Date: 12/04/2018 07:40 pm
Date: 03/17/2019 03:57 am
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 03/06/2017 01:19 am
McLeod Clutch
Date: 04/12/2017 12:08 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Date: 04/12/2017 08:15 am
Date: 03/18/2020 01:30 am
  • Online today: 2,399
  • Guests: 1511
  • Total: 1511
77 Cruising Wagon Build
Started by 71pintoracer, April 23, 2020, 04:56:14 PM
Dtmix
You probably already know about this 1977 Pinto Cruising Wagon being parted out at Moudy Auto of Arkansas...but in case you're not aware of it or is seeking parts, here's the info.
Moudy Auto is a family owned dismantling yard located at 3668 Highway 367 South in Searcy, ARK. 72143. Their number is 501-305-3620. There's no web address given.
I received in the mail the February 15, 2021 issue of Old Cars Weekly, and the car was pictured among many other cars in their yard (page 35).  It still has all the exterior  pieces that pertains to the Cruising Wagon package except for the porthole glass that was removed. It did not show the interior so I have no idea if there's anything left, such as the interior panels that fills in the space of where the porthole panels covers.
Good Luck and Happy Motoring!
Dan
Happy Motoring!
Dan
Quote from: 71pintoracer on January 28, 2021, 07:16:58 PM
Little by little Dwayne! I'm ready to order the complete front suspension kit from Speedway Motors with tubular control arms and coilovers. Using their manual rack & pinion and I'm going to use electric power steering!
Sounds good!!! :)
Jimmy,
So glad you're making progress on it.  Can't wait to see the final result!
Dwayne :)
Well I know it's been quite awhile since I've posted! I finally finished the 8.8 and I'm getting ready to install it. Still waiting on the new leaf springs so I've been sand blasting and sealing the other parts with por 15. Trying to load pictures stay turned lol
Thanks, even though it won't be seen l still want it to look new when it goes in. Taking a break right now, been doing outside projects at my house and my mom's. l did located an 8.8 Explorer rear end with disc brakes and a 3.73 and limited slip. My friend has a machine shop so we're going to set it up in the Bridgeport and drill the welds so we can shorten the left side axle tube.
warhead2
Looks really good.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Just regular 'ol rattle can lol but l did use a quality brand, Krylon primer and paint
warhead2
What type of paint did you use?
Thanks Dwayne! Little by little. At some point I'm going to build a dash, going to use parts from both cars for that also and who knows what else lol
In between other things I rebuilt the heater case using parts from three different cars. The original had been modified somewhat because of the dealer installed a/c that I'm not reusing. New heater core, new foam on the doors and even though you won't be able to see it l still painted it.
lol right! Haha hard to tell how long it's been there it actually held up pretty good! But now it all has to come out
warhead2
That bondo looks like the same guy that did mine lol.
Had a spot the was almost 1/2 thick.
Fuel cell mounted so l don't need this anymore
A few more rust spots getting fixed
On the 2 1972s that I've done there was over 100 spot welds.
After work was done & POR 15 used (I posted this I think in the Blue 72 Project) plus it will never be a daily driver ever again, it should last 100+ years.
Big job !
That's a good thought, it's really difficult to clean them out. Hopefully this car will live indoors from now on and be a fair-weather driver!
lol
warhead2
Wonder if you took the whole cowl off and welded a hinge for the side pieces of the cowl and use a body weld glue instead spot weld the side pieces to make it somewhat easier access for whatever you needed  to get in there in the future. Also use seam sealer for where hinge is. Just a thought
Spot welds on the outermost edge, the rest was cut and then welded back together
warhead2
Is that piece separate from the cowl like spot welded to it? Or was it cut?
Man that was a project! Hats off to my brother the expert body man and fabricator he worked his butt off on that! And it really didn't have a lot of crud in there, (you're right, they usually do) the car sat in a dry building for 13 yeas then in my driveway for another 13, no trees around it at all. It just rusted around that vent. The passenger side is made different and it's solid.
now you got the hard part done the rest should be easy , that is the most difficult spot to get to and fix , bet that area was packed with leaves and other rust causing crud .
Cowl panel
No sure don't sorry
