Date: 05/13/2021 05:33 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
cam pulley
Date: 05/30/2018 04:56 pm
Date: 02/21/2017 06:29 am
  • Total Topics: 16,268
  • Online today: 155
  • Guests: 126
  • Total: 126
rob289c
I was afraid it was gone for good.  I'm glad it's back.  I should be able to make more progress coming this weekend.
1972 Wagon:  I see you've had your Pinto for a long time.  It's great you have kept it so long!  I drove Pintos between Sep 1983 - Jan 1989.  Two wagons and a hatchback.  They were reliable and easy to maintain and repair.  They got me through 4 hears of Navy and the first three years of college.  I drove them until they wouldn't.  This current project is only half Pinto but it keeps one that would have been junked alive.
rob289c
Quote from: 1972 Wagon on October 14, 2024, 09:59:34 AM
So glad the site is working again as I have missed reading about your project! Glad you were able to make some progress.
Me too!  Scott told me he was going to take the site down for some much-needed maintenance, but didn't specify exactly when that was going to happen.  I guess we all got caught off guard!
1972 Wagon
Delivered: June 20, 1972
rob289c
I will back up to the dash repair as it looks like my Friday post isn't going to be published...for the major cracks over the instrument cluster, I used a razor knife to cut out the affected areas at an angle.  I filled the "excavations" in with aluminum foil.  Then regular Bondo, then I skimmed the entire dash pad with a lightweight filler (Porpoise Putty) and sanded smooth: 80 > 180 > 320 grit.  While it isn't perfect, it is much better than what I started with.  After final sanding it got 3 coats of adhesion promotor, then 3 coats of Krylon "Hammer Finish" textured black rattle can paint.  The textured finish masks some of the imperfections. Not perfect but good for what I am building.
rob289c
rob289c
It appears the site is working again.  On Friday I fabbed the rear portion of my fuel return line.  I use the pre-bent 5/16 supply line I got from CJ Pony Parts as my pattern and made a copy with 1/4 line.  Today I got the full length of the supply line in place and the rear portion of the return.  I need to get a 60" section of 1/4 and run it up toward the fuel pump then tie in both lines at the tank and fuel pump.  I wire wheeled all the fuel line and brake line hangers so next weekend when it warms up I can prime, paint and install.  I still need to replace the valve stem seals but that's a job I've never done so I'm a bit apprehensive.  I also need to get back to the rear quarter window installation job.  The passenger side needs to be re-done.  I think the regulator arm needs to be bent a little.  I'll figure it out.
rob289c
rob289c
Yesterday I was able to get on this site for the first time in over a week.  I tried to share recent progress but it didn't post.  THis may not either.  If it does, I will share what I did today...
rob289c
1972 Wagon
The dash looks really good! I enjoy following the work on your roadster project. Please keep posting updates!
Wow, the first post at the PCCA site in NINETEEN Days! The patient has a pulse - barely.
The dash looks great. What did you do to repair the cracks? I scrolled up but didn't see anything. I have tried in the past to do repairs but in the end while the gap filled I had to cover it with vinyl cloth to look half way decent.
rob289c
It's been a while since I've posted...mainly because I have made very little progress!  Too many other tasks, activities, and commitments have gotten in the way.  This past weekend I did do a little.  I painted the dash pad, instrument cluster, and rear package tray with my interior black paint.  That exhausted my supply of leftover EXP Project paint.  I had done come bodywork on the dash pad to fix the cracks.  I used adhesion promotor first, then a hammer texture rattle can to try to hide some of the imperfections.  It came out pretty good.  The instrument cluster and rear package tray got the regular spray gun treatment.  I am taking off the week of 10/7 so I home to make good progress then.
