Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 03/25/2019 09:02 pm
pintos for sale
Date: 12/11/2018 04:29 pm
Date: 05/22/2018 02:27 pm
Date: 08/16/2018 08:54 am
Date: 02/16/2019 10:46 am
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 09/09/2018 03:22 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
  • Online today: 802
  • Guests: 126
  • Total: 126
4 speed gear oil change
Started by Creedmoor, June 28, 2023, 02:37:01 PM
ponyboy
My 1973 2.0L 4 speed does not have a drain plug, but strangely enough it does have two plugs, both on the left side. The BOTTOM one is the fill plug. I don't know what the top one is for. You can pump some of it out, but there is no way to get the sediment on the bottom out, and to me that's the important part. I found a lot of it in the rear axle, and flushed it out with brake cleaner. I don't think these cars were meant to be serviced. There are no grease fittings on the ball joints or tie rod ends.
rob289c
In 1984 I changed a clutch in a 77 with a 4-speed.  I don't recall whether or not there were drain and fill plugs, and because I don't remember, that leads me to believe that there were plugs.  If there weren't, that would have been an oddity and I think I would have remembered that.  The 1982 EXP with a 4-speed had drain and fill plugs.  Granted, it was a transaxle (FWD), so I am 99.9% sure your 80 4-speed will have drain and fil plugs.
rob289c
Creedmoor
1980 Pony, 2.3, 4 speed manual. Wanted to change the lube in the gearbox with some fresh GL-4. However, searching the forum gave mixed results on wether or not there is a drain plug on the trans. So, do these things have drain and fill plugs or not?  If no, besides dropping the trans, are there any methods to perform a lube change?  If it has a fill plug, is it feasible to use a suction pump to drain it?  Appreciate any advice.
