72 pinto drag car
Date: 07/08/2017 08:25 pm
Date: 01/19/2021 03:56 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 03/30/2021 12:29 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Date: 07/21/2017 11:49 am
Pinto drive train
Date: 06/29/2018 08:32 am
2 liter blocks and heads
Date: 03/28/2018 09:58 am
  • Total Topics: 16,268
  • Online today: 155
  • Guests: 139
  • Total: 139
davidpinto
HERES A PIC OF MY HEATER HOSE SET UP
D BARHAM
rob289c
I looked at a few vendors and the H-Pipe is not in stock.  I am far from that point in my project anyway so I will check again in the future.  Thank you for providing the P/N!
rob289c
davidpinto
I HAVE HEAT ,NEW HEATER CORE TOO.THE H PIPE BYPASSES THE HEATER CORE WHEN THE HEAT IS OFF.WATER COMES OUT OF WATER PUMP AND RETURNS TO THERMOSTAT HOUSING.TURN HEAT ON AND VALVE OPENS TO CIRCULATE THRU HEATER CORE AND BACK TO THERMOSTAT HOUSING>THE H PIPE PART # IS 84515 FOUR SEASONS LINE.THIS SET UP WORKS WELL.
D BARHAM
rob289c
You must not have heat in your car?  I was planning to reinstall the hater box if there is room.  I won't get to that until some time next year....
rob289c
davidpinto
ROB289 :NEVER HAS OVERHEATED EVEN ON THE HOTTEST DAYS.I PUT A 5/8 DIA H PIPE IN FRONT OF HEATER VALVE SO WATER CIRCULATES ALL THE TIME.OLD FORD TRUCKS HAD THEM FROM THE FACTORY.
D BARHAM
rob289c
rob289c
one2.34me
Get an old extension or big screwdriver or punch and with a hammer hit the plug right inside the edge. It will drive the plug sideways in the hole and you can pull it out with pliers. You can put a film of sealant on the outer edge of the new plug and use a similar size socket or such to tap in the new plug.
https://www.bing.com/videos/search?q=removing+freeze+plugs&&view=detail&mid=D1411E708B1592EB8697D1411E708B1592EB8697&&FORM=VDRVRV
rob289c
What is the best way to remove them?  Hammer and screwdriver and pry them out?  And for replacement...tap them in with a hammer?  Is there a special installing tool?  Do you put any sealant on the lip before installing?  I've never replaced them...it was always done by the machine shop after hot-tanking.
rob289c
one2.34me
Rob, when I had my 2.3 out, I changed the freeze plugs. The one in the back of the head looked good, but when I removed it there was an area on its' backside almost completely corroded through. With your freeze plugs pulled you can reach into the block and remove a lot of gunk and material from the water jacket with your fingers and a magnet.
rob289c
So no overheating or no other negative effects?  It is plumbed into top heater pipe that runs along side the valve cover.  What is/was it's original function?
rob289c
davidpinto
I BRAZED UP THE WATER PORT ON MY INTAKE ,BOCKING IT OFF AND GOT RID OF ALL THAT EXTRA PLUMBING.MOTOR WARMS UP FASTER <SAVING FUEL>AND LOOKS A LOT CLEANER TOO.
D BARHAM
rob289c
While degreasing the intake, I noticed the coolant port felt slimy so I took it to the kitchen sink and ran hot water into the port.  dirty water and small bits of debris were coming out.  I continued to fill and shake the intake and more and more debris loosened and came out.  Eventually water started coming out of the small hose barb and more and more debris started pouring out.  I kept it up for at least 10 minutes until clean water and very little debris came out.  I noticed a little more external grime so after taking it out to further clean it I decided to run hot water through it again.  Glad I did...large chunks had loosened came out.  Classic sign of a poorly maintained cooling system.  There is probably similar debris in the block's water jacket.  Once it is time to run the engine again, I will run some coolant system flush through it.  I am a little leery of doing that as I know some of the dislodged debris will re-lodge itself in small spaces and maybe do more harm than good.  What do you guys think?  I asked in a previous post what it is and what purpose does the thing in the picture serve?  I am pretty sure that's where the debris was hiding before flushing the intake.  What was not cooling when the small hose port was plugged?  There is a 2-hose vacuum port on the opposite side from the water barb.  Just trying to understand what all the vacuum -operated components do so I can decide what to keep and what I can eliminate.
rob289c
rob289c
Over the weekend I got the timing assy put together and continued cleaning/degreasing/painting parts.  I had to quit a bit early on Sunday as I had a 5-hour drive ahead of me.  Had to mow the lawn/zoop up leaves, and other chores so I could be away for a week.  Pics below of my progress.  The valve cover got a quick spray of black paint (it was blue), then I sanded the ribs to bare aluminum.  I like the look.  It will be powder coated as a permanent coating.  I had to trim and massage the baffle under the oil filler cap in order for the gasket surfaces to mate.  It is only on temporarily so I can see how it will look.  I cut the timing belt cover down so I can see the cam pully go around when running.  I degreased and painted the intake with aluminum engine paint.  I have more to do but it will have to wait until next weekend...