rob289c
rob289c
I made a little progress over the weekend, although it doesn't seem like I did.  I installed the two, rear quarter glass assemblies.  The job didn't go all that well.  I had cleaned the glass and tracks a few weeks ago, but I still had to clean the regulators.  One of the regulators had a bent arm and I'm not sure if I bent it back to the correct position.  It may still be a little off.  Anyway, I did the passenger side first as that was the demonstration on the You Tube video I watched over and over and started and stopped through the process.  It doesn't seem to go up and down through the full travel.  I think I may have to start over.  I did the driver's side and it seems to go up and down better but there is still some irregularity and doesn't seem "quite right".  I did replace the rollers on both sides so that isn't (shouldn't) be the problem.  It is an awkward job with limited visibility but I think I have the process down pretty well with all the fumbling around I had to do.  Last evening I watched another video that used a different method, but in the end, the result should be the same.  Sometimes when you take a break and try again it goes more smoothly.  I also discovered that 68 window cranks are different from 67.  My regulators are 67 (65-67 are the same), but my window cranks are from a 68 that I got from a junkyard when I got the inner quarter panels.  They don't go on.  I will have to order two for a 65-67.  They are only $15 ea, but the problem seems to be the set screw is crappy.  It is slotted, while the original is allen.  Hopefully I can use the set screw from the 68 handles as long as Ford didn't have a "Better Idea" and change the thread from 67 to 68!
That was all the time I got on my project (most of Sunday).  On Saturday I weeded a garden that was overgrown and cleaned gutters and downspouts.  I knew both needed to be done but I put it off all Summer as my goal was to get this project in paint.  I still have other "didn't get to it" projects from he Summer that need done before the weather changes.  This time of year work ramps up and my time gets scarce so every minute has to count.  This coming weekend I have other events scheduled that will prevent me from making as much progress as I would like but I do plan to spray some interior parts black as the weather will be conducive.
rob289c
rob289c
You and me both!  It's getting closer.
rob289c
Quote from: rob289c on August 25, 2024, 06:08:28 PM
I made progress and getting closer to being able to start and then drive it.
That's the day I'm looking forward to!
rob289c
Today I compounded, then polished the body.  Overall it came out nice and has a nice luster.  Unfortunately I burned through the paint in a couple of spots...nothing I can do about it now.  I also hooked the transmission lines back up.  I was going to make new lines but put the old crusty ones back in.  I put the fuel line back in place but ended up cutting it and will make it a 2-piece line with a double flare union to connect them.  Trying to manipulate and modify the one-piece Mustang line was proving to be too much trouble.  Anyway, I made progress and getting closer to being able to start and then drive it.
rob289c
rob289c
I was going to bend my own fuel lines and even bought a length of line.  After looking at my Fastback's fuel line I decided the intricate bends at the rear around the trunk area were going to be a PITA so I broke down and bought a one-piece 5/16" fuel like for a 67 Mustang for CJ Pony Parts ($90  :o).  I will use it at the rear and modify as necessary to get it to fit up to the fuel pump.  It was way too long for this project so I already cut 3-4' off the front.  I will repurpose the part I cut off to be used as one of my transmission cooling lines.  As for the fuel line, I did test fit at the rear yesterday but I am going to have to remove the left rear shock and maybe disconnect the parking brake cables to get it in the right spot.  It isn't going to be a fun job.  Once I have it bent, I will use it as a pattern to bend up the 1/4" fuel return line and install them together.  The Mustang didn't have a return line, but the the Pinto does.  I was able to get a Mustang gas tank sending unit that has supply and return line tappings.  Yesterday I also aligned the deck lid as best I could.  It is an aftermarket part and I don't like the way the left and right lines fit the top of the quarter panels, but as I keep reminding myself, it was never intended to be a perfect show car.  This morning I installed the trunk lock assembly.  It needs further adjustment and I will mess with that at a later time.  Tomorrow I plan to compound, then polish the body.  No wet sanding as the paint is single stage metallic and several body men and other research said DO NOT wet sand it.  What I do tomorrow will be fine.
Today I am riding the Harley to Syracuse for a 174th Fighter Wing Alumni Picnic with a guy I served with.  He also happens to be my son in law's father.  Maybe I will get a little progress on the project later today, but it may have to wait till tomorrow.
rob289c
rob289c
A few more things to report:  The deck lid is installed but not yet perfectly aligned.  I am going to loosen the quarter panel extensions, then put the big dog pillow on the decklid, a piece of plywood on top of it, then a piece of railroad track on that for weight to hold it down.  Then I will get under the car (the gas tank is not in place) and loosen the decklid mounting bolts and trunk hinge bolts.  Then I will move the decklid and quarter panel extensions into the best positions, then tighten everything down.  That should align things pretty nicely.
