Date: 11/11/2019 03:38 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Pinto for sale
Date: 04/19/2017 10:15 am
Date: 05/22/2018 02:27 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Date: 09/12/2018 04:07 pm
73 Runabout
Date: 11/20/2017 03:19 pm
  • Online today: 2,399
  • Guests: 1511
  • Total: 1511
Born 1974 - Died 1996 Resurrected 2021-2022?
Started by PintoRoyL, February 01, 2021, 09:21:27 PM
PintoRoyL
Got home from work and found a brand new water pump setting next to the front door. Yippy!! Will plan on installing it this coming weekend. The correct clutch and pressure plate is expected to arrive about Tuesday of next week. Was busy at work today, I forgot to make calls looking for the rubber grommet between the filler tube and fuel tank.
On yesterday's post, I forgot to mention that I did get the brakes bled after changing the flex hose.
PintoRoyL
davidpinto, thanks for the part number. I'll see if I can make the time to place a couple of calls tomorrow to see if I can locate a new one.
I finished pulling the tank out, drained what was left in it, changed the rear flex hose,  then began working on accessories. I mocked up the position of the oil cooler, then repositioned both the ignition coil,  and the vacuum thingy, so that I could mount the remote oil filter.
davidpinto
i needed one for mine when i put a new sender in the tank.i went to the ford dealership here in town.the part # is E1AZ-9072-B. the dealership has been here as long as i can remember, they didn't have it but they located one in richmond va.i called them and they shipped it to me.it was like 28 bucks to my door.hope this helps....
D BARHAM
PintoRoyL
OK, it's about 5pm Pacific Daylight Savings time, Saturday the 7th. Attempted to install the new clutch kit that I had purchased (it arrived yesterday), turns out that I ordered the wrong one. I ordered for an '88 turbo coupe (that's where the engine came from), but I should have ordered for an XR4TI, because that is the T9 trans going in. Oops. So I ordered the correct one, and will keep the one for 2.3/T5 in case I later run across a 2.3/T5 trans.  Next, I worked to make sure that the fuel tank is near empty. After not getting results with attempting to pressurize the tank with an air hose and a gas can at the other end of the fuel line, I pulled the hoses off the tank and began loosening the straps. Turns out that the tank is nearly empty already. Disconnected the vent line and now the tank is loose. I am a little wary of the rubber grommet where the filler tube enters the tank. Do those damage easily? Can I get a new one if I need to? Will I have to remove the left rear spring to get the tank out without damaging the grommet? I can wiggle the filler spout a little, but it is looking like it might be difficult to get back together by myself later. Should this be a two person operation? Are there any tips/tricks to removing/replacing the fuel tank? I think I will pause and take a breather here. I can still move forward and replace the rear flex hose, then bleed the brakes. The weekend won't be a total loss of time/effort. Maybe I can also mock up the location for the remote oil filter, and the oil cooler.
PintoRoyL
This last Saturday, I torqued the intake/exhaust manifolds, replaced the rear most freeze plug, then bolted and torqued down the flywheel. I was originally going to bolt on the clutch disc and pressure plate, but after looking them over, I decided to buy new ones. I sprayed PB Blaster on the rear brake line junction block, and on the fuel tank strap nuts, to get them ready for removal.
On Sunday, instead of working on the Pinto, I searched the internet for electrical schematics, available tires for 13" rims, browsed that Facebook ad that @Dtmix posted a link to, ordered a new water pump, and a new clutch kit from RockAuto, ordered an oil pump primer tool from Jegs, and also spent money at Amazon.com on non-automotive items. Later in the evening, I went back to RockAuto and ordered a new steering pump for my daily driver Caballero.
PintoRoyL
I thank the three you for the reply regarding 13" tires. I have 7 stock rims actually. Four mounted on the car, 1 as a spare,  plus 2 with studded snow tires. Of course, every tire is 25+ years old, since the last time that the car moved under it's own power was June/July 1996.
