Date: 08/22/2017 09:21 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
Date: 11/14/2019 04:02 am
Date: 02/18/2017 04:41 pm
1979 pinto
Date: 04/19/2018 02:02 am
Date: 12/09/2016 08:34 am
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
  • Online today: 148
  • Guests: 131
  • Total: 131
Ignition Timing Question
Started by WTodd6, August 18, 2020, 08:49:42 AM
Exactly why, I don't know. But a fair guess is that it either had to do with smog specifications or to compensate (idle in particular) for the awful smog devices of the day. It might also be how the timing was measured. There is  possibility that certain cars were set with the vacuum advance attached and that would elevate the timing at idle (hence the 6 vs 20 degrees) but upon acceleration timing would drop.
When one observes the smog devices of the 70's/80's it seems as if there were teams assigned to certain RPM ranges each designing a separate device and then they were just thrown onto the engine thinking it added up to a collective whole. I'm not saying it was that way, just that the end result has the appearance of such.
Even the OBD I injection was a significant advantage over the carburetors of that time era. Some here have gone to the add on injection systems* while others have just adapted a complete engine swap from the 80's/90's Mustangs or Rangers.
* https://www.youtube.com/watch?v=J8iNcUku7jU
WTodd6
Why did ignition timing go from 6 degrees tdc to 20 degrees tdc on 2300 with auto trans from 1975 to 1976?