Beyond that, I installed tightened the power steering hoses, but still need to get some cushion clamps to mount and secure them.  The pressure hose connection at the pump concerns me...It is an o-ring seal and it doesn't tighten like I  think it should the instructions say it is a swivel fit so I have to believe it is installed correctly and won't leak.  I connected the throttle cable to the bracket and snapped the fitting over the ball.  I also bolted the trunk lid latch on to the bracket at the rear of the trunk area.  I started looking at how the fuel line should be run.  If anyone has a narrative on how it runs between the fuel pump to the rear, including how it runs down and mounts to the frame rail will be welcome.
Lots of little things to do that take time.  Gotta keep making progress!
rob289c
rob289c
This is a non-productive weekend when it comes to my project.  My employer is a major sponsor of our county fair so I spend every evening manning the booth, my car club's annual car show was yesterday, today I have to strip, then wax the floor at my VFW.  Friday before bed I went out to the shop and adhered the weather stripping to the trunk lid.  I am looking to install the trunk lid to the car later this afternoon when I get home from the VFW.
rob289c
rob289c
This needs to be black!
rob289c
rob289c
Today I did a lot of little things that don't show up as progress, but all necessary.  I bolted the dimmer switch in place.  I washed the Mustang II grill and reinstalled the marker light assembles.  I packed it back up and it's back in its box awaiting installation.  I spread out the under hood and rear lighting wiring harnesses out on the floor and got reacquainted with the connections.  I labeled the ends with masking tape and Sharpie when I removed it, but some of my writing isn't legible.  I think I have most of it figured out.   am going to wipe down the harnesses with mineral spirits before reinstalling.  I am going to have to re-wire pretty much the entire ignition section as it was in bad shape and I had to cob it together to get the engine to run prior to removing it.  I bought a Duraspark II wiring kit about three years ago so I should be able to make it serviceable.  I cleaned, lubed and installed the speedo cable, and re-installed the to floor frame pieces I fabbed last Fall.  I set the shifter in place just to see how it looks.  I disassembled the rear quarter windows and cleaned all the old dry grease out of the roller tracks and rollers.  I washed the assemblies so they are nicer to handle.  I still need to degrease the regulators, re-lube everything and install.  I cleaned the transmission lines but I think I need to get new ones made.  They are pretty corroded at the radiator end.  I don't trust them for the long term.  I will take them to the local hydraulic shop to get new ones made.  I wire wheeled the rear valance attaching hardware, the trunk lid hardware, the coil mount and starter relay mount, then primed and painted black.  Soon to be installed.  I took the instrument cluster out of it's box and realized I missed painting it what I sprayed black paint a few weeks ago.  I'll have to mix up a small batch so I can hide that hideous orange!  This AM I ordered 25' of red and 25' of black 1 ga battery cable and lug ends.  I am relocating the battery to the truck so I needed quite a bit of cable.  I also ordered a tube of 3M weather strip adhesive so I can install the trunk weather strip, then I can mount the trunk lid.  Once that's on, I will polish the paint.   I think that's it for now.  More next weekend.
rob289c
rob289c
Today after work I installed the side scoop ornaments and quarter panel extensions.  I also got a couple of boxes of parts and the rear window assemblies out of storage so I can start cleaning and installing.
Tomorrow (Saturday) I will be attending a car show that is part of a street festival in my home town, and Sunday I will be back on the project.
rob289c
rob289c
It's been a lot of work and it's engineer it as I go.  One modification generally leads to several other work-arounds to figure out.  I made a punch list of to-do items to get me close to the end but there are many I didn't list that will pop up.
rob289c
alwaysFlOoReD
Wow! That IS a major upgrade!Good luck.
rob289c
Thank you...I look it over every time I go out in the garage...I see a lot of spots where I should have spent more time and attention to detail, but then have to remind myself that I spent more time than I really wanted to and my skill level is novice at best.  I can't knit-pick a few pinholes and underlying crappy metal.  This was never intended to be a show car, but as you know, you always wish it was better!  Overall I am satisfied and it will garner a lot of attention when I drive it to its first cruise in!  I know the Mustang purists are going to tell me that I ruined a perfectly good Mustang until I show them what I started out with!  She was a real beauty...
