1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 08/17/2022 06:27 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Seeking parts
Date: 10/18/2020 10:35 am
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 2,399
  • Guests: 1417
  • Total: 1417
Bolt on Cowl scoop?
Started by Tonycando, December 05, 2020, 02:00:38 PM
entropy
Quote from: Tonycando on December 07, 2020, 09:51:02 PM
Has anyone ever put a teardrop scoop on a Pinto,curious how this would look. Might have to. Uh one just to see..
You mean like the one on a T-Bolt?  They're generally too long and just don't fit.  What I was going to do before a fiberglass cowl hood fell into my lap was use a scoop for a '70 AMX and mount it backward.  Forward could work, too.
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Tonycando
Found one on eBay that's 5" tall and 26" long. I think it should be the one. I'll post pics when it gets here.
Tonycando
Been down that search. That one looks different then the one on the car
Tonycando
One of the nicest Pintos I've seen. It needs a bigger tire IMHO. But that scoop is perfect,looks like a modified Boss 429 scoop. Anyone know this car or if that scoop is available ?
I agree. Took some pics etc anyway.....
Prop rod was shortened by original builder.
From center of radiator support to center of hood lip is 26"
Cardboard is taped onto my scoop & is 4 3/4" high over the cowl.
Clearance over cowl with hood up is 4 1/4"
Using a steak (Lath) to hold the hood up front center at 41 1/2" high.
Back has 1 3/4" clearance. (very close to wiper, but I need a higher one anyway)
Tonycando
Yes the top swoop over a bit but it dries not look right to me  it out of proportion with the front end I think
One left click & they pop up bigger.
Looks like the back is over the cowl some & only front pins.
I'll be in my shop later today. I'll lift the hood & take a pic or measurement of the clearance.
Tonycando
Looks like it already is up to the cowl  ? I guess if the hood is pinned on that's ok but hinged probably won't work ?
HOSS429
make it longer in the back and that is a good look .
Tonycando
Kinda what I'm looking for   Also seen a pic of a black 71 with a over grown Boss 429 scoop that looked real. Ice.
Tony - found these pictures this morning...
Dtmix
Now, I am worried about my Valance project...i was concerned about the primitive website he has, but when I spoke with him, I figured he wasn't all that tech-saavy which is common with a number of old school mechanics. I noticed from my communications with him that he responds to his email address that has his name Rob in the email...I will look it up for you...it's something like rob@showcars etc. Thanks for bringing to my attention of the reviews and I will keep all of you posted as for my valance panel. I hope that I will see it again...sigh. Fingers crossed.
In the meantime, I will keep my eyes peeled for hood scoops for you.
Despite this possible hiccup, Happy Motoring,
Dan
Happy Motoring!
Dan
Lots of bad reviews on line about Showcars unlimited Foxboro Ont.
Tonycando
Thanks Dan
I've spoke with him and he offers a hood and I asked for pics as it's not on his website or I couldn't find it but have not got a response back from him  ? If what he has fits my vision I have for my build I would have bought it already but was not sure how his product is if his response is like it is.
Dtmix
A while back, someone on this site mentioned showcars unlimited in Foxboro, Ontario as they make hood scoops, body cladding, and air dams for Ford Pintos. I am working with them in reproducting a lower front valance panel for my 1980 Pinto. You might want to contact them or look at his website for suggestions. Although he has been receptive and communicative with me, but I am unable to say anything as for his work as I am still in the early stages with him as for the valance panel. His name is Rob and his website can be found by googling Showcars unlimited Foxboro Ont.
Happy Motoring,
Dan
Happy Motoring!
Dan
Tonycando
I'll have to measure that up ,I'm pretty sure it can't go to high without the frame interfering with the lower hose  I'm thinking that will dictate the height. I'll play with it in Sat
I've had to cut the valance on all the cars I did. However, if you cut the hood bump out & mount the radiator higher, you may get away with no, or very little cutting.
In line thermostat
Had to make a 45 for the lower radiator hose. Cut it & had a shop in town tig a bead on each end to hold the hose on.
Last radiator didn't need this as it was more narrow.
If you left click the pics they should show bigger. No idea what will happen with those new fangled phones.....I still use a flip phone  ;D
Tonycando
So did your top nose go through the rad support and the lower hose go under the front frame and then up to the pump ? ,with this one they sent me I'll have to cut the front valance for the rad to drop down ?
Tonycando
Yes might work still with mine. Just wanted to be between the front tabs is all.
Top view of radiator
Right bumper bracket
Right side radiator / bottom support
Mine is 28 1/2" wide, 19 1/2" tall and 3 1/4" thick.
The tabs sticking out on the front of the frame rails were bent over (or cut off & welded up).
The bumper brackets were modified. The straight pieces were cut off at the end on the frame rails & another piece welded to the outside piece.
This pic is the one off of the blue car.
The hood was modified to get the Radiator higher.
If you need more pictures let me know.
Tonycando
What really blows is my alum rad comes in today and the shipped me a 26" instead of a 24" wide unit by mistake,bummer is they don't have anymore 24" units.back to the drawing board I guess.
Tonycando
Yes taller,I set my engine according to the header clearance,as far back as possible to maintain rack clearance..My cleaner is 5" from the cowl
I know very little about 351C engines.... but are they taller I think ?
Tonycando
Yep. Looks like it won't work.
Blue car. Carb has 1" to the cowl lip.
Had to cut the old scoop to get the hood on. That is a (too small) 9" K&N filter.
To the engine compartment seal surface it is 5 3/4"  or 10 1/2" to carb center
Absolute min scoop height for mine will have to be 5" , but 6" will be better.
The hood support under the back will also need some cut out, so a bigger air filter can be used.
Blue car will be much worse for clearance.