Besides tires, I should start thinking about dropping the fuel tank and making sure that it gets cleaned up/out. I should right now, as I am thinking about it, spray some PB Blaster on the fuel tank strap bolts to soak tonight/tomorrow. Sometime over this weekend, I need to put the new rear hose on the brake line junction block, bleed the brake system, replace the rear most freeze plug, install the flywheel, clutch, and pressure plate, and torque both the intake and exhaust manifolds. After that I can make plans to drop the engine back into the car, then when Harbor Freight gets a shipment of transmission jacks back in stock again, I will install the transmission. I got a rain check for their 450# transmission jack when they had their 4th of July weekend sale. The rain check is due to expire on August 3rd, but no stores within 35 miles have had one, so hopefully they will honor the rain check after the 3rd. Being above 60 yrs old, I don't want to have to bench press the transmission into place, then have it hanging by the input shaft until I can get bolts started. Last time I did it that way on any vehicle I own was nearly 4 yrs ago when I did the v6 to v8 swap on my GMC Caballero when I also swapped the factory 3spd stick for a 5spd stick.
One question I still have is, until I reinstall the turbo intake/exhaust manifolds, can I use the old points distributor as long I  am running the old carbed intake/exhaust. I know that the lower part of the shaft is different between the two distributors, but the overall length is the same, and the drive gear is located in the same location as well. I don't yet have the harness for the efi/turbo, although I do have the ecu that came from the Merkur that I got the transmission from.
Dtmix
I looked at Facebook marketplace, and there is a set of four tires, rims, and wheel covers for a 1979/80 Pinto priced $100 for the set.  I believe it will fit the older models as well.
https://www.facebook.com/groups/334722930045666/ Scroll down to July 14th advertised by a Justin Rasp.
Hope that helps?
Happy Motoring!
Dan
Happy Motoring!
Dan
Dtmix
Maxxis Tires produces 13 inch WSW for both 165 and 185 (165 is on backorder with long wait times-I waited for 5 months before switching over to the 185 as I wanted to get the car on the road). Coker is where I got mine from at $169 a piece before Hagerty discount and it is possible you might find them at a lower price if you plow through the internet. https://www.cokertire.com/tires/maxxis-185-80r13.html
Frankly the 3/4 of an inch is hardly noticeable and had very little affect on the odometer, and the WSW was perfectly sized!
I did buy a refurbished Pinto rim to use as a Spare tire, as the one in the car was the space-saver that they used in the 1980 model year. I saved the space saver as it is original and never been down.  I found the rim online by googling refurbished 13" rims for Ford Pintos. Surprisingly, there are a lot out there.  The like-new refurbished ones I got was priced at retail between 60 to 65 bucks (price is back in November of 2020...nowadays, they have gone up.  I have no idea as for why...I found some OEM 13x5 Steel wheel rims are available at Stockwheels.com this afternoon for $65 if all redone (in black) or less if purchased as is and you can redo it by sandblasting and repainting it. It seems pricey...but I was happy with mine.
Happy Motoring!
Dan
Happy Motoring!
Dan
While there aren't many 13" tires available there are "some." Right now the Tire Rack has Kumho Solus TA-11's for sale in 185-70-13" for $71 each. I just think people need to be somewhat flexible on getting a tire "near" original. More so getting a better tire even if it means a slight variation. They also had Laufenn's for $61 but at $10 more the Kumho's are likely a better buy. Federal use to be a manufacture that had a decent selection of 13" tires.
People just need to shop around on line rather than dropping in at their local small town tire store, asking for 13" tires, and getting a big NO (because the demand is low to non-existent)! There isn't a large selection but there are "some" out there on the internet.
