2 Station Wagons for sale
Date: 04/20/2018 11:10 am
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Date: 12/10/2017 01:14 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Clutch Fork
Date: 03/31/2018 09:12 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 12/04/2018 07:40 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
  • Online today: 529
  • Guests: 358
  • Total: 358
Gas gauge finally fixed
Started by caravan3921, December 12, 2021, 07:15:39 PM
caravan3921
Mechanic tells me not to worry too much about the fuel pump, but if I start needing to replace the fuel pump every couple years, then yeah, could look into electrical fuel pump. I'll keep an eye on it. The last fuel pump lasted 15 years. (Watched a documentary on Jay Leno's collection of cars, and Tim Allen's collection. These guys have too much money!) I guess there's another pinto owner in my neck of the Arizona woods. He stopped at the mechanics shop to inquire about my car when he saw it sitting outside. I guess he has 3 pintos and rooms filled with pinto memorabilia!
PintoTim2
What about your fuel pump?    The alcohol in the fuel can deteriorate the diaphragm.   I am in the process of starting to replace all my mechanical fuel pumps with electric ones.   This eliminates the issue of a ruptured diaphragm letting fuel into the crank case.  At one time, Jay Leno said he replaces his mechanical pumps every other year (but he's got an almost unlimited budget and a team to do this...).   I'd be curious if anybody has had issues with mechanical fuel pumps.... So far I've either been lucky, or this was another issue that was overstated....
caravan3921
Can finally give an update after a week in the shop: Recently installed fuel pump was operating correctly. Carburetor had a large vacuum leak, internal and external. Accelerator pump was dripping. Rebuilt carburetor and replaced EGR gasket. Mechanic said that all the additives in today's fuel really does a number on carburetors. No problems driving it home...yeah!
caravan3921
I'll definitely keep you posted! With all the money and maintenance we've put into the car to keep it right and tight, it should be purring like a kitten.
Appreciate your feedback!
I'm wondering it the fuel hoses on what I assume was a new gas tank fuel sender or the connectors at the replaced fuel pump are loose and air is sucking in the line. A good rule of diagnosis is to go back to the last things changed.
caravan3921
Gas gauge working fine but now it kills on me. A new fuel pump was installed a few weeks ago and the mechanic did some carb and choke adjustments. It idles really rough, and then kills. The mechanic says he can come to our house and get it to his shop about 6 miles away. We'll see...I'd feel better if it was towed in. It's only a 31,000 mile car. But at least the gas gauge is working!
caravan3921
Erratic gas gauge started last summer...Finally got it addressed and it appears fixed.
The 2 mechanics at the shop said this was the CLEANEST Pinto they have ever seen!
The problem may or may not have been caused by a creased/dented gas tank. What!? How did the tank get dented?? We saw the crease when the car was up in the air at the shop: it looked as if someone used a tire jack on the gas tank. No scratches or scrapes, just bent upward into tank interior. How did that happen?! We'll never know. Was the dented gas tank the cause of the malfunctioning sending unit, or the defective sending unit the culprit? It's an academic question at this point, I guess. At any rate, both the sending unit and tank got fixed. We bought the car 16 years ago....has it always had a dented gas tank? You'd think some mechanic through the years would have noticed it. There's so much ambiguity in this world, huh?
