 AM
Your work looks really good! Good to see you making progress, mine is going to be a long term build as well.
I was wondering if you were going to remove the round side windows? I've been eyeballing mine from time to time and I'm not sure if the rubber will survive. Or if there is anything that could be used to replace it. The carpet is faded so they will have to come out at some point. The rubber holds the glass and the trim panel and has a bead on the outside so it's a very specific piece.  :)
Thanks yes im keeping the portholes I like them. As for the center chrome trim that goes in the middle of the porthole gasket that can be found new for 70s Ford Broncos believe its the chrome windshield trim. Should be a reference on the site about it. As for the rubber who knows how long it will last? When I get to  that part im going to see if there might be some other rubber  gasket that could come close to replace it. Like the rear trunk gasket on the Wagon is the same for a 1999-2002/ 04? ford ranger extended cab.
warhead2
Worked on cleaning up the transmission some more. Need to get a parts washer. Also put a little primer down in the passenger fender area.
warhead2
Most definitely thats the plan  For the gas.
When you get the Mig , set up for gas. MUCH better than flux core.
warhead2
Also incase anyone was wondering this is the product I used for my suspension parts. Its available on Amazon.
warhead2
I may remove the cowl and clean and repair rust and seal it up properly. Plan on getting a mig welder once i get my stimulus money. And for the seams i do plan on resealing all seams. Do you know if the seam sealer is the same for inside and outside? Or 2 different products?
Also re-seam seal the pinch weld that connects the cowl to the kick panel side.  All my pintos had dried up seam sealer in those locations and leaked.
Clean out that cowl vent area while you have the fenders off too - while you have the chance.
