Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Date: 08/17/2022 06:27 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
74 hood
Date: 07/03/2017 03:46 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 02/18/2017 04:41 pm
  • Online today: 802
  • Guests: 195
  • Total: 195
Need carburetor help Autolite 5200
Started by ponyboy, August 26, 2023, 08:11:12 PM
ponyboy
OK, thanks a lot. That's where I'll put it, and see how it works. I'm going to use the small check ball first. Jerry
davidpinto
I KNOW ON MY WEBER 32/36 THE LARGER AIR BLEED GOES ON THE SECONDARY SIDE.NOT SURE ABOUT THE CHECK BALL ON A 5200
D BARHAM
ponyboy
Ok, I stupidly took my carburetor apart without paying enough attention. After I got it cleaned and started to put it back together with new parts from a kit, I noticed a couple of things. What5 are called "high bleed jets" in my manual, that go on top of the main well tubes, are 2 different sizes. I can't find any numbers on them. I don't believe this is the original carburetor. Does anyone know if the larger one should go on the primary venturi side or the secondary venturi side? Also, when I took apart the accelerator pump discharge assembly, I did not find a ball check valve in it. The manual shows one at the very bottom of the hole. The rebuild kit I have has three ball check valves in it, two that measure approx 3.6mm, and one that measure approx 2.9mm. The diagram only shows one ball in the whole carburetor. The kit includes some parts that don't go in this carburetor. Does anyone know if it is the larger or smaller ball check valve that goes below the pump discharge valve that holds the pump discharge nozzle in place. I originally took the carburetor apart because the accelerator pump was not working, then decided to go ahead and do a complete clean and rebuild. I should have been more careful. Thanks for any help. Jerry
