Date: 03/30/2021 12:29 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Date: 01/24/2021 07:54 pm
Date: 08/30/2018 12:59 am
Bell housing
Date: 08/23/2017 05:41 am
Date: 07/20/2017 01:23 am
Date: 10/10/2019 10:02 pm
pintos for sale
Date: 12/11/2018 04:29 pm
  • Online today: 306
  • Guests: 128
  • Total: 128
uneven fuel distribution in 2.0
Started by LongTimeFordMan, October 17, 2020, 01:13:01 PM
LongTimeFordMan
the primary is on the inside toward the engine...since the weber is reverse of the holley 5200
The SUs worked well but i had the.same.problem.with 2,3 running rich and 1 ,4 lean.with the new manifold. the other one with the plenum had better distribution
i think it was charge robbing..
im re doing the new one to have a plenum
Are the primaries on the inside or outside. If inside then likely yes the design might be the issue as the air/fuel would follow the shortest path and 1-4 cause the flow to need to pull away to the outer runners. What happened with the SU's?
LongTimeFordMan
hi..
has anyone experienced uneven fuel.distribution between cyllenders in a 2.0?
I installed a new factory jetted weber DGV on my 73 wagon and drive moderately daily. manual choke always full open except to start.
Stock rebuild, 5000 miles, stock cam and cyls 2 and 3 run rich but 1 and 4 lean.
no vacuum leaks, compression 170 +- 10 on all cyls.all.ign wires good. pertronix flame.thrower ign.
car runs ok,  16-18 MPG in town 23-26 on the highway.
the weber primary and secondary are reversed from the original 5200. i suspect possibly just the manifold design?
