2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 06/30/2018 09:48 am
Date: 07/01/2019 12:23 pm
Date: 08/01/2018 01:27 pm
Date: 07/04/2022 07:55 pm
72 pinto drag car
Date: 06/22/2017 07:19 am
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 03/06/2019 06:40 pm
Date: 06/18/2018 03:47 pm
  • Online today: 531
  • Guests: 195
  • Total: 195
rob289c
My oil pan gasket arrived yesterday around lunch time.  Around 2:00 I started re-installing the oil pan.  Royal PITA doing it from under the car vs while it was on the engine stand.  The side gaskets went on just fine but the end gaskets are the challenge.  I couldn't see the rear end of the pan so I am hoping and praying that I was able to get that gasket in place.  The front I am 98% sure it's in correctly; I wish I could say the same about the rear.  I will know when I start it!  I had a little issue yesterday when dropping the engine back on to the motor mounts.  The right side would't line up.  Essentially, the orientation was off and the starter is resting on the crossmember.  The front wouldn't drop down low enough for the bolt holes to align. I had to leave it as I promised my wife I would take her out and it was almost 7:00 when I finally called it a day. This morning had to jack the tranny under the trans mount to drop the front of the engine, loosen the engine mount from the engine, then I was able to pry it into position.    While I was waiting for the gasket, I manufactured the starter relay to starter cable.  I also cleaned up the shifter assembly. Last weekend I had sprayed the valve cover with Satin Black engine paint.  Yesterday I sanded the ribs to natural aluminum.  I installed it on the engine this afternoon. I made progress but a lot of the work I did was my own fault for dropping the valve keeper down into the oil pan. I'll do more on it next weekend...
rob289c
rob289c
Oil Pan Gasket should be here on Friday so this weekend I will put it back together.  I like the idea of thread holding the gasket in place.  I will use that tip.  I primed/painted the valve cover but have to sand the ribs before installing.  The clips I will use to hold my windscreen in place should be done soon so I can get that in place before putting the dash and pash pad in while I still have access. Getting there...
rob289c
I guess I'm too late to comment but I'd have tried a thin tube hooked to a vacuum and see if it would draw it up.
Regarding the gasket on the pan. I found a few pieces of thin thread through the bolt holes to keep the gasket from moving can be helpful. Once I get a few bolts in and everything aligned I cut the thread and pull it out. Otherwise you fight keeping the gasket in place.
I paid the ridiculous Calif. registration ($148) for my Pinto and here it is due again in late August..., and I haven't driven the car yet. Also, got a great deal on a battery when Advance Auto folded ($60 for a 800 CCA battery) and used it ONCE to start the car. I'm getting too old, too slow and the wife keeps coming up with major projects. So, don't feel too bad about how long your project is taking. I think it is an Epidemic afflicting the car community. :(
rob289c
Yesterday I removed the steering rack, removed the starter, then dropped the oil pan.  I was not able to completely remove it...maybe if I removed the tranny cooling lines and sway bar I may have created enough clearance. I was able to drop it enough to reach in and retrieve the valve keeper.  That was enough car work so I went out and weeded the garden until it was time to get ready to go to our daughter's place for the Independence Day celebration.  This morning I went back out and completed the rest of the valve stem seal project (after plugging the oil return holes!  ;D ).  I hope I never have to do this job again!  It is a PITA trying to reinstall the keepers!  Next mission was to clean the oil pan and block mating surfaces so I can reinstall the oil pan.  Because I couldn't completely remove it I had to do it the hard way under the car.  Using lacquer thinner, gasket scraper, and small wire brush, I got it pretty clean.  Not as good as when I did the job on the engine stand but unless I do a crappy job installing the gaskets, it should seal just fine.  I still need to wipe out the little bit of oil and moisture from the compressed air that's in the bottom of the oil pan but will do that just before reinstalling.  I will order the gasket after I post this update.  I'd like to get this thing buttoned up so I can continue on with the project.  I also decided to strip the paint off the valve cover. It was Ford Blue when I got it, then sprayed it black with crappy, non-engine paint just to see what it would look like.  Three applications of aircraft paint stripper and power washer cleaned it up so tomorrow I can prime and paint black with hi temp primer and paint.  I'll be back at it after the oil pan gasket arrives...
rob289c
alwaysFlOoReD
rob289c
I got home from my 2.5 month Michigan assignment on May 23.  I was faced with all the "must do" chores that didn't get done while I was away.  Yesterday was the first time I worked on my project since I put it away last Winter.  Yesterday was the day I was to replace the valve stem seals.  I didn't remove the head when I had the engine out of the car so replacing the valve stem seals may be a futile mission if there is a valve, head or gasket issue but I had them so I decided to change them out.  I have been stressing about this for a year but got at it.  I watched videos, read forums and got advice from members in this group.  I did the compressed air method.  I have my KD 3087 valve spring compressor that while not the easiest to use, it allows me to do the job with the head on the engine and the engine in the car.  It makes it easy to get the cam followers out.  Getting the valve keepers out is easy; putting them back in can be challenging.  I did #1 exh and intake, and #3 exh.  I was into #3 intake and I dropped a keeper down an oil return hole.  I heard it drop into the oil pan.  Now I have to drop the pan to retrieve the keeper.  Extra work that I didn't want or need.  Based on the placement of the oil return hole, I believe the keeper is in the upper/rearward part of the oil pan.  I don't know what it's going to involve but it doesn't look like a fun or easy job.  I did a real good sealing up the pan while it was on the engine stand so it will be a bitch getting it apart, cleaning the mating surfaces and re-sealing.  I have no one to blame but myself.  I should have plugged the holes.  If anyone has tips, I am all ears.  Otherwise I will study this forum and others that I can find.  After my self-inflicted wound, I decided to drown my sorrows by replacing a toilet flush valve. The 25 year old tank to bowl fastener threads were corroded so it required heat and a 2nd person to hold the LARGE screwdriver while I heated and turned the nuts from the underside.  Finally got it and completed the repairs.  Back to the car project, I think today I will try to remove the starter to get it out of the way and get a better idea of what removing the pan will involve.  I have other projects to do so I don't expect to get a lot done on my project today.  I need a break from it.  Hopefully I will have good news to report shortly.
rob289c
rob289c
rob289c
1972 Wagon
Delivered: June 20, 1972
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
rob289c
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
rob289c
rob289c