rob289c
The story of your house sounds like mine, with the exception of the deep lot.  It's on the outer edge of a circle, was four years old when we bought it, but had been totally trashed by the original owner.  We bought it for roughly half its appraised value at the time but there was a lot of work to do.  Fortunately, it was mostly cosmetic and within my scope.  I spent the first couple years whipping it into shape, and I have to say it has served us well.  We will have lived here 25 years this coming December, and the house has undergone several renovations to meet our needs.  My problem is that it's a large house on a small lot... no room for a garage at all.  Oh well!  I would have moved on years ago, but my wife was one of those kids that was uprooted and moved due to her parents' work for her entire life.  She attended over a dozen different schools and never felt she got to put down any roots or form any lasting friendships.  When we bought this house, she said she was never going to move again!  So far, she has stuck to her guns on that attitude whenever I've mentioned the possibility, but I still hold out hope that we can move someday.  I could do with a little less house and a nice garage; for me, that would be Heaven.
rob289c
Thank you.  I made more progress yesterday.  More cleaning, degreasing, priming, painting of parts.  I replaced the crank, cam, and aux shaft seats.  Started reassembly.  Will do more parts prime & paint today.  I will do more assembly today.  I will have to cut my day short...I have a 5+ hour drive this afternoon as I will be working out of state this coming week.  I will post more pics of my progress later.
My garage: it started off life as a 22.5' wide x 22' deep attached garage.  When we moved here in 2003 I really wanted to live a little more in the sticks and have a 40x60 pole barn.  I cam across this house in a small rural development.  It is on a circle with about 40 homes and I am on the outer ring on a dep lot that backs up to a nice hedgerow.  The house was 4.5 years old and almost in foreclosure.  The former owner was a single mom that pretty much trashed it so with some cleaning, painting, and flooring we got a a pretty nice newer home at a bargain price.  The deep lot gave me the idea that I coule add on to the garage to create my own "pole barn".  So now I have a 22.5' wide by 66' deep garage.  The whole setup is pretty nice.  Over the years I've made the place the way I want it.  In the Wintert serves as a garage to house 6 cars, 2 motorcycles, shop equipment and tools and other stuff.  In the Spring, Summer, Fall it is a shop, and it also serves as a "party hall".  Now I will complain...22.2' isn't wide enough.  Of course the whole thing should be at least double in size!
rob289c
Scott Hamilton
rob289c
Thank you...I will do more this weekend.
rob289c
It is, indeed, looking good!!!
rob289c
Today I removed timing belt, aux shaft sprocket, Crank sprocket (both were a PITA!), removed timing belt housing, oil pan, valve cover, and other pieces/parts.  I cleaned and degreased the removed parts and hardware.  Primed and painted block, oil pan, new water pump, t-stat housing, timing belt housing, timing belt cover.  I have a couple of pics below.  My phone wouldn't send all the pics so I can't post them all.  I need to remove the cam sprocket so I can replace all three seals.  I will paint the cam sprocket as it will be exposed.  So far it's looking good.  I need to get the rest of the pieces/parts done so I can reassemble and reinstall before month-end.
rob289c
rob289c
Crank pulley off, Intake off, water pump off, t-stat housing off.  Exh manifold bolts loose but haven't taken it off yet.  Need to R&R timing belt and tensioner, but need to clean up and prime and paint the inside of the timing belt area before replacing belt as it will be left exposed.  I will start degreasing the block, head, and oil pan and prepping for primer and paint.  I have a Mid-80's T-bird valve cover so the one on it won't be used.  Progress...
rob289c
rob289c
Today I started removing components from the engine.  I stared with the alternator and power steering pump and brackets.  No problem with the alternator.  I was able to remove the two top power steering pump bracket bolts, but the lower one broke off.  I won't get into the details, but will divulge that I spent a substantial amount of time, effort and frustration getting the bracket off.  The process included a hammer, angle drill, pry bar, and while I did finally get it off, I cracked the bottom of the bracket by getting overzealous with the hammer.  I removed both motor mounts.  The left side looks like it had been replaced at some point but the right side is defective.  I have two new ones and a new tranny mount so all will be replaced.  I pulled the distributor out.  I removed the radiator hoses and disconnected the heater pipes.  I removed the fuel pump and the guard that is over it.  I removed the fan, fan spacer, and water pump pulley.  I removed the timing belt cover.  My next challenge is getting the crank pulley off.  I got the bolt out with my impact, but when trying to pull it off with a 2-jaw puller, the inner groove started bending.  I will take any advice from the experts on how to get it off without ruining the pulley.   Is heat advisable?  I think it might ruin the crank seal, but I need to get it off so I can replace the timing belt and clean up and paint the pulley.  I plan to replace the seal anyway.  I have sprayed penetrating oil where I could hoping it will loosen things up.   I loosened, but didn't remove the water pump and thermostat housing bolts.  Next weekend I plan to remove the intake and other fuel and emission system components.  I will have to figure out what I need to keep for vacuum hoses.  I want to eliminate as much as possible.  I plan to remove and block off the EGR.  The stock air cleaner won't be used so there are a bunch of hoses I won't need.  I have a header so not cat converter will be used.   There is a pic below of a component that I need help identifying.  It is under the intake/carb and has a HW line that runs to or from one of the heater pipes on top of the engine.  If anyone can identify it, please let me know what it is, what it does, and if it can be eliminated.  Once I get more stuff off the engine I will clean it with lacquer thinner, then prime, paint, reassemble, and put it back in the chassis.
