1975 mercury bobcat
Date: 08/14/2018 03:40 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Date: 11/05/2020 06:32 pm
Date: 09/01/2017 11:58 am
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 11/04/2018 02:34 am
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Date: 09/03/2018 08:58 am
  • Total Topics: 16,268
  • Online today: 265
  • Guests: 129
  • Total: 129
That's a pretty sharp looking Mustang!
rob289c
I did nothing on my project over the weekend.  We had our car club's show on Saturday.  I was on site at 0600, did the last minute setup tasks, parked 260 cars between 0730 and 1300, then passed out fliers for an upcoming cruise in, then did the tear down and clean up.  Got home about 1630.  Long day in the 90 degree sun! The show was a huge success...not one Pinto though.  There was one '77 Mustang II, 302 car.  Maybe next year my project will be done and it can be on display.  The attached pic is my Mustang in the member's row (display only) as the sun was rising...
rob289c
1972 Wagon
No matter how much you got done, it is all helping you move towards the finish line! Thanks for the update on your project. Enjoy the birthday party!
Delivered: June 20, 1972
rob289c
Last weekend I made a little progress. I torqued the header bolts.  I made one wiring connection where one on my temp crimps from 3 or 4 years ago came apart.  I epoxied a crack on the back side of the shifter bezel, then painted it.  I may have done a few more things but I don't remember what they were.  My car club is holding a car show tomorrow so my day will be there and Sunday I have to go to a great-niece 1st birthday party so that day will be unproductive too.  Going to a cruise in soon to do a last ditch show flier distribution mission.
rob289c
rob289c
I hope to have more progress to share this weekend.  I am going to lose a lot of Sunday to a car club picnic and representing the company I work for at the County Fair.  I will have to make the best of Saturday.  Summer is short in NY State and so many activities are packed into a short amount of time.  I am edging closer to getting ready to (hopefully) hear it run.
rob289c
1972 Wagon
Sounds like you made quite a lot of progress! Every week, I look forward to reading your posts to see what you accomplished on your project. It's getting there!
rob289c
Plug wires and Voltage Regulator.
rob289c
rob289c
Some progress today:  Gapped and installed new spark plugs and wires.  Checked that the rotor was still pointing at #1 tower on the distributor cap after rolling it over during the valve stem seal replacement process (it is).  Found a spot to mount the voltage regulator that allows the harness to plug in.  Attached the leads to the temp and oil pressure idiot light sending units.  Attached the power lead to the rear of the choke assembly.  It is a flat, blade type connector.  There is another round, push on lead that I labeled "Choke" when I disassembled but I don't see anywhere that it will connect to.  Can anyone guide me to where it goes? There is a pic attached that shows the one lead plugged in at the rear of the choke assy, and the lead with blue tape is the one I need to know where to attach it to.  I mounted the coil mount to the intake using the bolts that attach the EGR block off and installed the coil.  I hooked up the coil leads that came with the new Duraspark II wiring kit.  I connected the distribotor leads to the wiring kit. I need to make some wiring repairs before I plug the leads from it to the ignition module.  I have to think about how I am going to do this, then buy the appropriate wiring repair parts/components. I tested the horn with jumper wires and my lawn mower battery (it works) and found my spot to mount it after I prime/paint the back side of it. I ran the front parking lamp leads and installed the sockets into the grill-mounted receptacles. Can anyone tell me how the spark plug loom attaches to the Ranger-style valve cover? It's different than my stock Pinto valve cover.  Once I get the wiring straightened out, I can add fluids and try to start and run it!  I'm getting there!
