1975 Ford Pinto
Date: 01/13/2020 11:02 am
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 10/31/2018 12:00 pm
Date: 05/19/2018 04:56 pm
Date: 07/30/2020 11:45 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Date: 01/28/2019 05:15 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
  • Total Topics: 16,268
  • Online today: 620
  • Guests: 439
  • Total: 439
72 pinto coil springs
Started by pinto1955, November 01, 2020, 06:38:33 PM
I have a set of 71 springs if you're interested
Also, there might have been 2.3 and V-6, 2.8 springs. I'm not sure on that but it should be given consideration to check. Yes, as noted cutting the springs will be necessary. It is sort of a double effect. The later springs are designed for heavier weight and thus stiffer. And cutting the spring will make it even stiffer still. So, know that going in so it will not be a surprise to you.
Yes they will, but you'll have to shorten them and a little shortening goes a long way.
pinto1955
Does anyone know if later model coil springs fit the 71-73 models. Coil spring don't seem to be available.  Thanks, Don
1972 Ford Pinto SS/MC, HP 2.0, 4 speed, 9" full spool w/6:50 gears
