73 rear hatchback glass
Date: 07/06/2017 11:33 am
Date: 12/20/2016 10:47 pm
Date: 01/24/2021 07:54 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
Date: 09/26/2019 05:31 pm
Date: 04/13/2017 04:56 am
Radiator
Date: 05/27/2018 06:07 am
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
  • Online today: 1,438
  • Guests: 1165
  • Total: 1165
Hazard Lights on 1978 Pinto
Started by caravan3921, March 03, 2023, 07:43:59 PM
caravan3921
Pull out to turn on. Push in to turn off. Not up and down.
Hey, thx!! that worked.  For some reason, it just wasn't intuitive to me!
Flasher lights work perfectly. Thx!
Mattb
If you can't get them to work and the turn signals work shouldn't be the flasher since I believe there is only one common flasher. However they do use different  fuses. The hazard lights share a fuse with the brake lights which I believe is fuse # 10. So if stop lights work, not the fuse. Hopefully pulling out on the switch will be the solution.
Mattb
Pull out to turn on. Push in to turn off. Not up and down. If it moves up/down and nothing happens when you pullout perhaps it has become disconnected/broken.
caravan3921
How do I activate the hazard lights on my 1978 Pinto?  I see the hazard switch on the right side of the steering column, but it doesn't move when I try to engage it. It appears to be just an up and down switch but it doesn't move.  Am I missing something?  I googled it but nothing helpful surfaced. Thx.