rob289c
rob289c
I didn't do much on my project this past weekend.  I mounted the ignition module and voltage regulator but realize now that I will have to relocate the voltage regulator.  The wiring harness is too short to connect it where I have it.  I'd rather relocate it than cut and lengthen the harness.  That just creates future electrical gremlins.  I located my Duraspark II wiring kit, looked it over and read the instruction page that came with it.  It comes with an optional ballast resister that I am 99% sure I won't need to use.  My car came with Duraspark II and it doesn't have the Chrysler style resister so I'm not going to wire it in. The kit will take the place of some questionable ignition circuit wiring.  I am likely going to try those connecters that have solder in the middle that you use a heat gun to melt it and it also serves as heat shrink.  I think a little pricy but better than crimp connecters.  There is some other questionable wiring done by the previous owner and temp wiring done by me just to get it to run that I will also take care of.  My biggest issue is time.  In NY the weather sucks a good part of the year so I have a lot of things to cram into a short period of time and there are other obligations beyond my car project.  I had three events to attend on Saturday and next Saturday will be similar.  It's all good.  I have a blessed life.  Maybe more to report after next weekend.
rob289c
rob289c
Got a few things done today...first thing I did was introduce about 8 psi of compressed air into the oil pan drain to see if I could feel any air leaking at the rear oil pan seal. I didn't but I'm still concerned that I didn't get the seal properly oriented when I installed it last weekend.  For now, I am moving on from that.  I got the under-hood wiring harness out and cleaned it with Simple Green.  I then put it in place.  I mounted the starter relay, and attached the positive battery cable, starter cable, and the other two wires.  I secured the harness to the firewall and then temporarily ran it down the firewall to radiator supports.  I am going to have to re-wire the entire ignition circuit.  It was a mess when I got the Pinto and I half-assed wired it with a combination of new and old wiring to get it to run before I disassembled the Pinto.  I will do it correctly now.  I bought a DuraSpark 2 wiring kit that has most of what I will need.  I think it is for wiring up DuraSpark in a car that didn't originally come with it.  I bought it about 5 years ago so I will dig it out of storage and get ready to get to it.  I have to figure out where to mount the ignition module, voltage regulator, and coil.  The fender wells no longer exist so I need to find new spots.  I also replaced the power steering return hose from the pump to the cooler.  I think that was it for today.  I spent the rest of the day trimming shrubs, lopping off tree limbs, cleaning up the debris, mowed, then moved two pickup loads of firewood from a wet spot to a dry spot. Maybe more tomorrow...
rob289c
rob289c
My oil pan gasket arrived yesterday around lunch time.  Around 2:00 I started re-installing the oil pan.  Royal PITA doing it from under the car vs while it was on the engine stand.  The side gaskets went on just fine but the end gaskets are the challenge.  I couldn't see the rear end of the pan so I am hoping and praying that I was able to get that gasket in place.  The front I am 98% sure it's in correctly; I wish I could say the same about the rear.  I will know when I start it!  I had a little issue yesterday when dropping the engine back on to the motor mounts.  The right side would't line up.  Essentially, the orientation was off and the starter is resting on the crossmember.  The front wouldn't drop down low enough for the bolt holes to align. I had to leave it as I promised my wife I would take her out and it was almost 7:00 when I finally called it a day. This morning had to jack the tranny under the trans mount to drop the front of the engine, loosen the engine mount from the engine, then I was able to pry it into position.    While I was waiting for the gasket, I manufactured the starter relay to starter cable.  I also cleaned up the shifter assembly. Last weekend I had sprayed the valve cover with Satin Black engine paint.  Yesterday I sanded the ribs to natural aluminum.  I installed it on the engine this afternoon. I made progress but a lot of the work I did was my own fault for dropping the valve keeper down into the oil pan. I'll do more on it next weekend...
rob289c
rob289c
Oil Pan Gasket should be here on Friday so this weekend I will put it back together.  I like the idea of thread holding the gasket in place.  I will use that tip.  I primed/painted the valve cover but have to sand the ribs before installing.  The clips I will use to hold my windscreen in place should be done soon so I can get that in place before putting the dash and pash pad in while I still have access. Getting there...
rob289c
I guess I'm too late to comment but I'd have tried a thin tube hooked to a vacuum and see if it would draw it up.
Regarding the gasket on the pan. I found a few pieces of thin thread through the bolt holes to keep the gasket from moving can be helpful. Once I get a few bolts in and everything aligned I cut the thread and pull it out. Otherwise you fight keeping the gasket in place.