PintoTim2
There still is one size tire available for a 13" rim.   There are more sizes in 14" (BF Goodrich Radial TAs are what I like).  You can find rims (Summit Racing had some in 4 bolt pattern).   Even the 15" rim tire choices are very limited (those were the hot size in the 80s).   I think the 14" are the largest rim that look "best" to me on a Pinto (or Mustang II) : that is totally my opinion....   I'm converting my Pintos to 5 bolt rims, there are more 14" or even 15" rims that size available.    Even fox body rims fit on a Pinto - with probably a bolt on spacer on the fronts.   I have found used 14" rims to be very affordable at swap meets.  On my '72,  I have 14" 6" wide turbine style rims on it and they look great (P215 size - but it has custom flares, so I'm not sure if they would fit under stock fenders in the front)
PintoRoyL
Yesterday, I pulled the old brake shoes, and also replaced wheel cylinders on both sides. Finished in time for lunch. Took a two hour break,  then went after the front brakes. Removed and replaced the calipers with brand new ones, installed new flex hoses. Doing the brakes at all 4 wheels, I found that I must have done a brake job shortly before the engine quit 25 yrs ago. The rear had new hardware, springs, and retainers. Rear drums in very good condition. Front pads almost brand new, rotors good. All that is left to do with the brakes, is to buy another bottle of fluid, install the new flex hose on the rear, then bleed the system.
I should probably start looking for tires. I was reading some other threads, it seems that 13" passenger tires are no longer made? That is crazy, aren't there cars new with 13" these days? I guess I'll find out pretty soon. If I can't get 13", are there 14" rims with the 4 bolt pattern?
PintoRoyL
After my morning coffee, I sprayed the engine bay with degreaser and let soak for a couple hours while I ran a couple of quick errands. When I returned, I pressure washed again. I was able to get everything a bit cleaner than I left it after pressure washing last week. Later in the day, I swapped out the old master cylinder for a new one. I am glad that I sprayed the mounting bolts with PB Blaster last weekend, those bolts had me wondering if I would end up with rounded heads. Fortunatly, all turned out well, even with my big hands and small access clearance. After finishing the master, I  removed the rear wheels and brake drums, sprayed PB on the bolts and brake lines to get them ready for the wheel cylinder replacement, and new shoes tomorrow. I feel that the drums are in good enough condition to continue using them, nice and smooth inside, no scars.
I've got pics, but until I am able to add them to my posts, I will have to save them.
I need motivation to get back working on the engine again, not very much left to do. I need to remove it from the stand, replace the large rear soft plug,, bolt on the flywheel, clutch, and pressure plate, torque down the intake and exhaust manifolds, and then it should be ready to set in. I need to either create a wiring harness for the electronic ignition distributor, or put the old points dizzy back in again. I notice that both distributors are slightly different near the drive gear. Can anyone tell me if the old points dizzy will work on a turbo engine block, and not mess up the oil pressure?
PintoRoyL
I bought a pressure washer from Harbor Freight on Saturday. Sunday I hooked it up and washed the engine bay of the Pinto. Did a decent job, but I need to spray some degreaser and wash it one more time. Nearly all of my Pinto brake parts have arrived, so I sprayed PB Blaster on several nuts/bolts to soak. Not sure if I will actually work on the brakes during the weekday evenings, probably will wait until the weekend. Have new master cylinder, rear shoes, and wheel cylinders in hand. New front calipers, pads, hardware kit, inner and outer front bearings in hand also. Waiting on the rear hose, and both front hoses (due to arrive this afternoon). Will decide on new drums and rotors after disassembly.
If you want to "like" a certain person, click on their username, which will pull up their profile.  Then, you'll see on their profile the words "positive" and "negative".  Click on the one which best describes how you feel about that person.  It will automatically add one to their number.
Dwayne :)
PintoRoyL
I have a question. Many people have responded with good advice and suggestions. How do I give their response a "like"? I see a statistic for feedback below their avatar. Does that represent the number of "likes" they have earned?
Yea, when the light bub finally went on and I realized Windows (7 at the time) had the Snipping Tool it was a gamer changer for me. Now if we could only paste pictures into the body of the Forum text like you can into an email that would be awesome! Probably a security reason they need to be attachments???
Dtmix
I didn't have much luck with photoshop...try the snipping tool, as it did the trick! Fingers crossed...
Happy Motoring!
Dan
Happy Motoring!
Dan
PintoRoyL
Sounds easy enough. I tried reducing the size using Photoshop Elements, but they still would not load. My earlier pics were larger,  so I am confused as to why these will not load. I'm not sure if it shows on other's screens,  but my desktop and my phone both show a padlock at the very far right of the screen after clicking on the "your projects" category and scrolling to my thread. It has been that way for quite some time, do you think that I did something to myself that prevents photos from being added? Text posts seem to work, but not when including photos.
