Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 10/27/2018 03:30 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Date: 11/12/2020 08:28 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 03/05/2017 03:27 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
  • Online today: 802
  • Guests: 180
  • Total: 180
Correct Tranny Fluid for a 1980 C-4
Started by rob289c, October 31, 2023, 01:15:09 PM
rob289c
Thank you for that answer.  I will use up the Dex/Merc I have in stock.  I think the only other think I have that uses it is the transfer case in my '03 Ranger.
rob289c
davidpinto
79 AND EARLIER C4s USE TYPE F, IN 1980 THEY WENT TO DEXRON .WHICH I RUN IN MY 80 MODEL.DEXRON III AND DEXRON-MERCON ARE THE SAME.
D BARHAM
rob289c
I know the older C-4's use Type F, but at some point in the late 70's Ford started using Dex II.  The 1980 Owner's Manual recommends Dex II.  I am told Type F would provide crisper shifts.  I think Dex II is now Dex 6 and supposedly backward compatible.  I have both Type F and Dex-Merc in stock.  I think Dex-Merc is closest to what the owner's manual suggests.  See attached.
What are you all using in your C-4's, specifically if you have a 1980 version?  What is the scuttlebutt on pros and cons of both fluids?  I have no history on this tranny, in fact I don't know if it has been rebuilt at some point in the past, or if it even works.
What would you do if it was yours?  Last year I drained the old fluid, cleaned the pan, and installed a new filter.  By next year I plan to run and hopefully drive it so I want to be prepared with and use the correct fluid.
rob289c