I paid the ridiculous Calif. registration ($148) for my Pinto and here it is due again in late August..., and I haven't driven the car yet. Also, got a great deal on a battery when Advance Auto folded ($60 for a 800 CCA battery) and used it ONCE to start the car. I'm getting too old, too slow and the wife keeps coming up with major projects. So, don't feel too bad about how long your project is taking. I think it is an Epidemic afflicting the car community. :(
rob289c
Yesterday I removed the steering rack, removed the starter, then dropped the oil pan.  I was not able to completely remove it...maybe if I removed the tranny cooling lines and sway bar I may have created enough clearance. I was able to drop it enough to reach in and retrieve the valve keeper.  That was enough car work so I went out and weeded the garden until it was time to get ready to go to our daughter's place for the Independence Day celebration.  This morning I went back out and completed the rest of the valve stem seal project (after plugging the oil return holes!  ;D ).  I hope I never have to do this job again!  It is a PITA trying to reinstall the keepers!  Next mission was to clean the oil pan and block mating surfaces so I can reinstall the oil pan.  Because I couldn't completely remove it I had to do it the hard way under the car.  Using lacquer thinner, gasket scraper, and small wire brush, I got it pretty clean.  Not as good as when I did the job on the engine stand but unless I do a crappy job installing the gaskets, it should seal just fine.  I still need to wipe out the little bit of oil and moisture from the compressed air that's in the bottom of the oil pan but will do that just before reinstalling.  I will order the gasket after I post this update.  I'd like to get this thing buttoned up so I can continue on with the project.  I also decided to strip the paint off the valve cover. It was Ford Blue when I got it, then sprayed it black with crappy, non-engine paint just to see what it would look like.  Three applications of aircraft paint stripper and power washer cleaned it up so tomorrow I can prime and paint black with hi temp primer and paint.  I'll be back at it after the oil pan gasket arrives...
rob289c
alwaysFlOoReD
rob289c
I got home from my 2.5 month Michigan assignment on May 23.  I was faced with all the "must do" chores that didn't get done while I was away.  Yesterday was the first time I worked on my project since I put it away last Winter.  Yesterday was the day I was to replace the valve stem seals.  I didn't remove the head when I had the engine out of the car so replacing the valve stem seals may be a futile mission if there is a valve, head or gasket issue but I had them so I decided to change them out.  I have been stressing about this for a year but got at it.  I watched videos, read forums and got advice from members in this group.  I did the compressed air method.  I have my KD 3087 valve spring compressor that while not the easiest to use, it allows me to do the job with the head on the engine and the engine in the car.  It makes it easy to get the cam followers out.  Getting the valve keepers out is easy; putting them back in can be challenging.  I did #1 exh and intake, and #3 exh.  I was into #3 intake and I dropped a keeper down an oil return hole.  I heard it drop into the oil pan.  Now I have to drop the pan to retrieve the keeper.  Extra work that I didn't want or need.  Based on the placement of the oil return hole, I believe the keeper is in the upper/rearward part of the oil pan.  I don't know what it's going to involve but it doesn't look like a fun or easy job.  I did a real good sealing up the pan while it was on the engine stand so it will be a bitch getting it apart, cleaning the mating surfaces and re-sealing.  I have no one to blame but myself.  I should have plugged the holes.  If anyone has tips, I am all ears.  Otherwise I will study this forum and others that I can find.  After my self-inflicted wound, I decided to drown my sorrows by replacing a toilet flush valve. The 25 year old tank to bowl fastener threads were corroded so it required heat and a 2nd person to hold the LARGE screwdriver while I heated and turned the nuts from the underside.  Finally got it and completed the repairs.  Back to the car project, I think today I will try to remove the starter to get it out of the way and get a better idea of what removing the pan will involve.  I have other projects to do so I don't expect to get a lot done on my project today.  I need a break from it.  Hopefully I will have good news to report shortly.
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
