Looking for front seats
Date: 08/10/2021 09:54 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Date: 04/13/2018 11:30 am
Date: 08/20/2017 01:34 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Date: 09/22/2020 11:33 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
  • Online today: 600
74 Pinto Electrical problems
Started by Pinto_dude, October 15, 2005, 09:01:15 PM
pmfman
check flasher (common for those to croak) and fuses
KDC
Pinto_dude
thanks Pintony for all your help. I found my problem. My light sockets in the front were connecting power between my parking lights and turn signals. I pulled the lights out and everything works great now. thanks and i hope this might help others out.
OK, Sounds like you have a frayed wire somewhere near the bulb.
Also if you have replaced the Neg. Battery cable?
Make sure that you have a good ground to the body as well as the engine block.
Pinto_dude
The Flasher is good. There are 2 flashers, one for turn signals and one for emergency lights. Both have power going in. No power (0 volts)going out when lights are not being used. When I turn on the parking lights i get less a 1 volt of power going thought the output side of the turn signal flasher. Still 0 volts from the emergency flasher output. Is this supposed to happen? Again, the turn signals work when the parking lights are not on. I am checking the grounds, so far they all seem to be good. thanks
Pinto_dude,
First start with a NEW flasher.
2nd check the grounds near your headlights on the core support.
From pintony
Pinto_dude
I have a 74 pinto wagon. when i turn on my parking lights, my turn signals don't work, or slow way down. Any help where to start looking? I have parking light problems already. Some lights don't work. Thanks for any help. Steven