rob289c
alwaysFlOoReD
You're making progress! Awesome job so far...
rob289c
I unmasked everything and wiped down dust from the last several months.  I had a helper for a few minutes and torqued the front wheel adapters.  I had previously only snugged them so now they are torqued with Loctite.  Back on 4 wheels so I pushed it back into its spot.  Now I can get up into he overhead and get parts that I can now start to do reassembly.  The orange steering wheel is only temporary.  More next weekend...
rob289c
rob289c
I don't know if I will do anything else to it this weekend.  I need to keep my paws off it so the paint cures.  I accidentally touched it...I had a rag on my left shoulder and as I bent down to look at the paint it started falling off.  When I went to grab it, I accidentally touched the left quarter panel and made a smudge.  Maybe it will buff out later.  Too soon to touch right now.  Anyway, another mission accomplished and I can move on to other things.
rob289c
rob289c
Today was high humidity and started raining while I was painting, but it is now Medium Gray Metallic.  Not the best day to spray, but even perfect weather wouldn't make a silk purse out of this sow's ear!   ;D  I had just enough paint for 3 good coats and I wish I had just a little more...I ran out as I was giving the left sail panel its final coat so there is a little tiger striping.  I didn't have enough to blend it in. Anyway, other than the expected orange peel, it came out pretty good.  I won't touch it till tomorrow afternoon.  We are getting our daughter's dog tomorrow morning (babysitting)...he better not decide to investigate and scratch it!
rob289c
rob289c
My little project will almost be a convertible.  There is a bit of a roof, but will be an open air vehicle.  I'll get that "wind in my hair" feeling, although there is a a lot less up there than I started with!  I had three convertibles when I was a teen:  '70 Cutlass, '65 Mustang, '68 Mustang.  I loved those cars.  Haven't had one since.
I can't remember if I mentioned it previously...I procured my windscreen.  Polycarbonate (Lexan).  I'm waiting on the clips I am having made to hold the bottom of the windscreen to the cowl.  Then I can install but will have to dream up some sort of support for the top of it.  During one of my sleepless nights it will come to me.
I am going to spray body color at some point over the next three days.  Sunday looks to be the best day weather-wise but I could do it as early as tomorrow (Friday), or even Saturday.  I want to get it done so I can move on.  Will report more after paint.
rob289c
Quote from: dga57 on August 01, 2024, 11:24:58 AM
...  Feels good to have the wind blowing through my hair again! ...
If only I could have that experience.  :(  The "land clearing" on the top of my head is getting close to a complete flesh toned Cul De Sac.  ::)  Happy motoring! As we all get older the days to enjoy keep getting shorter and with less comfort. Grab them while you can.
I can't get over how much progress you've made while I wasn't paying attention!  It's looking good!  I didn't realize I hadn't been online for so long either... have had lots going on.  A little over a month ago I bought myself a 2017 Mercedes-Benz E400 cabriolet, so I've been out riding around with the top down instead of spending time on the computer.  lol This is the seventh convertible I've owned, but there was a six-year lap between this one and the 2015 Mustang I sold in 2018.  Feels good to have the wind blowing through my hair again!  Your progress looks amazing.  Can't wait to see the finished project!
rob289c
That's usually when I start taking short cuts and do shoddy work!  ;D  There are so many small details left to do but I will feel much better after the body and paint part is done.  I'm not that good at it so it's not going to be show car quality, but that was never my goal anyway.  I think the next phase will be to fabricate supply and return fuel lines, then secure fuel and brake lines to the frame.  Then I can install the wiring harnesses and get ready to hear the engine run for the first time in three or four years.  I'm going to trunk mount the battery so that will be another project: buy and mount a battery box, and routing long cables.
I'll have to find some sort of radio.  I have the factory radio bezel.  Does anyone know of something that will fit in the hole?  I'm not interested in any high performance sound system...just want to have FM radio available.  I have JBL 6x9 speakers for the rear deck.
rob289c
