Date: 07/08/2017 08:53 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 08/03/2017 07:40 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 06/07/2018 01:45 am
Bumpers
Date: 07/06/2018 04:47 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
  • Total Topics: 16,268
  • Online today: 289
1977 pinto x 2
Started by alwaysFlOoReD, September 10, 2023, 02:57:54 PM
rob289c
When I go out to the shop I will look to see what mine looks like.  1980, 2.3.
rob289c
alwaysFlOoReD
3rd time trying to post to my own thread...
I ran into a snag with the wiring to the 2.8l alternator. The replacement harness came from a 2.3l engine, and the connection is different as well one wire is significantly bigger. I'm doing some research but any advice is welcome.
1st and last pics 2.8.
Middle two pics 2.3.
rob289c
Keep working on it and post your results so we can all learn from each others' struggles.
rob289c
alwaysFlOoReD
Thanks both of you for the tips, I was able to re and re the wiring. Had a problem with the duraspark module but finally got it.
Unfortunately found some serious rot on drivers floor and firewall.
Will be draining gas tank next and see if it fires with new gas.
rob289c
First pic is the feed from under the hood to under the dash.  The big grommet goes through the firewall.  THe second pic are the two under dash connectors that correspond to the under hood feeds.  Hope this helps.
rob289c
alwaysFlOoReD
rob289c
Follow the bundle where it goes through the firewall.  Under the dash are (I think) two connectors that will separate the under hood harness from the under dash harness.  You will not have to remove the under-dash wiring.  Just un-do the connectors.  If I get a few free minutes I will snap a pick or two of the connectors.  My under-hood harness isn't in a real accessible spot at the moment but will try you get pics of that too.
rob289c
alwaysFlOoReD
Hi. I recently picked up a beat 77 pinto coupe to put a built 2.3 motor into. The motor I got in trade for some construction work. Apparently the motor was built for salt flats racing in an early 90s Ranger. The pinto is in pretty rough shape, no motor or gas tank but that wouldn't matter anyway. The original 3-speed auto is still in the car. While loading, the rear bumper was pulled off...😭. Guess I get to learn aluminum welding... This particular pinto is on the back burner.
The 2nd pinto is in much better shape. It has the 2.8l/auto. Unfortunately the magic smoke got away. I'm not sure if I want to try replacing short sections of wire, or rob the harness from the other pinto. I'm leaning to using the full harness, reason being i can check all connectors for being loose, which i suspect caused the magic smoke to leave. So.... can anyone tell me how to remove the wiring harness? It looks like there isn't a connector at the firewall. Do I need to disconnect everything under the dash?