Dtmix
Yeah...the picture problem is an ongoing issue.  I learned of a workaround from another Pinto member...
1.) type "snipping tool" in your search-bar on the bottom left screen if you have Windows.
2.) The free app will appear. (Do this once you have the desired picture on your screen first).
3.) Click "New" on the pop-up and shade the area of the picture you want and save it as a new picture to your pictures album.  This reduces the size of the picture.
4.) Once you are posting on the Pinto forum, you click attach "choose file" below your posting and select the snipped picture that you have saved. (Note: Although it says you can do four per post, but I suggest no more than two per posting as the size would exceeded).
5.)  If you wish to do more than two, just type "continued" and "post" at the end of your first post.  This will let the reader know there's more pictures coming.  Once posted, you click "reply" to create the next post and upload two more pictures.
I hope my directions is clearer than sludge in a barn-find Pinto?  If not, let me know and I will try to create a screenshot tutorial...
Happy Motoring!
Dan
Happy Motoring!
Dan
PintoRoyL
I spent this weekend mostly working on the Pinto motor. Replaced the old timing belt and tensioner with new, removed the tbird oil pan, installed new high volume oil pump and new pickup tube, drilled out plug for the dip stick, installed the Pinto oil pan. Removed motor mounts and brackets, installed new mounts in correct brackets on '88 engine, exhaust gasket and manifold is lightly snugged on, and intake manifold is loose with two bolts so that I can measure/cut all of my new hoses. I had also replaced the 4 expansion plugs that I can reach (3 under the exhaust, 1 at the rear of the head) until I remove the engine from the stand (then I will get the large one at the rear of the block).
I ordered brake parts a couple days ago, new master cylinder, rear wheel cylinders, front disc pads. Picked up both front calipers at NAPA yesterday. In writing this, I realize that I need to order rear brake shoes, plus I need to order new clutch plate and disc. I have a needle bearing pilot bearing, throw out bearing already. The engine block half of a remote oil filter adapter is installed, and an oil cooler is on the way.
I am happy with what I got accomplished over this weekend, considering that I am the only able bodied person at home, taking care of my wife, and the pets, and the shopping.
Quote from: PintoRoyL on June 19, 2021, 10:21:16 PM
I resized my pics to less than 1MB each. Let's see if they work now.
Later post: Pics still not working.
Near 1 MB would still be three times too big. Got to get them individually down below the number I circled in red (Image below, click on it to enlarge, read it). And frankly that limit will make for a very large image that the slide bars will be needed to sectionally view the picture. Usually when I post an image to a forum they are between 50KB and 150KB. And the 150KB images pretty much fill the screen. For reference the image I'm displaying here is a mere 24KB. Unfortunately the resolution a modern phone/camera is capable of, and the capacity to display/store the image on Forums like this are worlds apart.
PintoRoyL
PintoRoyL
If the pics are here, the first is with engine ready to pull out, the second, engine/trans hanging on the hoist.
Roy,
Glad to see that you're able to post again!  Wish I could be of some help with the photo issue but I've never been able to post pictures either.
Dwayne :)
PintoRoyL
Have been trying to post since Memorial weekend to provide an update. On Saturday, May 29, I noticed that the birds nesting in my engine hoist had gone. I decided to wait one more day, just in case. On Sunday the 30th, with no parent/fledgling activity, I began disconnecting all of the ancillary connections for the engine removal process. I got everything ready under the hood. I disconnected all of the electrical, vacuum, ign coil, throttle cable, pulled the fan and radiator, ect., ect., then sprayed all of the major bolts with PB Blaster to soak overnight. On Monday the 31st, I disconnected the stick shift handle, removed the driveshaft, motor and trans bolts/mounts, speedo cable, backup light wiring, exhaust pipe flange, clutch cable, and fuel lines. I then hooked the load leveler to the hoist and pulled the engine/trans as one unit. The old engine/trans is now in the carport alongside the engine that is going to go in, while the 5-spd trans to be connected to it, is in the garage.