I got some good news on the title.  The person I got the Mustang portion from found the title.  The previous owner signed it over to him but he never registered it in his name.  It is a PA title so he and I will have to go to a Notary in PA to get it in his name, then get it signed over to me.   A bit of a hassle, but it's what I will have to do to get it in my name and registered in NY.  I ordered and received a VIN tag that is stamped with the correct VIN so it will look official.
I'm in crunch time with a short window of opportunity to hit the goals I set for myself before calling it quits for the season.  I will carry on...
rob289c
Sounds like pretty good progress under the circumstances.  I'll bet your house looks neat all decorated for Halloween.  My daughter-in-law handles all the outdoor decorating at our house.  She hasn't started on Halloween yet, but they're going on a vacation trip next week and she says she'll do it as soon as they return.
rob289c
The underside is now black.  It took longer than I expected but it is sealed up really well.  I didn't get a chance to use the rattle can black in difficult to brush areas.  What I brushed on was still wet and/or tacky and I had enough paint on my hands and arms so I figured it would be better to wait than to mess up what I had just brushed on.
More to come next weekend...
rob289c
rob289c
Today I helped my wife decorate outside for Halloween.  We have a tree that gets hundreds of orange lights and takes over two hours to do, among other lights and decorations.  We had good weather today nd she had an Saturday off so we did it.
This afternoon I brushed red oxide primer on the underside, including leaf springs, differential, axle housings.  Tomorrow I'll brush black enamel on and use black spray paint on any of the hard to get to spots. I need to take a good look at the engine and put my game plan together for some disassembly, cleaning/degreasing, sanding wire wheeling, priming, painting.  Will do some re-gasketing.  I have taken deliver of mot of my recently ordered parts.  I have a few more that will come this week.  I am looking forward to assembly in the near future.  That's when it gets exciting!
rob289c
Sounds like another busy weekend you have lined up there!  Keep us in the loop!
rob289c
Tomorrow (Saturday) I will brush paint the underside.  Red Oxide Primer first, then black enamel.  That will seal up the underside and my next thing will be to start detailing the engine, engine accessories, and any other "under hood" parts.  I ordered a bunch of stuff from CJ Pony Parts and Rock Auto that are starting to trickle in so I have what I need to do a lot of the remaining work.  I bought an engine gasket and seal kit so I can re-gasket any external engine parts.  Might as well do it now with the engine on the stand rather than later when it is in the chassis.  I want to get the engine back in the frame before I put it away for the Winter.  I also ordered a VIN Tag with the VIN stamped on it now that I know what the Mustang VIN is.  I'll have to start working on the titling process.  I need to check with the upholstery shop that has my seat frames and covers to see if he's made progress.
There is a car show that I should patronize on Saturday but in order to stay on schedule, I can't sit at a show all day just to be cordial so I may pop in as a spectator only for a few minutes and make a donation to the show organizers.  I have a wedding to go to this afternoon (Friday) so that is kind of getting in my way too.  Anyway, I continue to make progress but there is still a long way to go.
rob289c
Quote from: rob289c on September 18, 2022, 08:08:43 PM
  Long day, but progress was made!
:o What an understatement!!!  You made AMAZING progress!  It looks great!
rob289c
Started shooting Black shortly after 6:30....done and cleaned up at 8:30.  Long day, but progress was made!  I only painted the under side of the decklid black.  The top side will be body color.  I only have so much of the body color and no one will see the trunk area and underside of the deck lid unless the truck is open so I didn't want to waste it.  The body is going to be leftover Medium Gray Metallic from my EXP project.
rob289c
rob289c
Two more pics after shooting epoxy.  My exhaust fan pulls any airborne particles out.  It's a furnace fan on low speed.  I made a square to round transition and attach an Air FOrce Heater Hose to it to route it out the back door of my garage.  I use blue tarps to segregate the rear 2/3 of the garage from the "paint booth".
rob289c
rob289c
This AM I did all my prep work:  cleaning the surfaces, wiping down with degreaser, tack cloth, jacked it up, got the gun and paint materials ready.  I didn't start spraying till about 1:30.  Spraying the underside didn't work too well.  I will have to paint it with a brush.  No big deal; there isn't that much of an underside.  I sprayed all exterior surfaces, the trunk area, frame, and cabin with Epoxy.  Came out pretty good.  Since I got a later than desired start and the primer isn't quite cured, I am in a waiting pattern before I can spray black enamel.  It is about 5:00 now so I am hoping that by 6:30 I can do the black, then get everything cleaned and put away so I can put myself away for the night!  Pics of epoxy attached.  Will take pics of black later after spraying...
rob289c
