Pinto Watch
Date: 06/22/2019 07:16 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 02/28/2018 09:33 am
Date: 01/24/2017 12:36 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 02/27/2017 10:10 pm
Date: 09/12/2018 12:33 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
  • Online today: 292
  • Guests: 287
  • Total: 287
Re-Torque Head Bolts?
Started by rob289c, October 06, 2022, 05:40:41 AM
rob289c
Mine is a 1980 and has 12 pt bolt heads.  I will not be re-torquing.
rob289c
Yeah, retorquing would be ill-advised at this point IMO. It probably wouldn't cause any problems, but it wouldn't mitigate any risk and has the potential to cause a problem you don't have now.
The TTA (torque-to angle) head bolts have six-point heads. "Early" reusable bolts have 12-point heads. I don't know when the switch was made, but that's an easy way to tell what you have. All the 2.3T engines have 12pt bolts, so they were used at least until 1988 or '89.
rob289c
I will heed your advice and leave things well enough alone!  Thank you...
rob289c
As a general rule, no. Some of the later years had the TTY (Torque To Yield) bolts that should not be retorqued! Those you just buy new bolts after a removal. Also, even with an older engine the bolts may have been replaced with TTY bolts. So, considering all that I'd say no.
I have an old Rambler whose 1964 OHV engine is derived off their flathead that originated in 1940. Now THAT engine requires checking the head bolt torque every 5,000 miles.
rob289c
Would it be advisable or discouraged to re-torque head bolts on an old engine that is not being torn down?  I will have my valve cover off during my engine detail process and just curious if that would be a good or horrible idea?  Something tells me it would be a bad thing to do, I should resist the urge, and leave well enough alone.  I am open to comments and suggestions.  Thank you...
rob289c