My next objective is to remove/swap the intake/exhaust manifolds from the old engine to the one going in to the car. As I looked for gaskets at Rock Auto, I saw that there are three different gasket types; a round, an oval, and a "D" type. I need to make the time to see which type I will need, and I am hoping that both heads use the same type.
Something is up with my computer I think. when I tried to update over the last couple of weeks, I was also trying to include pics. I kept getting some sort of error message, or a message that I had double posted. As you can see the two previous posts to this one, I have figured out that I can post, but only without pics. The pics that I was trying to include are smaller than 3MB, so I can not figure out why they will not work. Maybe the wrong format? They are JPEG's, so I don't know why they don't work.
PintoRoyL
Cannot post including pics, error page pops up.
Seems to work without pics
PintoRoyL
Although the T9 is not as strong as a T5, they are perfectly fine in a stock or mildly modified XR4Ti and would have an easier time in a Pinto due to the lighter weight. In fact, if yours has a 6.75" rear, that is probably the weaker link. The European crowd also mentions that a stock T9 gets balky to shift at high RPM, but a 2.3T is unlikely to rev that high without a lot of work. They were putting them behind built 2.0s and Cosworth 2.0s that twist 7500+. A 2.3T that can do that with purpose will be making way too much power for the gearbox anyway.
If you have an '85 ("E3") turbo manifold with the round bosses on each runner, look it over to make sure it isn't cracked. They often do between 2 and 3. The '85.5+ E6SE manifold is much less likely to crack and it flows better.
PintoRoyL
I was raised down there in Cypress/La Palma. When in my 20's, I most often visited the Pick-a-Part up near La Mirada. It seems to me that there was also a self-serve wrecking yard on Beach Blvd, down the road from Knott's Berry Farm that I had used occasionally (30+ years ago). I am living immediately south of Seattle, Wa. now, and most of the yards here are not self-serve, but we do have Pick-n-Pull which is self-serve. I am right in the middle of four of them, one each, 25 and 50 miles north, and 25 and 50 miles south. You talk about HAPPY, my wife is not thrilled about me working on the Pinto, she has no appreciation for "classic" cars, but getting to the yards is therapeutic to me, I get a chance to relax and be with my own thoughts and imagination.
I'm currently thinking that I will install the  turbo coupe engine using the NA manifolds and carburetor from the old motor for a time to 1) see if the motor even runs, 2) to operate the vehicle a bit to see what 25 years of deterioration has done to the various systems, ie: brakes, electrical, ect., and 3) take the time to learn how efi and turbo systems work.
Glad to hear you are finding obscure parts. Regarding the T-9, how strong 'strong' needs to be is probably how you drive the car. If you are not inclined to fabricate and drive with reasonableness it should be OK. The Murkur harness is actually desirable. It is a stand alone. The Turbo Coupe has everything comingled together and the 87/88 years are the worse. I spent DAYS sorting through my 88 harness and still had about 20 wires I wasn't sure of. But I was using the T/C steering column and that entailed a lot of extra consideration (click on image to enlarge). NOTE THAT ALL THE COMPUTERS ARE PINNED DIFFERENTLY!!! So, whatever harness you wind up using make sure the right wires go to the right pins.
Curious, is this a self serve yard you found the Murkur in? Up until about 2016 I went to the Pick Your Park 50% off sales every month. Then I'd go over the U-Pull Parts yard. Unfortunately the U-Pull Parts yard folder in 2016 (it is now a Copart yard). And the Pick Your Part yard now thinks mid 80's Mercedes and early Miata's are "collector cars." What had been a large part of my "car life" for 20+ years came to an abrupt end. I'd get there at 6:30AM (after a 45 mile drive) and stay at times until closing at 6:00PM. It would be 100+ degrees and I'd be filthy and HAPPY! Anyway, back to Murkur's. Occasionally I'd se one in the early 2000's. Then nothing for years. I was in the Stanton Pick Your Part one day (maybe around 2008?) and there were four side by side. Then I never saw another the past 12 or so years. So, I'm glad that you found a Murkur. It is quite a rare find.
