Date: 01/28/2017 12:30 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
1972 Pinto for sale
Date: 05/19/2021 12:41 am
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 10/11/2019 11:13 am
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Date: 05/22/2018 01:54 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
  • Online today: 489
  • Guests: 301
  • Total: 301
rob289c
I got home from my 2.5 month Michigan assignment on May 23.  I was faced with all the "must do" chores that didn't get done while I was away.  Yesterday was the first time I worked on my project since I put it away last Winter.  Yesterday was the day I was to replace the valve stem seals.  I didn't remove the head when I had the engine out of the car so replacing the valve stem seals may be a futile mission if there is a valve, head or gasket issue but I had them so I decided to change them out.  I have been stressing about this for a year but got at it.  I watched videos, read forums and got advice from members in this group.  I did the compressed air method.  I have my KD 3087 valve spring compressor that while not the easiest to use, it allows me to do the job with the head on the engine and the engine in the car.  It makes it easy to get the cam followers out.  Getting the valve keepers out is easy; putting them back in can be challenging.  I did #1 exh and intake, and #3 exh.  I was into #3 intake and I dropped a keeper down an oil return hole.  I heard it drop into the oil pan.  Now I have to drop the pan to retrieve the keeper.  Extra work that I didn't want or need.  Based on the placement of the oil return hole, I believe the keeper is in the upper/rearward part of the oil pan.  I don't know what it's going to involve but it doesn't look like a fun or easy job.  I did a real good sealing up the pan while it was on the engine stand so it will be a bitch getting it apart, cleaning the mating surfaces and re-sealing.  I have no one to blame but myself.  I should have plugged the holes.  If anyone has tips, I am all ears.  Otherwise I will study this forum and others that I can find.  After my self-inflicted wound, I decided to drown my sorrows by replacing a toilet flush valve. The 25 year old tank to bowl fastener threads were corroded so it required heat and a 2nd person to hold the LARGE screwdriver while I heated and turned the nuts from the underside.  Finally got it and completed the repairs.  Back to the car project, I think today I will try to remove the starter to get it out of the way and get a better idea of what removing the pan will involve.  I have other projects to do so I don't expect to get a lot done on my project today.  I need a break from it.  Hopefully I will have good news to report shortly.
rob289c
rob289c
rob289c
1972 Wagon
Delivered: June 20, 1972
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
rob289c
rob289c
rob289c
rob289c
1972 Wagon
rob289c
rob289c
rob289c
rob289c
rob289c
rob289c
1972 Wagon
Congratulations on the new addition to your family!
rob289c
I only made a small amount of progress this weekend.  I sprayed the remaining corroded areas of the taillight housings with rust converter, then primer.  Then I spread tiger hair over the repaired area.  I haven't sanded it smooth yet.  Once I do, they will get another treatment of primer, then silver paint.  I ordered and received the taillight assembly gaskets so once the housings are in paint, I can reassemble them.  I bought more cushion clamps and speaker wire so I can get all the rear wiring properly run and secured.  While the interior panels are off I need to swap rear window channels from side to side.  I found a resource that identifies why my rear windows don't go all the way down: the channels are currently on the wrong side.  Hopefully swapping them will correct the full travel issue.  In the near future I need to replace the valve stem seals and install the valve cover, then install the front grill assembly, front bumper, and headlights.  Then I can reinstall the engine compartment wiring harness, and install the dash and dash pad.  That will allow me to connect all the wiring harnesses.  If I can get that done I will feel like I made good progress, although I didn't get to hear it run or drive it.
My excuse for not doing more is that our first grandchild was born yesterday.  Our daughter was induced and has been at the hospital since Thursday AM.  I had to take my wife there and back several times and I wasn't able to get too deep into any of my projects.
I will be travelling for work again this week but should be back at it next weekend.
Happy Veterans Day to all those that served.  Thank you for serving...
rob289c
rob289c
Battery is mounted in the trunk.  I made the following cables: battery ground to rear bumper mount, frame to engine ground, positive battery to trunk-mounted circuit breaker, Circuit breaker to starter relay location.  I haven't crimped the lug at the relay end yet as I want to secure the cable and mount the relay first so I make it the correct length.  Another day's project.  I also need to make the relay to starter cable.
I wanted to do more but taking down Halloween decorations, leaf duty, mowing , and other household chores took precedence.   More to come next week...
rob289c
rob289c
Progress today:  Mounted the rear bumper.  One of the mounting bolts is going to be the battery to frame ground point.  I also washed the taillight lenses while doing the breakfast dishes.  Dawn detergent did a nice job of removing 57 years of grime.
rob289c
rob289c
Some progress made today.  I spent roughly 3 hours repairing the bottoms of my taillight housings.  Both were badly corroded, one much worse than the other.  I cut out the cancer then fabricated patches and welded in place.  The really bad one had very little good metal to weld to but in the end both are pretty sturdy.  I will prime, use some tiger hair to seal and smooth things up, then more primer and paint.  I need to order taillight lens gaskets, and clean  up the rubber that is encrusted with corrosion from the original corroded taillight panel.  Once everything is in place, none of it will be visible and will be functional.  I am saving about $200 by repairing and re-using the old parts.  I have a set of new taillight bezels that I will put in my Fastback and use the ones currently in the Fastback in this project.  They are pitted, but in much better shape than the ones that came with the project Mustang.
Tomorrow I will do more and report.
Other projects today:  attempted repair, then replaced an entry door knob set.  They don't last long.  I also disassembled and PM'd my dehumidifier.  The drain had plugged and wasn't draining.   I cleaned the evap coil and drain pan.  All good now,
rob289c
