Date: 04/30/2023 04:31 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
Date: 02/28/2018 09:37 am
Hatch needed
Date: 09/10/2017 09:16 pm
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Date: 11/23/2017 05:44 pm
Date: 02/18/2017 05:52 pm
Date: 08/13/2021 10:39 am
  • Online today: 1,044
  • Guests: 75
  • Total: 75
'80 Bobcat....steering col + Converter questions..
Started by browniecat, March 03, 2022, 07:20:39 PM
browniecat
Thanks for response(s)..
Tigger... the rag joint was previously replaced, so yeah the play is definitely in that little u-joint (you can feel it if you wiggle the column by hand between rag jt and the u-coupling..). I  have since learned that the ujoint can probably be renewed, but of course that will involve removing the column anyway..
So far as that upper converter...... YES INDEED!  There really is a small converter up there by the manifold, and though I'm pretty certain car does not originally hail from California originally, she's definitely an '80....so there we go!  Yeah, I think that's prob the solution: i.e., a down-pipe from an earlier model...
BUTBUTBUT....prob all academic.. 'cause I'm going to sell the olde girl.  She sure does get a lot of attention (surely more attention than any old car I've ever owned -- quite astonishing, really), but it's a little too challenging as a Daily for me..
Appreciate the input, Boyz....
Hey there, is the play coming from that u-joint or from the rubber rag joint that is lower down closer to the rack?  Typically it is the rubber that fails that causes the play in the steering.
As for the cat that is up by the manifold, I believe that is only an 80 item or possibly a California emissions thing.  I am not sure.  All the other cars 77-79 cars I have owned have never had the small cat up by the manifold.  The one 80 hatchback I had, which donated the engine and the passenger side floor pan to my cruising wagon, had the cat up by the manifold.  I thought it was odd but it looked factory.  I would see if you can just get a down pipe off an earlier car if you want to delete it.
davidpinto
I HAVE A RANGER HEADER ON MINE,I MADE A GASKET OUT OF A SHEET OF ASBESTOS MATERIAL TO COVER THE AIR PORTS,THATS THE WAY TO GO.
D BARHAM
browniecat
Happy Spring, Kidz...  I am sure everybody's looking forward to even MORE expensive gasoline.  Surely the old adage, "you get what you pay for", will apply here too, no?
1980 Bobcat glassback, stock 2.3, 47K miles.... TWO questions....
1.) STEERING COLUMN  u-joint coupling (I'll try to attach photo, but it's not workin) near the firewall.  Have discovered some play developing here.  What are my options here for parts//servicing?  Anyone?  I assume back-in-the-day, you could prob buy the entire column up to the rag joint part, but I'm not really finding anything...  Please share intel if you can.........
2.)  CAT-CONVERTER QUESTIONS....(Why THANK-YOU FoMoCo, for a SECOND CONVERTER, up by the exh manifold!!!  It's provided such joy and pleasure for Pinto owners, 4 decades on...!!!  INSERT SWEAR WORDS HERE...)
I digress..sorry.. SO: Though pretty sure they're not clogged, I'm determined to get these Beasts off the car.  The lower one underneath is straightforward (and after considerable inquiries, I found a shop here that will weld in pipe, no questions asked..).  Now the small converter which is up near the exhaust manifold....Aaaarrrgghhh.....I want this POS gone as well, but of course, there's really limited room to work there.  HAVE ANY OF YOU HAD SUCCESS CUTTING THIS OUT and welding in piping?  Could I use a manifold from a pre-converter-era 2.3 (assuming I could find..)???  Or....I imagine some of you may have installed a header here instead....(??)  ..I was hoping to avoid that bcuz I'm not sure how much longer I'm going to keep car.. Please share your acumen with me if you can.
So any advice on either of these will be greatly appreciated, Lads.  Cheers and regards from NYC.....
